Topic: [Not my release] Biography view (Read 377419 times) previous topic - next topic
Reply #375
Would it be possible to implement the following choice:  "Display biography info for selected track" or "Display biography info for playing track" in the panel preferences?
I think this would be a really nice feature and it doesn't seem to be too difficult.
Would also appreciate a way to set the bio to display for only the playing track.
Reply #377
up
Reply #378
vbscript update for AMG reviews:
Reply #379
download link: http://pastebin.com/download.php?i=YgXKSFUV
Enjoy
Awesome!
Do you think it is possible to update for AMG Biography?
@ssenna,
I guess it has already be asked and maybe it is just not possible to implement it, but to add the possibility to change on demand (w/o changing manually the order in the preferences) the server for Biography panel and/or to specify a server for a particular biography panel in the layout would be great.
Hence we could have a specific Biography panel for Last.fm, another one for wikipedia or for AMG...
Thanks anyway,
Decalicatan Decalicatan
Reply #380
Enjoy
Thank you so much for this script.  It works perfectly.  I would also like to know if there is a way to have it pull the artist biography instead of the album review.  I know nothing about this sort of thing, so any help you could provide would be great.
Jason
Reply #381
AMG biography VBScript update download link: http://pastebin.com/download.php?i=i1RfTb9M
Usage: cscript //Nologo scripts\foo_allmusic_b.vbs "%album artist%"
Problem can emerge when there are more artists with the same name. Typical example, pop artist "Air", and returned result for jazz artists from 70s. Right now, first match is returned that matches artist name (played in foobar), and although options exists for "relevance" or "significant" parsing, that doesn't solve possible issue, as I quickly checked. So keeping the script simple and fast I won't add another page request to check artist discography for match. However if more users demand it, I'll do it
My only issue when I was writing first script was that I couldn't find a way to parse HTML page as XML/XHTML instead using regular expressions. I wraped it in XHTML but MS XMLDOM couldn't see it. If someone has idea how to parse HTML as XML in VBScript please let me know.
If you compare both scripts you can see that it isn't that hard to pull arbitrary data from allmusic. Maybe I should have commented the code, but it seem silly to do so for such small script.
Edit: Minor issue corrected. Line 31: "<div id=""bio""> to "bio"">
Link updated
Reply #382
They work well and rapidly, thank you. One problem, if there is no result by the script, "no match for:" display. How can I to do then if I want to search by last.fm or wiki in turn?
Reply #383
Romor,
Thanks again for the script.  It works perfectly.  It would be great if you could have it check artist discography in the event of multiple matches, but I understand the desire to not want to do that unless really demanded.  I also do not know the impact of that additional check on the speed, as the script as written returns results very quickly, which is great.
Thanks again for you efforts.
Jason
Reply #384
I'm always listening online streams by FB2k, some of the radio supply dynamic track sources, is it possible search the artist/album info by run exterior script?
Reply #385
Thanks for the script romor!
Do you have any idea why this query works:
cscript //nologo foo_allmusic_r.vbs "amos lee" "supply and demand"
But this one gives an error that no review was found (which obviously isn't correct)?
cscript //nologo foo_allmusic_r.vbs "amos lee" "last days at the lodge"
thanks!
Reply #386
Apparently because of two paragraphs, meaning CRLF wasn't covered by regex pattern. I remember I considered this, but maybe forgot something at some point.
You can change last part of line 32: ([\S ]+) to ([\s\S ]+), or re-download from here: http://pastebin.com/download.php?i=1PvmetSv
Please post such issues in future also
About allmusic biography script, I'll consider discography search for multiple artists matches when I have time for vbscript
Reply #387
Thanks for the quick fix!      I'll will report any further issues if I encounter them.
By the way someone earlier reported that sometimes the text in foobar was incomplete.
I just encountered an example with the bio of Ryan Adams. After  a couple of sentences the text in Foobar abruptly ends with an H
However, when I ran the script manually, the complete bio appeared in the command prompt but the problem obviously is with the ü which should have appeared after the H (of the band Hüsker Dü).
Next I tried directly retrieving the bio of Hüsker Dü and it worked fine....
So there's a problem somewhere with these kind of characters, is that a known issue with the bio plugin itself?
Reply #388
I uploaded Amazon review vbscript here: http://www.hydrogenaudio.org/forums/index....showtopic=86092
Artist's Biography is not available through this webservice
I plan *later* to merge allmusic scripts in one and extend it with classical music reviews feature, that's why I'm not posting extension for allmusic biography with discography match
Reply #389
It feels not good to scroll with middle button of mouse if there's a long biography, it'll be nice to scroll it with "page up" and "page down".
Reply #390
This plugin is pretty great, and I see alongside the biography text it also holds "similar artist" information? (At least... I assume it is this plugin.)
However this information isn't shown anyone and I can't figure out a way to use it... is there no titleformatting that would allow me to grab the information stored in Similar Artists/bio?
eg: Like so...?
Reply #391
thank you!
you can get information discography?
I do not know anything about scripting ....
Reply #392
Link updated
a quick guide on how to use this script?
Reply #393
file>preferences>tools>biography server. add run external script to the current source list. highlight it and move it to the top of the list.
back in the left hand pane, select run external script and add this new command
now i'm not sure if the scripts folder here is relative to the user profile folder or the main foobar folder so you'll have to work that out for yourself. save the script from the pastebin website using the same file name.
Reply #394
as i was bored, i tried looking at fixing the vbscript so that line breaks in the AMG bio are retained but it was beyond me.
so i bodged in a little jscript to handle that. the script is here....
http://pastebin.com/XFNQTesT
note this uses a different file extension and must be saved/called accordingly.
cscript //Nologo scripts\foo_allmusic_b.wsf "%artist%"
(i prefer %artist% over %album artist% but that's just a personal preference)
Reply #395
thanks, but doesn't work here, don't know why...just create a folder called "Nologo scripts" and put foo_allmusic_b.wsf in that...
ps, Is it possible to keep album review from allmusic?
Reply #396
nologo is a command line switch - not part of the folder name. i even put the folder name scripts in bold...
Reply #397
I love this plugin....but my only problem is with the "AC/DC" name, I use the following file path to save the last.fm data on my pc:
____________________________________________________________________________________________________
Metadata: C:\Users\maXelo\AppData\Roaming\foobar2000\lastfm\artist\$swapprefix(%artist%,A,The,Los,El,La,At The,As I,At The)
Image:    C:\Users\maXelo\AppData\Roaming\foobar2000\lastfm\artist\$swapprefix(%artist%,A,The,Los,El,La,At The,As I,At The)
Artist:
Folder path: C:\Users\maXelo\AppData\Roaming\foobar2000\lastfm\artist
File Name: [(%artist%,A,The,Los,El,La,At The,As I,At The)]
Album:
Folder path: blank
File Name: [%artist% - ][%album%]
But somehow I can't save the AC/DC last.fm data, any ideas?...thanks in advance
Reply #398
try
$replace(%artist%,'/',-)
Reply #399
I'm sorry but where exactly do I put that string?
