Topic: mp3DirectCut - cut, split, fade and record mp3s (Read 25230 times) previous topic - next topic
Re: mp3DirectCut - cut, split, fade and record mp3s
It is very useful... and runs with wine on linux
The most important audio cables are the ones in the brain
  - UTF-8 character encoding for cue, project and ini files
  - Inernal ANSI/Win98 compatibility removed
  - Checking 4GB size limit
  - Cut noise mute function
  - Settings button in the toolbar
  - Graph font localization issues fixed
  - Some other corrections and improvements
http://mpesch3.de
- Multilanguage support changed to UTF-8
- Bright symbols layout for smaller window width
- Lots of minor improvements
https://mpesch3.de/
Keep up the good work!
Glass half full!
- Possible startup crash fixed (on text button layout set)
- Some minor improvements and corrections
https://mpesch3.de/
https://mpesch3.de/
Thans for this.
How does the "Cut noise mute function" work? There's no entry in the manual and I cannot figure it out / get it to work.
- Level activated recording feature
- Batch search and path fields reacting on killfocus
- Larger range of graph level adjustment (Num +/-)
- Some more improvements
https://mpesch3.de
Reply #32
Does not work for me, doesn't accept cue file formats and you can't even uninstall it..beware
what do you mean by "beware"?
wagner reatto
Reply #34
- Cue sheet load problem (wrong null char) fixed
- Longer delay time for tooltips
- Check for overdrive function (Normalize)
- Fixed garbage bytes on Xing header creation
- Some corrections
https://mpesch3.de/
Reply #35
- Overdrive check feature removed (inacurate detection possible)
- Minor corrections
https://mpesch3.de/
Reply #36
- Tooltip glitch fixed
- Timeline overflow fixed
- Audio display glitches fixed
https://mpesch3.de/
