Topic: Kameleon by Br3tt (Read 341386 times) previous topic - next topic
0 Members and 6 Guests are viewing this topic.
Kameleon by Br3tt
Reply #175
hi falstaff, first: the best foobar config ever....thanks
a litte qestion: is it possible to make the path to the artist pics relative (by using foobar as portable app)?
thanks
frank
just try, it should work
i tried in extended variables: kameleon_artistart_path = %FOOBAR_PATH%/artists
but it doesn't work!
just enter :
./artists/
Kameleon by Br3tt
Reply #176
thanks
frank
just enter :
./artists/
it works!
falstaff = foobar king
another question:
i use multivalue field for artist (for example: "elton john; george michael")
if i have a pic in artist pic "elton john, george michael.jpg" it will be display....
but if i have only a photo by "elton john.jpg", can i display "elton john.jpg" when "elton john; george micheal" is playing?
in my old panels ui config with album art panel with this source worked fine: "Artists/$substr(%artist%,0,$sub($strrchr(%artist%,','),1) ).jpg", but that doesn't work in extended variables...
any idea???
thanks frank
Kameleon by Br3tt
Reply #178
I am planning to switch to Vista over the weekend are all plugins compatible with Vista?
Kameleon by Br3tt
Reply #180
OK, i have re-coded the CD Case panel, now it must work for everyone
http://br3tt.online.fr/files/K/kameleon_1.0c2.fcl
test it and gimme feedback please
I appreciate your hard work, really, but I noticed this bug two times again.
Maybe it is not a code problem ? maybe foobar versions or operating systems, some components maybe... you know it much better I think
If you have any suggestions about components etc. incompatibility I would offer to everyone, who has this bug, show version of comp. etc., if needed of course, maybe we will find some regularity.
Anyway, this bug don`t make me inconvenience anymore, because it appear very rarely.
very very very weird, maybe a Vista issue with Panel Stack Splitter, i'm under XP P3, and it never happens.
i really think that is a Vista problem with PSS, coz all people that have reported this to me are under Vista ... is someone with this bug under XP ?
If you don't use foo_exvar for cover art (because file already named folder.jpg and are stored in music folder), try to enter this and see if it fix the problem (maybe ...) :
kameleon_coverart_path = default
Kameleon by Br3tt
Reply #181
After some tries, I can say that it still happens. I'm running Vista SP1, foobar 0.9.6.3 beta 1, and Kameleon 1.0c2.
It doesn't happen everytime though, I have to restart foobar a couple of time before seeing the effect.
Kameleon by Br3tt
Reply #182
Entering:
kameleon_coverart_fil
This still allows the bug to happen. It occurs about once every 10 or 15 foobar restarts and is fairly random.
Kameleon by Br3tt
Reply #183
All of the plugins I listed here
http://www.hydrogenaudio.org/forums/index....st&p=615937
are the latest as of 2/17/2009 and work perfectly under Windows Vista.
The ones provided by Br3tt are also compatible, except foo_skip.dll in an early revision of Kameleon, which should have been replaced by http://www.saunalahti.fi/~cse/foobar2000/foo_skip.zip by now.
Kameleon by Br3tt
Reply #184
Bug still there.
Just wanna show you some details:
Small arrows in first pictures are missing (red ovals)
Jewel case seem to be smaller in first picture and drifted to left.
Hope that helps.
I'm using Vista SP1 too.
Kameleon by Br3tt
Reply #185
The same happens with my bug. In fact, the jewel cases shift identically, and the covers contract just the same. So, while the bug is random, the effects are pretty predictable, which might lead to some way to fix it. Who knows?
Kameleon by Br3tt
Reply #186
This post may have gotten lost in the shuffle of sorting out the album art scaling issue, so here goes again... any help is much appreciated!
  • Quick question on Chronflow - is there any way to get it to display the first JPG it finds in an album folder to use for album artwork, i.e. *.jpg? I have this working well for all other album art splitters in Kameleon except Chronflow... if anyone knows how to get this working it would make my day!
