Topic: Need help with EAC/MAREO configuration (Read 2452 times) previous topic - next topic
Setup question from an absolute newbie...
I'm preparing to rip my cd collection, and have installed EAC with Mareo, in hopes of ripping my discs in .flac and .mp3 formats simultaneously.
I went through the install and configuration and have tried a couple of test rips -
Following each song scan, I get a message indicating that "mareo.exe has encountered a problem and needs to close". This is typically followed by another message in a separate box (in this case for a self-titled CD, track #4, titled "Trompe L'Oeil". Similar messages appear for each track, and :
The external comrpessor returned an error!
Options : mario.ini "C:\Documents and Settings\Walter\Walt's CD Collection Rips\Atmp660-!.wav" "C:\Documents
and Settings\Walter\Walt's CD Collection Rips\Atmp660-!.flac" "Advent" "Advent" "Trompe L'Oeil" "04" 1997
"Progressive Rock"
File : C:\Documents and Settings\Walter\Walt's CD Collection Rips\Advent - Advent - 04 - Trompe L'Oeil.wav
The log from my test CD rip is as follows:
Exact Audio Copy V0.99 prebeta 4 from 23. January 2008
EAC extraction logfile from 8. March 2009, 21:37
Advent / Advent
Used drive  : HL-DT-STRW/DVD GCC-4481B  Adapter: 1  ID: 0
Read mode              : Secure
Utilize accurate stream : Yes
Defeat audio cache      : Yes
Make use of C2 pointers : No
Read offset correction                      : 6
Overread into Lead-In and Lead-Out          : No
Delete leading and trailing silent blocks  : No
Null samples used in CRC calculations      : Yes
Used interface                              : Native Win32 interface for Win NT & 2000
Gap handling                                : Not detected, thus appended to previous track
Used output format              : User Defined Encoder
Selected bitrate                : 768 kBit/s
Quality                        : High
Add ID3 tag                    : No
Command line compressor        : C:\Program Files\Exact Audio Copy\mareo\mareo.exe
Additional command line options : mareo.ini %s %d "%a" "%g" "%t" "%n" %y "%m"
TOC of the extracted CD
    Track |  Start  |  Length  | Start sector | End sector
        1  |  0:00.00 |  5:58.40 |        0    |    26889
        2  |  5:58.40 | 10:37.00 |    26890    |    74664
        3  | 16:35.40 |  3:31.57 |    74665    |    90546
        4  | 20:07.22 |  3:27.05 |    90547    |  106076
        5  | 23:34.27 |  5:14.45 |    106077    |  129671
        6  | 28:48.72 |  4:30.08 |    129672    |  149929
        7  | 33:19.05 |  4:11.37 |    149930    |  168791
        8  | 37:30.42 |  1:28.33 |    168792    |  175424
        9  | 38:59.00 |  7:08.27 |    175425    |  207551
Track  1
    Copy aborted
Track  2
    Copy aborted
Track  3
    Filename C:\Documents and Settings\Walter\Walt's CD Collection Rips\Advent - Advent - 03 - Rear View Mirror.wav
    Peak level 100.0 %
    Track quality 100.0 %
    Copy CRC EE5E5309
    Track not present in AccurateRip database
    Copy OK
Track  4
    Filename C:\Documents and Settings\Walter\Walt's CD Collection Rips\Advent - Advent - 04 - Trompe L'Oeil.wav
    Peak level 99.9 %
    Copy CRC E4FB8FC6
    Copy OK
Track  5
    Filename C:\Documents and Settings\Walter\Walt's CD Collection Rips\Advent - Advent - 05 - Nowhere Else To Go.wav
    Peak level 99.9 %
    Copy CRC 1B99215A
    Copy OK
Track  6
    Filename C:\Documents and Settings\Walter\Walt's CD Collection Rips\Advent - Advent - 06 - In The Tree.wav
    Peak level 99.9 %
    Copy CRC 473F8506
    Copy OK
Track  7
    Filename C:\Documents and Settings\Walter\Walt's CD Collection Rips\Advent - Advent - 07 - Marche To The Fighte,The Retreat.wav
    Peak level 99.9 %
    Copy CRC 0FD7375C
    Copy OK
Track  8
    Filename C:\Documents and Settings\Walter\Walt's CD Collection Rips\Advent - Advent - 08 - Caminando.wav
    Peak level 99.9 %
    Copy CRC 98632A0D
    Copy OK
Track  9
    Filename C:\Documents and Settings\Walter\Walt's CD Collection Rips\Advent - Advent - 09 - BITB.wav
    Peak level 99.9 %
    Track quality 99.9 %
    Copy CRC 80CAFB79
    Copy OK
 7 track(s) not present in the AccurateRip database
 2 track(s) not fully ripped for AccurateRip lookup
No tracks could be verified as accurate
No errors occurred
End of status report
Finally, my config file follows:
; ******* MAREO: Multiple Applications Runner for EAC and Others - by Kwanbis - Open Source GPL Licensed ***********
;  [PLACEHOLDER]      VALUE
;  [SOURCE]          Temporal source FULL file name, command line arameter #2 passed by the ripper to MAREO
;  [DESTTMP]          Temporal destination FULL file name, command line arameter #3 passed by the ripper to MAREO
;  [ARTIST]          CD Artist Name, command line arameter #4 passed by the ripper to MAREO
;  [ALBUM]            CD Name, command line arameter #5 passed by the ripper to MAREO
;  [TITLE]            Track (song) Name, command line arameter #6 passed by the ripper to MAREO
;  [TRACK]            Track (song) Number, command line arameter #7 passed by the ripper to MAREO
;  [TRACKPADDED]      [TRACK] padded with PaddingZeros.
