Topic: Curaçao by Br3tt (Read 341649 times) previous topic - next topic
Curaçao by Br3tt
Reply #425
hidding titlebar not possible in ColumnsUI interface like Curacao (only PUI allow that)
btw an extenal program (autohotkey with an adapted script) that lauch foobar can do the job but not very practical because without the title bar, no way to move the foobar window
Curaçao by Br3tt
Reply #426
@rolf1955 many programs can do it (O&O defrag, Photoshop... many cannot -Opera browser -YET).  as a workaround try mine
 %artist% - %title% - %_time_elapsed% / %length%                        $info(tool) <> $info(bitrate)/%bitrate% <>  %_foobar2000_version%  %replaygain_track_gain%
Curaçao by Br3tt
Reply #427
Hey,
nice to talk with the master himself, aren´t you ... ;+)
First thanx for reply - i have a solution for moving foobar without titlebar --> with "Advanced Controls" ( http://www.niversoft.com/products/fac ) you can hide or show foobar - and ( at least at my last conif I had - "FofR config" - similar to Br3tt Curacao -->  http://www.fooblog2000.com/category/config ) wich was working with PUI, position move was possibe by moving the dash panel.
Curaçao by Br3tt
Reply #430
Hey,
Here - that´s what Italkin about:
http://img165.imageshack.us/img165/1619/grabitthereko9.jpg
Grab it at the dashboard to move the player.
i see that you have not tested yet (lol), the zone that you indicate as 'dash board' is no more a anchor because it's a PSS panel. The only way to move a window is to use the titlebar area.
try this : http://br3tt.free.fr/files/foobarrun.7z
extract the 2 files in the foobar2000 folder, then launch foobar with the fobarrun executable, you'll see that there is no dragable area.
Curaçao by Br3tt
Reply #431
[/quote]
[/quote]
Thank you !!
well - interesting. It´s a nice view now, but no real way to move, right! ...but so it´s may be possible to use the player as a kind of desktop-player, you know - instead the wallpaper. Not also so bad....
But - of course - it´s a little pitty - theres nearly no way to move it anymore - but one circumstantially:
you can fit the size on the edges and so you "can manoeuvre" the window across your screen.
Curaçao by Br3tt
Reply #432
focus window, ALT+SPACE / MOVE / ENTER, them vove with arraw keys, or after first move with an arrow key it moves by following the mouse
Curaçao by Br3tt
Reply #433
Hey - cool !
funny thing you freak !!
thanx !!
Curaçao by Br3tt
Reply #434
yep, thanx for the tips! never try the arrow keys to move
notes that after a arrow keypress, then mouse's move works
Curaçao by Br3tt
Reply #435
I'm trying to get this to work with a portable version of foobar2000 (not installed in C:\program files\foobar2000).  Does anyone have any tips on how I can make this work, without having installed in the default directory?
Curaçao by Br3tt
Reply #436
nevermind
Curaçao by Br3tt
Reply #437
I've been getting some fatal errors when I try to start foobar recently (with Curaco installed). It was doing fine for awhile, but now just about every time I shut my computer down and start it up again a different time, foobar fatals 2 or 3 times before it will actually load. It has done this with both Br3tt's Curaco version and the tweaked version now. I saved a few copies of the error reports that are created in Notepad when it fatals, so hopefully they will help in solving this problem.
