Topic: Kameleon by Br3tt (Read 341417 times) previous topic - next topic
Kameleon by Br3tt
Reply #150
Is it really that much of a problem to click one more time?
Playlist switcher in the left panel would be a better treat :x
You mean the whole playlist/quicksearch panel? I guess that would significantly streamline usage for people that navigate through their library that way. =) Let's hope our lobbying does not fall on deaf ears. Br3tt's got a lot of requests, though...We'll see.
Kameleon by Br3tt
Reply #151
All,
Maybe it's just me and this is REAL basic... Doesn't apply to Br3tt specifically...
When I go back into tag and rename after playing songs my tags are all messed up.
How do you use the "play count" and "ratings" without foobar messing up your tags? I find myself disabling these things because it wipes out hours of hard work.  Do you folks edit the way your tags are updated within foobar? Thoughts?
Thanks, Casey
Kameleon by Br3tt
Reply #152
This scaling bug is still happening with FLC 1.0c. No idea what is triggering it.
That is mostly caused by some dll files. You can try to delete all your dll files and just use the components given by Br3tt.
Kameleon by Br3tt
Reply #153
Amazing config - thanks!!
Quick question on Chronflow - is there any way to get it to display the first JPG it finds in an album folder to use for album artwork, i.e. *.jpg? I have this working well for all other album art splitters except Chronflow... if anyone knows how to get this working it would make my day!
Also, I recently installed the foo_discogs component and am having trouble downloading artist/album artwork. When I use the context menu on a track or album, the "Update Album/Artist Art" command is always grayed out... in the foo_discogs Configuration > Album/artist art tab, I have "Fetch" checked for both Album & Artist artwork, as well as "Fetch all available art" yet no artwork is being downloaded. I have tried using the "Write tags" command (the only one not grayed out besides "Configure tag mappings" and "configuration") and the album artwork is indeed present in the preview page - I just have no way to download it to the album folder! What am I missing? Any help is much appreciated - thanks again!
Kameleon by Br3tt
Reply #154
Not sure if this helps - but it seems that once I added the Artist Artwork variables to Extended Variables, I started experiencing this same scaling issue w/Album artwork in the main lefthand splitter. I added these 2 lines to Extended Variables:
kameleon_artistart_path - N:/Music/---- Artist Art ----/
Restarted foobar and while the Artist Artwork now worked fine, the album artwork had the scaling issue several people have previously mentioned. So I removed these 2 lines from exvar, restarted foobar, and the issue went away... hope this helps in some way to track down the issue.
Kameleon by Br3tt
Reply #155
2 pages back i asked
For example. if an artist name contains a / , let's say Ac/dc then i use this variable to search for the cover
How can I convert my ibiza/curacao line to work with kameleon?
C:\Program Files\foobar2000\covers\$replace(%artist%,/,,?,,) - %album%.jpg
it worked in Curaçao, but then again, extended variable wasn't in use then...... can i in some way, get this to work in kameleon
anyone who can figure this out . is it possible to somehow make it compatible with extended variables
Kameleon by Br3tt
Reply #156
look at this
For the last time, functions do not work with foo_exvar, learn to tag you %artist% tags to be free of this or find a better way to store artists pics... the best is a unique folder that contains all the artists images named %artist%.jpg (ex: Jimi Hendrix.jpg, ... ). Other way, modify the code in K to bypass foo_exvar uses...
Kameleon by Br3tt
Reply #157
nice config really! I finally decided to change my old one, as it is based on panels ui, and new foobar versions have so many tasty features
Now I'm trying to figure out all those new plugins, have some troubles
1. Where is chronoflow part in Kameleon? I removed it, and it seems ok... (it annoyed me with error message on the start, and do not have priviledges to update graphics card drivers).
2. Can I have 3 configs (Kameleon, Curacao and Ibiza) simultaneously and switch them on-the-fly in Preferences? Now when I import a config, all others disappear
3. Besides, I have noticed a strange glitch:
The now playing text is too large (I had to reduce it from 19 to 6!). It might be due to 120DPI settings for my computer, however, I hope it helps someone.
Again, nice config, thanks!
Kameleon by Br3tt
Reply #158
Seems like you don`t have "snapix" font installed
Kameleon by Br3tt
Reply #160
I guess we're in the same boat.  I wrote about it on page 2. Well, the thread is growing really fast!
I tried to do something myself, but the code for this is a lot more complex than in earlier configs. All those panels are closely connected to each other, to ELPlaylist and even some kind of check is performed. Anyway, a lot of code would have to be re-written. If you have the time, Br3tt... I would appreciate it
Kameleon by Br3tt
Reply #162
hi falstaff, first: the best foobar config ever....thanks
a litte qestion: is it possible to make the path to the artist pics relative (by using foobar as portable app)?
thanks
frank
Kameleon by Br3tt
Reply #163
is it normal that all visualisations stop when you scroll through the ELP-Panel?