;  [YEAR]            Year of the CD release, command line arameter #8 passed by the ripper to MAREO
;  [GENRE]            CD's Music Genre, command line arameter #9 passed by the ripper to MAREO
;  [1] .. [N]        Any parameter passed by the ripper to MAREO, after the genre.
;  [NOTHING] It gets transformed to an empty string. (Fo example, if you need to pass no param to the encoder)
;  [OWNPATH]          Full path to MAREO, without the the ending backslash, example: c:\encoders
;  [EXTENSION]        File extension without the dot (ex: MP3), as specified to MAREO on the INI as EXTENSION = XXX
;  [DESTTMPPATH]      Destination temporal PATH as passed to MAREO by the ripper (in dest).
;  [DESTTMPNAME]      Destination temporal NAME as passed to MAREO by the ripper (in dest), with no extension.
;  [DESTTMPFULLNAME]  Destination temporal full name: desttmppath+desttmpname+extension.
;  [FINALPATH]        Destination final PATH as specified to MAREO on the INI, as PATH.
;  [FINALPATHSHORT]  DOS/8.3/"no spaces" version of [FINALPATH]. Is required because mp3gain does not works with paths with spaces.
;  [FINALNAME]        Destination final NAME as specified to MAREO on the INI, as FILENAME, with no extension.
;  [FINALFULLNAME]    Destination final FINALPATH+FINALNAME+extension.
;  [APPDATA]          File system directory that serves as a common repository for application-specific data.
;  [CDBURN_AREA]      File system directory acting as a staging area for files waiting to be written to CD.
;  [COMMON_MUSIC]    File system directory that serves as a repository for music files common to all users.
;  [DESKTOP]          Virtual folder representing the Windows desktop, the root of the namespace.
;  [DESKTOPDIRECTORY] File system directory used to physically store file objects on the desktop (not to be confused with the desktop folder itself).
;  [LOCAL_APPDATA]    File system directory that serves as a data repository for local (nonroaming) applications.
;  [MYDOCUMENTS]      Virtual folder representing the My Documents desktop item.
;  [MYMUSIC]          File system directory that serves as a common repository for music files.
;  [MYPICTURES]      File system directory that serves as a common repository for image files.
;  [MYVIDEO]          File system directory that serves as a common repository for video files.
;  [PERSONAL]        Virtual folder representing the My Documents desktop item.
;  [PHOTOALBUMS]      Virtual folder used to store photo albums.
;  [PLAYLISTS]        Virtual folder used to store play albums, typically username\My Music\Playlists.
;  [PROFILE]          User's profile folder.
;  [PROGRAM_FILES]    Program Files folder.
;  [PROGRAM_COMMON]  A folder for components that are shared across applications.
;  [PROGRAMS]        The file system directory that contains the user's program groups (which are themselves file system directories).
;  [SYSTEM]          Windows System folder. A typical path is C:\Windows\System32.
;  [WINDOWS]          Windows directory or SYSROOT. This corresponds to the %windir% or %SYSTEMROOT% environment variables.