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 01599BF9h
Access violation, operation: read, address: 01826000h
Call path:
entry
Code bytes (01599BF9h):
01599BB9h:  C7 8D 73 1C 8D 50 02 66 8B 08 83 C0 02 66 85 C9
01599BC9h:  75 F5 2B C2 D1 F8 50 8B C7 E8 D9 7A FF FF 8B 5B
01599BD9h:  30 8D 3C 5F 33 C9 66 3B 0F 75 1A 8B 54 24 10 8B
01599BE9h:  44 24 20 03 C2 8B FF 3B F8 73 0A 83 C7 02 33 C9
01599BF9h:  66 3B 0F 74 F2 8B 54 24 14 8B 4A 0C 85 C9 75 04
01599C09h:  33 C0 EB 08 8B 42 14 2B C1 C1 F8 03 8B 5A 10 8B
01599C19h:  D3 2B D1 C1 FA 03 3B D0 73 2E C6 44 24 1C 00 8B
01599C29h:  44 24 1C 8B 4C 24 1C 50 51 8D 74 24 30 BA 01 00
Stack (0012F188h):
0012F168h:  00EADCDC 7C9C94F8 77F643DD 7C9C94F8
0012F178h:  00000004 00000000 00EAD1E8 00000000
0012F188h:  0012F308 01825350 00000000 0012F308
0012F198h:  000001C8 015E1458 01824540 0012F200
0012F1A8h:  01825E38 000001C8 01824540 01824610
0012F1B8h:  0049DFB1 0012F218 00000004 0012F22C
0012F1C8h:  015CF690 00000001 01825350 0012F238
0012F1D8h:  015B11D8 0012F204 000001CC 0012F328
0012F1E8h:  00000BFC 01F7660F 0012F358 AA81D745
0012F1F8h:  43A64C62 6920FEAD 39481087 015D7F54
0012F208h:  0012F308 00000000 00000000 015E04CC
0012F218h:  000001CC 00000000 01824F28 013C8A20
0012F228h:  0012F1E8 0012F2DC 015CF11A 00000001
0012F238h:  0012F2E8 015BA70F 0012F308 0012F328
0012F248h:  0041AB95 0012F308 0012F328 0012FD70
0012F258h:  004E72D4 0000027C 0012F2A0 7C90E900
0012F268h:  7C910040 FFFFFFFF 0001003D 0000000D
0012F278h:  0012F1D4 0012F1D8 0012F2C0 7C90E900
0012F288h:  7C910040 FFFFFFFF 7C91003D 01312F55
0012F298h:  01390000 00000000 01312F74 1C299799
Registers:
EAX: 01826000, EBX: 00000041, ECX: 00000000, EDX: 000001C8
ESI: 0182455C, EDI: 01826000, EBP: 0012F1D4, ESP: 0012F188
Crash location: "foo_uie_lyrics", loaded at 01590000h - 015EC000h
Loaded modules:
foobar2000   loaded at 00400000h - 00539000h
ntdll loaded at 7C900000h - 7C9AF000h
kernel32 loaded at 7C800000h - 7C8F6000h
COMCTL32 loaded at 773D0000h - 774D3000h
msvcrt   loaded at 77C10000h - 77C68000h
ADVAPI32 loaded at 77DD0000h - 77E6B000h
RPCRT4   loaded at 77E70000h - 77F02000h
Secur32   loaded at 77FE0000h - 77FF1000h
GDI32 loaded at 77F10000h - 77F59000h
USER32   loaded at 7E410000h - 7E4A1000h
SHLWAPI   loaded at 77F60000h - 77FD6000h
SHELL32   loaded at 7C9C0000h - 7D1D7000h
ole32 loaded at 774E0000h - 7761D000h
shared   loaded at 10000000h - 1002A000h
UxTheme   loaded at 5AD70000h - 5ADA8000h
COMDLG32 loaded at 763B0000h - 763F9000h
IMM32 loaded at 76390000h - 763AD000h
LgWndHk   loaded at 003D0000h - 003D7000h
MSCTF loaded at 74720000h - 7476C000h
msctfime loaded at 755C0000h - 755EE000h
foo_lyricsgrabber loaded at 00AB0000h - 00B04000h
WS2_32   loaded at 71AB0000h - 71AC7000h
WS2HELP   loaded at 71AA0000h - 71AA8000h
WINMM loaded at 76B40000h - 76B6D000h
foo_menu_addons   loaded at 00BF0000h - 00C4D000h
libmmd   loaded at 00C60000h - 00F11000h
MSVCR80   loaded at 78130000h - 781CB000h
foo_uie_panel_splitter   loaded at 00F40000h - 00F8F000h
gdiplus   loaded at 4EC50000h - 4EDF6000h
foo_ui_columns   loaded at 00FC0000h - 010F2000h
foo_playback_custom   loaded at 01120000h - 01165000h
WINSPOOL loaded at 73000000h - 73026000h
OLEAUT32 loaded at 77120000h - 771AB000h
foo_uie_vis_channel_spectrum loaded at 011B0000h - 011ED000h
MSIMG32   loaded at 76380000h - 76385000h
foo_albumlist loaded at 01210000h - 0127B000h
foo_ui_std   loaded at 012A0000h - 01374000h
foo_uie_trackinfo_mod loaded at 013A0000h - 013F6000h
MSVCP80   loaded at 7C420000h - 7C4A7000h
foo_uie_wsh_panel loaded at 01410000h - 0143F000h
foo_uie_lyrics   loaded at 01590000h - 015EC000h
WININET   loaded at 78050000h - 78120000h
Normaliz loaded at 01600000h - 01609000h
iertutil loaded at 78000000h - 78045000h
foo_input_std loaded at 01830000h - 0196C000h
foo_dsp_std   loaded at 01990000h - 019D8000h
