I tried to retrieve my playlist which contains 34347 songs but only 5000 were retrieved. Is there some firewall settings I need to adjust?
[12:41:54] foo_upnp: 30.040: FbMediaServer::OnAction(254)/864: INFO: received action 'Browse', args = { ObjectID=0/0/0, BrowseFlag=BrowseDirectChildren, Filter=*, StartingIndex=4900, RequestedCount=50, SortCriteria= }
[12:41:54] foo_upnp: 30.040: PLT_MediaServer::OnBrowse(380)/864: INFO: Received BrowseDirectChildren from 1.2.3.4.5 for id = 0/0/0 with filter = *, start = 4900, count = 50
[12:41:54] foo_upnp: 30.041: upnp_server_conf::get_profile(726)/864: INFO: using default profile (User-Agent:Platinum/0.5.4.0, DLNADOC/1.50 / foobar2000)
[12:41:54] foo_upnp: 30.058: FbMediaServer::OnAction(271)/864: INFO: action 'Browse' response: args = { ObjectID=0/0/0, BrowseFlag=BrowseDirectChildren, Filter=*, StartingIndex=4900, RequestedCount=50, SortCriteria=, NumberReturned=50, TotalMatches=34347, UpdateID=0 }
[12:41:54] foo_upnp: 30.082: FbMediaServer::ProcessHttpRequest(317)/5340: INFO: received WAN request: http://1.2.3.4.5:56923/ContentDirectory/bade1451-dba8-955a-f882-451c97920316/control.xml (User-Agent: Platinum/0.5.4.0, DLNADOC/1.50 / foobar2000)
[12:41:54] foo_upnp: 30.082: FbMediaServer::OnAction(254)/5340: INFO: received action 'Browse', args = { ObjectID=0/0/0, BrowseFlag=BrowseDirectChildren, Filter=*, StartingIndex=4950, RequestedCount=50, SortCriteria= }
[12:41:54] foo_upnp: 30.082: PLT_MediaServer::OnBrowse(380)/5340: INFO: Received BrowseDirectChildren from 1.2.3.4.5 for id = 0/0/0 with filter = *, start = 4950, count = 50
[12:41:54] foo_upnp: 30.083: upnp_server_conf::get_profile(726)/5340: INFO: using default profile (User-Agent:Platinum/0.5.4.0, DLNADOC/1.50 / foobar2000)
[12:41:54] foo_upnp: 30.098: FbMediaServer::OnAction(271)/5340: INFO: action 'Browse' response: args = { ObjectID=0/0/0, BrowseFlag=BrowseDirectChildren, Filter=*, StartingIndex=4950, RequestedCount=50, SortCriteria=, NumberReturned=50, TotalMatches=34347, UpdateID=0 }
[12:41:55] foo_upnp: 31.118: PLT_HttpTcpConnector::Connect(86)/3404: FATAL: NPT_CHECK failed, result=-20402 (NPT_ERROR_CONNECTION_REFUSED) [(m_Socket->Connect(socket_address, connection_timeout))]
EDIT: Additional details:
Windows 7 Ultimate x64
UDP Timeout - 600s
TCP Timeout - 86400s
Windows firewall OFF
Not using foobar's Media Library feature - just playlists
Streaming profile left on default
Playlists contains many different filetypes (mostly MP3s)
LAME not installed.
2nd EDIT:
I tried on the playlist at work which has 5810 songs and it was able to eventually load. I should also mention that I'm only trying to connect to the PC that I'm currently on for testing and configuring but through my public IP.