; NUMBER OF ZEROS TO PAD THE TRACK NUMBER (0 to disable)
PaddingZeros = 2
; IS MAREO REQUIRED TO DELETE THE WAV FILE AFTER ENCODING (TRUE) OR THE CD RIPPER DOES (FALSE)?
DeleteWavFile = FALSE
; What char would be used to replace forbiden chars?
CorrectionChar = _
; EXPLANATION
; EXECUTEIF  = MAREO evaluates the formula, and if true, MAREO executes this "encoder order".
;              It could be TRUE (executes), LASTTRACK (it reads mareoLAST.txt and evaluates agains current track number,
;              or XXX = YYY, in this last case MAREO evaluates the equality, for example, [TRACK]. = [1]
;              Assuming that in [1] MAREO is getting the last track number from the ripper, and that it is for example,
;              12, and that the current track number is 4, MAREO would evaluate 4 = 12, and not execute.
;              When track number is 12, MAREO would evaluate 12 = 12, and execute.
; FINALPATH  = the path to place the encoded file, example: C:\Music\[ARTIST] - [ALBUM]
; FINALNAME  = the name of the encoded file, example: [TRACKPADDED]. [TITLE]
; VFINALPATH = V.A. CDS: the path to place the encoded file, example: C:\Music\[ARTIST] - [ALBUM]
; VFINALNAME = V.A. CDS: the name of the encoded file, example: [TRACKPADDED]. [TITLE]
; EXTENSION  = the extension of the encoded file, example: mp3
; ENCODEREXE = the full file name of the encoder executable, including, if not in the same folder as MAREO, the full path (c:\encoders\lame.exe).
; PARAMETERS = the command line parameters we would normally pass to the encoder, as if we where running it from a command prompt.
; RENAME    = if TRUE, MAREO would rename as per the FINALPATH, FINALNAME and EXTENSION options.
; WAVEGAIN: Track Mode: used to "normalize" files: [url=http://www.rarewares.org/others.html]http://www.rarewares.org/others.html[/url]
; EXECUTEIF = TRUE
; FINALPATH = NONE
; FINALNAME = NONE
; VFINALPATH = NONE
; VFINALNAME = NONE
; EXTENSION = NONE
; ENCODEREXE = wavegain.exe
; PARAMETERS = --radio --apply --noclip "[SOURCE]"
; RENAME = FALSE
; LOSSY ENCODERS
; MP3 LAME: best MP3 encoder: [url=http://www.rarewares.org/mp3.html]http://www.rarewares.org/mp3.html[/url]
EXECUTEIF = TRUE
FINALPATH = [PERSONAL]\Music\[ARTIST] - [ALBUM]\
FINALNAME = [TRACKPADDED]. [TITLE]
VFINALPATH = [PERSONAL]\Music\VA - [ALBUM]\
VFINALNAME = [TRACKPADDED]. [TITLE] ([ARTIST])
EXTENSION = mp3
ENCODEREXE = lame.exe
PARAMETERS = -V5 --vbr-new --ignore-tag-errors --ta "[ARTIST]" --tl "[ALBUM]" --tt "[TITLE]" --tn "[TRACK]" --ty "[YEAR]" --tg "[GENRE]" "[SOURCE]" "[DESTTMP]"
RENAME = TRUE
; MP3gain: TRACK Mode: mp3 normalizer: [url=http://www.rarewares.org/mp3.html]http://www.rarewares.org/mp3.html[/url]
; EXECUTEIF = TRUE
; FINALPATH = [PERSONAL]\Music\[ARTIST] - [ALBUM]\
; FINALNAME = [TRACKPADDED]. [TITLE]
; VFINALPATH = [PERSONAL]\Music\VA - [ALBUM]\
; VFINALNAME = [TRACKPADDED]. [TITLE] ([ARTIST])
; EXTENSION = mp3
; ENCODEREXE = mp3gain.exe
; PARAMETERS = /k /r /s r "[FINALFULLNAME]"
; RENAME = FALSE
; MP3gain: ALBUM Mode: mp3 normalizer: [url=http://www.rarewares.org/mp3.html]http://www.rarewares.org/mp3.html[/url]
EXECUTEIF = LASTTRACK
EXTENSION = mp3
PARAMETERS = /k /a /s r [FINALPATHSHORT]\*.mp3
RENAME = FALSE
; OGG VORBIS: excelent and patent free encoder: [url=http://www.vorbis.com/]http://www.vorbis.com/[/url]
; RECOMMENDED VERSION: AoTuV 4.51b: [url=http://www.geocities.jp/aoyoume/aotuv/]http://www.geocities.jp/aoyoume/aotuv/[/url]
; EXECUTEIF = TRUE
; EXTENSION = ogg
; ENCODEREXE = oggenc.exe
; PARAMETERS = -q 4.25 "[SOURCE]" -o "[DESTTMP]" -a "[ARTIST]" -l "[ALBUM]" -t "[TITLE]" -N "[TRACK]" -d "[YEAR]" -G "[GENRE]"
; RENAME = TRUE
; AAC/MP4/3GPP Nero Digital Audio Audio Code[PERSONAL] [url=http://www.nero.com/nerodigital/eng/Nero_Digital_Audio.html]http://www.nero.com/nerodigital/eng/Nero_Digital_Audio.html[/url]
;              You can prepend any of the following options, under PARAMETERS, before the -if:
;                -q [number]  : "TARGET QUALITY" mode. [number] is a floating-point number in 0...1 range.