foo_skip loaded at 01A00000h - 01A0C000h
MSVCR90   loaded at 78520000h - 785C3000h
foo_uie_graphical_browser loaded at 01A30000h - 01AC4000h
foo_uie_elplaylist   loaded at 01AE0000h - 01B47000h
foo_vis_shpeck   loaded at 01B70000h - 01B9A000h
foo_converter loaded at 01BB0000h - 01C1C000h
foo_masstag   loaded at 01C40000h - 01C83000h
foo_cdda loaded at 01CB0000h - 01CF1000h
foo_uie_albumlist loaded at 01D20000h - 01D5D000h
foo_uie_quicksearch   loaded at 01D80000h - 01DC6000h
foo_lastfm_radio loaded at 01DF0000h - 01E36000h
foo_rgscan   loaded at 01E60000h - 01EBB000h
foo_run   loaded at 01EE0000h - 01F0E000h
imagehlp loaded at 76C90000h - 76CB8000h
DBGHELP   loaded at 59A60000h - 59B01000h
VERSION   loaded at 77C00000h - 77C08000h
Stack dump analysis:
Address: 015E1458h, location: "foo_uie_lyrics", loaded at 01590000h - 015EC000h
Address: 0049DFB1h, location: "foobar2000", loaded at 00400000h - 00539000h
Address: 015CF690h, location: "foo_uie_lyrics", loaded at 01590000h - 015EC000h
Address: 015B11D8h, location: "foo_uie_lyrics", loaded at 01590000h - 015EC000h
Address: 015D7F54h, location: "foo_uie_lyrics", loaded at 01590000h - 015EC000h
Address: 015E04CCh, location: "foo_uie_lyrics", loaded at 01590000h - 015EC000h
Address: 013C8A20h, location: "foo_uie_trackinfo_mod", loaded at 013A0000h - 013F6000h
Address: 015CF11Ah, location: "foo_uie_lyrics", loaded at 01590000h - 015EC000h
Address: 015BA70Fh, location: "foo_uie_lyrics", loaded at 01590000h - 015EC000h
Address: 0041AB95h, location: "foobar2000", loaded at 00400000h - 00539000h
Address: 004E72D4h, location: "foobar2000", loaded at 00400000h - 00539000h
Address: 7C90E900h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "strchr" (+00000113h)
Address: 7C910040h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlFreeHeap" (+00000133h)
Address: 7C91003Dh, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlFreeHeap" (+00000130h)
Address: 01312F55h, location: "foo_ui_std", loaded at 012A0000h - 01374000h
Address: 01312F74h, location: "foo_ui_std", loaded at 012A0000h - 01374000h
Address: 004E8CC4h, location: "foobar2000", loaded at 00400000h - 00539000h
Address: 004C622Bh, location: "foobar2000", loaded at 00400000h - 00539000h
Address: 01590000h, location: "foo_uie_lyrics", loaded at 01590000h - 015EC000h
Address: 015E01F4h, location: "foo_uie_lyrics", loaded at 01590000h - 015EC000h
Address: 004DC8A0h, location: "foobar2000", loaded at 00400000h - 00539000h
Address: 004DC378h, location: "foobar2000", loaded at 00400000h - 00539000h
Address: 00417F14h, location: "foobar2000", loaded at 00400000h - 00539000h
Address: 004D8D5Fh, location: "foobar2000", loaded at 00400000h - 00539000h
Address: 77E3BEC3h, location: "ADVAPI32", loaded at 77DD0000h - 77E6B000h
Address: 77C20621h, location: "msvcrt", loaded at 77C10000h - 77C68000h
Symbol: "wfullpath" (+00000093h)
Address: 00DF96B1h, location: "libmmd", loaded at 00C60000h - 00F11000h
Symbol: "_csqrtq_f90" (+00196D75h)
Address: 01A6DC95h, location: "foo_uie_graphical_browser", loaded at 01A30000h - 01AC4000h
Address: 01AE79B9h, location: "foo_uie_elplaylist", loaded at 01AE0000h - 01B47000h
Address: 7CB38959h, location: "SHELL32", loaded at 7C9C0000h - 7D1D7000h
Symbol: "Ordinal211" (+0000EF1Ah)
Address: 776067E8h, location: "ole32", loaded at 774E0000h - 7761D000h
Address: 00503200h, location: "foobar2000", loaded at 00400000h - 00539000h
Address: 004DD46Ch, location: "foobar2000", loaded at 00400000h - 00539000h
Address: 01000000h, location: "foo_ui_columns", loaded at 00FC0000h - 010F2000h
Address: 00503220h, location: "foobar2000", loaded at 00400000h - 00539000h
Address: 004C9090h, location: "foobar2000", loaded at 00400000h - 00539000h
Address: 00439CF0h, location: "foobar2000", loaded at 00400000h - 00539000h
Address: 004D8DECh, location: "foobar2000", loaded at 00400000h - 00539000h
