Topic: Disc number in vorbis tags? (Read 8994 times) previous topic - next topic
I'm using MP3tag to do this and it works but winamp doesn't display the disc number. I don't know why they don't show up in winamp but if they show up in mp3tag, will they show up in other media players with disc information?
The current de facto standard for writing disc number into Vorbis files is to use the DISCNUMBER tag. (In some programs it's customary to write tag names in uppercase, so bear with me, please.)
Winamp's Vorbis plugin should have a feature where you can adjust the title formatting in your playlist.
Adding %discnumber% somewhere to your "formatting strings" should add the contents of your DISCNUMBER tag to your playlist display.
If you don't want question marks showing up with songs that don't have that tag, then you can add [blah %discnumber% this part will only be shown if the DISCNUMBER tag exists on the file] or something similar.
DISCNUMBER is the most used one, but there are also (also widely used):
DISCC
DISCCOUNT
DISC
The situation is a right mess...
The drawback of »open specs« — If you allow the users to do anything, they will. And users are much more creative than developers … ;-)
In Vorbis Comment Tags, these are (more or less) usual (»n« shall denote the disc #, »x« the total number of discs in a set):
  • DISC=n
  • DISCNUMBER=n
  • DISCNUMBER=n/x
  • DISC #=n (J. River — just why do they always have to complicate things?)
  • DISCC=x
  • DISCTOTAL=x
  • TOTALDISCS=x (dBpoweramp uses this)
I have even seen all of the above spelled with a »K« instead of »C« in the word »DISC«, but we can probably just disregard these …
Moonbase: The Problem Solver (use link in profile)
dBpoweramp uses DISCNUMBER=n and TOTALDISCS=x, because there is a 'standard' of TRACKNUMBER=n and TOTALTRACKS=x
I haven't seen that before. Hilarious though! I mean, a hash!?
I've always agreed with this.