;                -br [number]  : "TARGET BITRATE" mode. [number] is target bitrate in bits per second.
;                -cbr [number] : "TARGET BITRATE (STREAMING)" mode. [number] is target bitrate in bits per second.
;              Recommended Options:
;                - Nero ABR (-br 128000)
;                - Nero 2-Pass (-br 128000 -2pass)
;                - Nero Quality VBR (-q 0.425)
;              Note: atm, the encoder does not supports tagging. You have to use NeroAacTag to do so.
; EXECUTEIF = TRUE
; EXTENSION = mp4
; ENCODEREXE = neroAacEnc.exe
; PARAMETERS = -q 0.425 -if "[SOURCE]" -of "[DESTTMP]"
; RENAME = TRUE
; Nero TAGGER for AAC/MP4.
; EXECUTEIF = TRUE
; EXTENSION = mp4
; ENCODEREXE = Neroaactag.exe
; PARAMETERS = "[FINALFULLNAME]" -meta:artist="[ARTIST]" -meta:album="[ALBUM]" -meta:title="[TITLE]" -meta:track="[TRACK]" -meta:year="[YEAR]" -meta:genre="[GENRE]"
; RENAME = FALSE
; AtomicParsley TAGGER for AAC/MP4: [url=http://atomicparsley.sourceforge.net/]http://atomicparsley.sourceforge.net/[/url]
;                            NOTE: use 0.8, no 0.84, if 0.80+, change --writeBack for --overWrite
; EXECUTEIF = TRUE
; EXTENSION = mp4
; ENCODEREXE = AtomicParsley.exe
; PARAMETERS = "[FINALFULLNAME]" --artist "[ARTIST]" --album "[ALBUM]" --title "[TITLE]" --tracknum "[TRACK]" --year "[YEAR]" --genre "[GENRE]" --writeBack
; RENAME = FALSE
; Richard123's TG TAGGER for AAC/MP4: [url=http://users.rcn.com/rpritz/tgutf.zip]http://users.rcn.com/rpritz/tgutf.zip[/url]
;                              NOTE: on my sistem, it returns errorlevel 1 even if ok.
; EXECUTEIF = TRUE
; EXTENSION = mp4
; ENCODEREXE = tg.exe
; PARAMETERS = "[FINALFULLNAME]" --artist "[ARTIST]" --album "[ALBUM]" --title "[TITLE]" --track "[TRACK]" --year "[YEAR]" --genre "[GENRE]"
; RENAME = FALSE
; MPEG4ip's TAGGER for AAC/MP4: [url=http://rarewares.org/mp4.html]http://rarewares.org/mp4.html[/url]
;                        NOTE: at the moment, this doesn't works.