Address: 00400000h, location: "foobar2000", loaded at 00400000h - 00539000h
Address: 7C9101C0h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlAllocateHeap" (+0000011Ch)
Address: 7C9101BBh, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlAllocateHeap" (+00000117h)
Address: 004B5983h, location: "foobar2000", loaded at 00400000h - 00539000h
Address: 004B0020h, location: "foobar2000", loaded at 00400000h - 00539000h
Address: 004B3DD8h, location: "foobar2000", loaded at 00400000h - 00539000h
Address: 1000258Fh, location: "shared", loaded at 10000000h - 1002A000h
Symbol: "uPrintCrashInfo_SetDumpPath" (+000000C8h)
Address: 004DF52Ch, location: "foobar2000", loaded at 00400000h - 00539000h
Address: 004CA1CAh, location: "foobar2000", loaded at 00400000h - 00539000h
Address: 0043A100h, location: "foobar2000", loaded at 00400000h - 00539000h
Address: 004AE1B1h, location: "foobar2000", loaded at 00400000h - 00539000h
Address: 004AE1ABh, location: "foobar2000", loaded at 00400000h - 00539000h
Address: 004D0B64h, location: "foobar2000", loaded at 00400000h - 00539000h
Address: 004CEED0h, location: "foobar2000", loaded at 00400000h - 00539000h
Address: 004AE1BFh, location: "foobar2000", loaded at 00400000h - 00539000h
Address: 004CA3A8h, location: "foobar2000", loaded at 00400000h - 00539000h
Address: 004AFC0Ah, location: "foobar2000", loaded at 00400000h - 00539000h
Address: 7C817067h, location: "kernel32", loaded at 7C800000h - 7C8F6000h
Symbol: "RegisterWaitForInputIdle" (+00000049h)
Address: 7C839AC0h, location: "kernel32", loaded at 7C800000h - 7C8F6000h
Symbol: "ValidateLocale" (+000002B0h)
Address: 7C817070h, location: "kernel32", loaded at 7C800000h - 7C8F6000h
Symbol: "RegisterWaitForInputIdle" (+00000052h)
Address: 004AFC75h, location: "foobar2000", loaded at 00400000h - 00539000h
Address: 004E0049h, location: "foobar2000", loaded at 00400000h - 00539000h
Address: 004F0044h, location: "foobar2000", loaded at 00400000h - 00539000h
Version info:
foobar2000 v0.9.6
UNICODE
Windows 5.1
[!--sizeo:1--][span style=\"font-size:8pt;line-height:100%\"][!--/sizeo--]Moderation: Code => codebox. Probably caused by "foo_uie_lyrics", fyi.[/size]
Curaçao by Br3tt
Reply #438
The best! Anyway, is the Avril background is default? Can it be changed?
Curaçao by Br3tt
Reply #439
I've noticed that I can slightly improve smoothness when scrolling by reducing the size of teh background image (wallpaper.jpg). I think originally it's 300KB, but I used Photoshop to reduce it (save for web and devices option) down to around 48KB!
It's improved smoothness in scrolling in the playlist for me. Could anybody else verify this for me?
Curaçao by Br3tt
Reply #440
ohoh, i'll test that and give you feedback asap, could be a good news to improve curacao a little more
brb
Curaçao by Br3tt
Reply #441
Hi, when i search for lyrics, the field "artist" is empty and i have to fill the artist in manually!
How can i fix it that its automatically?
Curaçao by Br3tt
Reply #442
Preferences-->Lyric Show Panel-->Internet-->Titleformating for lyric search-->Artist: $if2(%artist%,)
Curaçao by Br3tt
Reply #445
tested, it's false... i have scrolled down a full playlist of 630 tracks with a background image very huge (~5Mb), it takes 22,6 seconds to reach the bottom with key down pressed. After converting the image to 186 Kb, same result : 22,6 seconds.
Curaçao by Br3tt
Reply #446
I have a problem with this beautiful Design. The "things" on the left side doesnt work. You can see it on the screenshot. What is wrong? Thanks for your help!
Curaçao by Br3tt
Reply #448
i think it's because you have not the good version of the component panel stack splitter !!!
grad the last one here : http://foo2k.chottu.net/
that will fix your pb!
Curaçao by Br3tt
Reply #449
Ah... thanks... simple...  That was the problem. Thanks a lot.