  • Also, I recently installed the foo_discogs component and am having trouble downloading artist/album artwork. When I use the context menu on a track or album, the "Update Album/Artist Art" command is always grayed out... in the foo_discogs Configuration > Album/artist art tab, I have "Fetch" checked for both Album & Artist artwork, as well as "Fetch all available art" yet no artwork is being downloaded. I have tried using the "Write tags" command (the only one not grayed out besides "Configure tag mappings" and "configuration") and the album artwork is indeed present in the preview page - I just don't see how to download it to the album folder! What am I missing? Any help is much appreciated - thanks again!
  • Does anyone have a favorite Album Art Downloader? I have been using Album Art Downloader XUI v0.24 which seems to work great, but is there something even better out there (preferably a Foobar component so I can download art while listening to an album)?
Kameleon by Br3tt
Reply #187
Hi Br3tt !
I think, one of a solution  would be replacing cd cover code from Curacao config, because I have never seen this liitle bug in Curacao before.
I guess it is not so important to see cover inside of CD case or without this one  The special version for Vista users f.e..... before you self will return to Vista
To Lonk NY
# Quick question on Chronflow - is there any way to get it to display the first JPG it finds in an album folder to use for album artwork, i.e. *.jpg? I have this working well for all other album art splitters in Kameleon except Chronflow... if anyone knows how to get this working it would make my day!
It is impossible as I know, you can only add variables like
... and any possible names of covers you have
The simpliest  way is using constant name of covers or use programs for grouping file rename if you have so huge music collection.
it doesn`t exist. as far as I know again
By the way, I use Album Art Downloader too with script which automatically saves cover art files into album/artist folder with name "folder.jpg" and problem of Chronflow you are talked above is solved.
Kameleon by Br3tt
Reply #188
You are wrong here.
The possible option is CD Art Display, except latest beta is buggy for me. it is standalone, but integrates into foobar via component.
Kameleon by Br3tt
Reply #189
Got serious Problems here:
When a Song got a "timestamp" like:
<FIRST_PLAYED> : 2009-02-18 12:25:55
<LAST_PLAYED> : 2009-02-18 12:25:55
<PLAY_COUNTER> : 1
<PLAY_STAMP> : 2009-02-18 12:25:55
The "title"-info will promptlydisappear. While playing a song the first time, this happens even within listening to it.
What should i do? Remove play_counter?
Kameleon by Br3tt
Reply #190
Falstaff
good job, amazing config
it possible, make album art bigger? (like in curacao)
Kameleon by Br3tt
Reply #192
<PLAY_COUNTER> : 1
which components are you using to save stats ?
- Playback Custom Statistics or Play counter (official stats plugin)
PCS store stats info in the music file TAGs
PC store them in a database and do not affect the music file
go to Prefs --> Tools ---> ...
and be sure you have set them the way you want
Kameleon by Br3tt
Reply #193
Falstaff
thank you, sorry for silly question
Kameleon by Br3tt
Reply #194
My foobar is black!
[a href="http://img179.imageshack.us/my.php?image=f2kug0.jpg" target="_blank"]
Kameleon by Br3tt
Reply #195
Would it be possible to jump to the default playlist/or previous by clicking the Kameleon button?
Because i think it would be more usefull than resizing f2k!
Kameleon by Br3tt
Reply #196
This scaling bug is still happening with FLC 1.0c. No idea what is triggering it.
test it and gimme feedback please[/b][/size][/color]
OK, new try that might fix the bug on Vista or Seven systems ...
http://br3tt.online.fr/files/K/kameleon_1.0c5.fcl
test it and gimme feedback please, ty
Kameleon by Br3tt
Reply #197
Ok, I couldn't wait any longer, so I added Playlist switcher and Album list to the left panel myself. It works the same as in Curacao, without covering parts of ELPlaylist.
Br3tt, if you are interested, I could send it to you and you could incorporate it in further versions.
Kameleon by Br3tt
Reply #198
I'm really happy because that was the only thing about Kameleon that I didn't like. Now it's perfect
I'm interested in that, I too found the new playlist switcher a bit...well... a bit too big. Mind sharing with us exxecutor?
Kameleon by Br3tt
Reply #199
Can someone please tell me how i can sort a playlist by track and not by album? I have a playlist with radio streaming locations and it gets very ugly with this type of sorting.
OFF TOPIC, ELPlaylist topic recommended for this. btw here is some help :
right click ion ELPlaylist -> Settings
then
1.modify the default group by order and/or the default sort order
OR
2.add an alternative sort order that you can use by right click contect menu