; EXECUTEIF = TRUE
; EXTENSION = mp4
; ENCODEREXE = mp4tags.exe
; PARAMETERS = "[FINALFULLNAME]" -artist "[ARTIST]" -album "[ALBUM]" -song "[TITLE]" -track "[TRACK]" -year "[YEAR]" -genre "[GENRE]"
; RENAME = FALSE
; AAC/MP4 iTunes (w/iTunesEncode): excelent AAC encoder: [url=http://www.rarewares.org/aac.html]http://www.rarewares.org/aac.html[/url]
; EXECUTEIF = TRUE
; EXTENSION = mp4
; ENCODEREXE = iTunesEncode.exe
; PARAMETERS = -d -a "[ARTIST]" -l "[ALBUM]" -n [TRACK]. -t "[TITLE]" -y "[YEAR]" -g "[GENRE]" -i "[SOURCE]" -o "[DESTTMP]"
; RENAME = TRUE
; AAC/MP4 QuickTime (w/Qutibacoas): [url=http://www.rarewares.org/mp4.html]http://www.rarewares.org/mp4.html[/url]
; EXECUTEIF = TRUE
; EXTENSION = mp4
; ENCODEREXE = qutibacoas.exe
; PARAMETERS = "PATH_TO_QUICKTIME\QuickTimePlayer.exe" "[SOURCE]" "[DESTTMP]"
; RENAME = TRUE
; AAC/MP4: Nero AAC VBR (w/NAACEnc): [url=http://www.rarewares.org/aac.html]http://www.rarewares.org/aac.html[/url]
; ******** NOTE, AAC/MP4/3GPP Nero Digital Audio Audio Codec, is the official NERO encoder now ********
; EXECUTEIF = TRUE
; EXTENSION = mp4
; ENCODEREXE = NAACEnc.exe
; PARAMETERS = -normal "[SOURCE]" "[DESTTMP]"
; RENAME = TRUE
; AAC/MP4: Nero AAC CBR (w/NAACEnc): [url=http://www.rarewares.org/aac.html]http://www.rarewares.org/aac.html[/url]
; EXECUTEIF = TRUE
; EXTENSION = mp4
; PARAMETERS = -cbr192 "[SOURCE]" "[DESTTMP]"
; RENAME = TRUE
; MusePack (MPC): excelent low bitrates encoder: [url=http://www.musepack.net/]http://www.musepack.net/[/url]
; EXECUTEIF = TRUE
; EXTENSION = mpc
; ENCODEREXE = mppenc.exe
; PARAMETERS = --quality 4 --xlevel --artist "[ARTIST]" --album "[ALBUM]" --title "[TITLE]" --track "[TRACK]" --year "[YEAR]" --genre "[GENRE]" "[SOURCE]" "[DESTTMP]"
; RENAME = TRUE
; LOSSLESS ENCODERS
; FLAC: most supported lossless encoder: [url=http://flac.sourceforge.net/]http://flac.sourceforge.net/[/url]
EXECUTEIF = TRUE
EXTENSION = flac
ENCODEREXE = flac.exe
PARAMETERS = -5 "[SOURCE]" -o "[DESTTMP]" -T artist="[ARTIST]" -T album="[ALBUM]" -T title="[TITLE]" -T tracknumber="[TRACK]" -T date="[YEAR]" -T genre="[GENRE]"
RENAME = TRUE
; WavPack: excelent lossless encoder, with hybrid option: [url=http://www.wavpack.com/]http://www.wavpack.com/[/url]
; EXECUTEIF = TRUE
; EXTENSION = wv
; ENCODEREXE = wavpack.exe
; PARAMETERS = -hb192 "[SOURCE]" "[DESTTMP]"
; RENAME = TRUE
; TAK: Offers compression ratios comparable to Monkey's Audio with decoding speeds comparable to FLAC.
; EXECUTEIF = TRUE
; EXTENSION = tak
; ENCODEREXE = [OWNPATH]\takc.exe
; PARAMETERS = -e -pN "[SOURCE]" "[DESTTMP]"
; RENAME = TRUE
; Case's TAG (at least 2.0.49): [url=http://www.hydrogenaudio.org/forums/index.php?s=&showtopic=51565&view=findpost&p=461653]http://www.hydrogenaudio.org/forums/index....st&p=461653[/url]
; EXECUTEIF = TRUE
; EXTENSION = tak
; ENCODEREXE = tag.exe
; PARAMETERS = --artist "[ARTIST]" --album "[ALBUM]" --title "[TITLE]" --track "[TRACK]" --year "[YEAR]" --genre "[GENRE]" "[FINALFULLNAME]"
; RENAME = FALSE
; Monkeys Audio: lossless encoder: [url=http://www.monkeysaudio.com/]http://www.monkeysaudio.com/[/url]
; EXECUTEIF = TRUE
; EXTENSION = ape
; ENCODEREXE = mac.exe
; PARAMETERS = "[SOURCE]" "[DESTTMP]" -c4000
; RENAME = TRUE
; True Audio Software: [url=http://www.true-audio.com/codec.project]http://www.true-audio.com/codec.project[/url]