They stutter with an intel Q9450. Processor timings go up significantly when you scroll through that panel.
lol!
i have a E6850 with 3.00 Ghz and foobar takes 50% when i scroll through the list!
I think i have found a new Benchmark for my PC!
And it takes 120 mb ram!
That really SUX!
But the Problem is:
The design kicks asses  so i will stick to this config! (or i will by a new Intel Processor only for foobar!)
Kameleon by Br3tt
Reply #164
Still happening on about 1 out of 15 restarts with 1.0c2.
But, RAM memory usage went down about 10-15mb, and I was pleased about that.
Note: I do not use exvars for my album art.
Vista 32-Bit
Component List:
    foobar2000 core 0.9.6.2
    ABX Comparator 1.3.3
    Album List 4.3
    CD Audio Decoder 2.1.4
    Chronial's Coverflow 0.3.0
    Converter 1.2
    Convolver 0.3
    Noise Sharpening DSP 1.0.0
    Standard DSP Array 1.0
    Tube Sound 0.8
    Extended Variables 0.3.1
    File Operations 2.1.1
    freedb Tagger 0.6.1
    Standard Input Array 1.0
    Last.fm Radio 0.5.2
    Masstagger 1.7.1
    Menu Addons 0.4.1 (SSE)
    ASIO support 1.2.6
    Kernel Streaming Output 1.2.2
    Playback Statistics Custom 1.4.3
    Playback Statistics 2.1.6
    Playback Queue Viewer 0.2
    ReplayGain Scanner 2.0.8
    Run services 0.3.4
    Run Command 1.0 beta 3
    Skip Track 0.4
    Columns UI 0.3.6.5
    Default User Interface 0.9.5
    Album list panel 0.2.2
    ELPlaylist 0.6.4.2(beta)
    Graphical Browser rev015
    Lyric Show Panel 0.3.3.9 [Dec 12 2008 - 17:39:01]
    Panel Stack Splitter 0.3.6.2(alpha)
    Quick Search Toolbar 2.8|
    Track info panel mod 0.8.0 beta [Jan  5 2007 - 13:36:12]
    Channel Spectrum panel 0.17.2
    WSH Panel (uie) 0.7.2
    RAR reader 1.1
    ZIP/GZIP reader 1.0
    Playlist Tools 0.6.2 beta 6
    Shpeck - Winamp vis plugins wrapper 0.3.1
Kameleon by Br3tt
Reply #165
OK, i have re-coded the CD Case panel, now it must work for everyone
http://br3tt.online.fr/files/K/kameleon_1.0c2.fcl
test it and gimme feedback please
I appreciate your hard work, really, but I noticed this bug two times again.
Maybe it is not a code problem ? maybe foobar versions or operating systems, some components maybe... you know it much better I think
If you have any suggestions about components etc. incompatibility I would offer to everyone, who has this bug, show version of comp. etc., if needed of course, maybe we will find some regularity.
Anyway, this bug don`t make me inconvenience anymore, because it appear very rarely.
Kameleon by Br3tt
Reply #166
lol!
That really SUX!
But the Problem is:
problem is elsewhere, i have the same CPU and when no scroll, i'm under 2%, when scrolling, near 20%
about memory usage, it depends of the playlist size and library size. HERE, i'm near 65000 Kb with a library ~28000 tracks
Kameleon by Br3tt
Reply #168
very very very weird, maybe a Vista issue with Panel Stack Splitter, i'm under XP P3, and it never happens.
Kameleon by Br3tt
Reply #169
Hey, Br3tt! I'm not one for nitpicking, and this is not a behavior I really care about, but the interface moves down about 1 pixel when I click the aliencat.
Below are screenshots:
For an easier comparison, just click the aliencat button really fast =).
Kameleon by Br3tt
Reply #170
How annoying, it never once cropped up during Beta testing but I am XP SP3 too, although I was also running it on Windows 7 on and off with no problems
Kameleon by Br3tt
Reply #171
Hey, Br3tt! I'm not one for nitpicking, and this is not a bug I really care about, but the interface moves down about 1 pixel when I click the aliencat.
Kameleon by Br3tt
Reply #172
Can someone please tell me how i can sort a playlist by track and not by album? I have a playlist with radio streaming locations and it gets very ugly with this type of sorting.
Someone please help me...
Kameleon by Br3tt
Reply #173
thanks
frank
just try, it should work
i tried in extended variables: kameleon_artistart_path = %FOOBAR_PATH%/artists
but it doesn't work!
