Topic: RC3 Decoder - Where is it? (Read 5498 times) previous topic - next topic
Is it just me? I can't find the RC3 decoder anywhere...
For Windows, there is no command line decoder.
If you really want one, you can compile decoder_example I think.
GCP
Why not? It seems like a natural thing.
There should be a --decode option in oggenc.
Seems very natural to me too.
I really want a Win32 Ogg console decoder! Who can make it?
It's not natural to have the _encoder_ _decode_
GCP
it would be nice to have an oggdec or something similar... I'd use it with oggifier.  Right now I use either cdex or dBpowerAMP to decode ogg samples; I can encode with oggdrop or use various front-ends for oggenc (oggifier, eac, cdex).
God kills a kitten every time you encode with CBR 320
GCP
Hi Garf,
I found decoder_example in the libvorbis source code. But it says:  "Takes a vorbis bitstream from stdin and writes raw stereo PCM to stdout.  Decodes simple and chained OggVorbis files from beginning to end.  Vorbisfile.a is somewhat more complex than the code below."
I suppose the decoded files will not be WAV files then?
I did compile the example decoder and it will take in an ogg file and write a wav, but without a wave header. I didn't look any further at the time. You get it to take in a file and write out a file by using the < and > for input and output, eg:
oggdec < sample.ogg > sample.wav
If people are interested, I'll look at it again. I didn't bother too much 'cos it's too easy to do it thru Winamp, either directly, or using the Winamp plugin thru CDex.
john33
I would be interested because I could then make a decode button on the Oggifier frontend. But I suppose you would need some external code that writes wav headers. That won't be easy I think.
libsndfile, maybe?
Finding the wave writing routines there could be useful.
I still need an RC3 decoder for Win32. Does anyone have a RC2 decoder for Win32 they would be willing to share?
John33 is still working on decoding support for Oggdrop.
I believe he will have something beta soon.