; EXECUTEIF = TRUE
; EXTENSION = tta
; ENCODEREXE = ttaenc.exe
; PARAMETERS =  -e -o "[DESTTMP]" "[SOURCE]"
; RENAME = TRUE
; LOSSLESS + LOSSY ENCODERS (Hybrid Encoders)
; WavPack HYBRID WITH CORRECTION FILE: [url=http://www.wavpack.com/]http://www.wavpack.com/[/url]
; ** NORMAL FILE**
; EXECUTEIF = TRUE
; EXTENSION = wv
; PARAMETERS = -hb192 -c "[SOURCE]" "[DESTTMP]"
; RENAME = TRUE
; ** CORRECTION FILE (RENAME ONLY) **
; EXECUTEIF = TRUE
; EXTENSION = wvc
; ENCODEREXE = NONE
; PARAMETERS = NONE
; RENAME = TRUE
; OptimFROG WITH CORRECTION FILE: [url=http://www.losslessaudio.org/]http://www.losslessaudio.org/[/url]
; ** NORMAL FILE**
; EXECUTEIF = TRUE
; EXTENSION = ofs
; ENCODEREXE = ofs.exe
; PARAMETERS = --correction "[SOURCE]"
; RENAME = TRUE
; EXECUTEIF = TRUE
; EXTENSION = ofc
; ENCODEREXE = NONE
; PARAMETERS = NONE
; RENAME = TRUE
; APEv2 TAGS (requires wapet.exe): [url=http://www.rarewares.org/others.html]http://www.rarewares.org/others.html[/url]
; GENERAL APEv2 TAGS (requires wapet.exe)
; XXX = extension of the encoder you are gonna use, for example ape for Monkey Audio.
; EXECUTEIF = TRUE
; EXTENSION = XXX
; ENCODEREXE = wapet.exe
; NOTE WAPET PARAMETERS: "[DESTTMP]" -t "Artist=[ARTIST]" -t "Album=[ALBUM]" -t "Title=[TITLE]" -t "Track=[TRACK]." -t "Year=[YEAR]" -t "Genre=[GENRE]"
; PARAMETERS = WAPET_PARAMETERS + ENCODER_PARAMETERS
; RENAME = TRUE
; Monkeys Audio with APEv2 TAGS (requires wapet.exe)
; EXECUTEIF = TRUE
; EXTENSION = ape
; PARAMETERS = "[DESTTMP]" -t "Artist=[ARTIST]" -t "Album=[ALBUM]" -t "Title=[TITLE]" -t "Track=[TRACK]." -t "Year=[YEAR]" -t "Genre=[GENRE]" mac.exe "[SOURCE]" "[DESTTMP]" -c4000
; RENAME = TRUE
; Musepack with APEv2 TAGS (requires wapet.exe)
; EXECUTEIF = TRUE
; EXTENSION = mpc
; PARAMETERS = "[DESTTMP]" -t "Artist=[ARTIST]" -t "Album=[ALBUM]" -t "Title=[TITLE]" -t "Track=[TRACK]." -t "Year=[YEAR]" -t "Genre=[GENRE]" mppenc.exe --quality 4 --xlevel "[SOURCE]" "[DESTTMP]"
; RENAME = TRUE
; EOF
Hopefully I don't have this this all set up TOO out of whack - but if need be I can go back and do a full re-install or reconfiguration. Hoping some of you experts can tell me just what I'm doing wrong here.
Thanks in advance for any advice you can offer.
walter
[!--sizeo:1--][span style=\"font-size:8pt;line-height:100%\"][!--/sizeo--]Moderation: Formatting.[/size]
EAC Options (F9) -> Extraction tab -> Skip extraction on read or sync errors: uncheck
Thanks greynol - I unchecked the Skip extraction on read or sync errors box and tried to re-rip the CD, but I'm getting still the exact same error messages.
Walter K
Are you telling EAC to hide the DOS box? if so, you had to tell mareo not to print to screen iirc.
If you want MAREO NOT to log to the screen, create a file called: MAREO.EXE.NOSCREENLOG and place it on the same place where MAREO.EXE is.
If you want MAREO NOT to log to a log file, create a file called: MAREO.EXE.NOFILELOG and place it on the same place where MAREO.EXE is.
Kwanbis -
I don't recall any configuration setting for EAC wherein I would have instructed EAC to hide the DOS box. I'd like to have the log file, and I have not problem with MAREO logging to the screen, unless doing so is creating a conflict with the EAC settings.
Walter
