Topic: Media Library ignores some tracks (Read 11116 times) previous topic - next topic
Hi all!
I have a big problem with my Media Library, it skips somewhere around 800 out of my 5500 tracks. I noticed the problem when using a version from auugust or something, but I just updated to newest beta and it's still the same.
I don't think there is something wrong with the tracks since many of the missing tracks are individual files from individual albums. And also, the tracks are added, played and tagged without problem if I just drag them into a playlist.
Please help! It sucks to be missing 15% of my music collection
I just like listening to music
Are your files on a network drive?
Do any of your files have unicode filenames?
elevatorladylevitateme
No, they're on an external drive.
Not as far as I can see. Here's two filenames, the first works, the second don't:
F:\Musik\All Musik\Street Dogs\State of Grace\07. Street Dogs - Two Angry Kids.mp3
F:\Musik\All Musik\Street Dogs\State of Grace\03. Street Dogs - Into The Valley.mp3
Are any of these files marked as system or hidden? You can check that in the files' properties in Windows Explorer.
No. They have identical attributes and they also have the same access rights.
I can pm you a non-working track if that will help identify the problem.
I've just confirmed that it's something with my current foobar2000 install. Media library successfully added all tracks from a new portable install of the newest beta.
Since it's something wrong with my config, a list of plugin is probably needed:
Core (2008-11-19 13:07:56)
    foobar2000 core 0.9.6 beta 5
foo_abx.dll (2008-05-24 16:23:50)
    ABX Comparator 1.3.3
foo_albumlist.dll (2008-11-19 13:06:54)
    Album List 4.3
foo_audioscrobbler.dll (2007-12-07 17:34:36)
    Audioscrobbler 1.3.15
foo_browser.dll (2007-03-23 16:53:12)
    Music Browser 1.2.3b [Mar 23 2007 - 16:52:56]
foo_burninate.dll (2006-08-04 21:56:44)
    Audio CD Writer 2.0.1
foo_cdda.dll (2008-11-19 13:06:36)
    CD Audio Decoder 2.1.3
foo_comserver2.dll (2006-07-31 20:13:20)
    COM Automation server 0.7 alpha 6
foo_converter.dll (2008-11-19 13:06:26)
    Converter 1.2
foo_dsp_soundtouch.dll (2007-04-01 08:06:40)
    SoundTouch DSP 0.1 (Intel SSE)
foo_dsp_std.dll (2008-11-19 13:06:58)
    Standard DSP Array 1.0
foo_fileops.dll (2008-11-19 13:05:54)
    File Operations 2.1.1
foo_freedb2.dll (2008-11-19 13:07:02)
    freedb Tagger 0.6
foo_input_monkey.dll (2006-08-04 21:57:18)
    Monkey's Audio decoder 2.1.1
foo_input_mslive.dll (2007-10-29 19:56:56)
    mslive 0.4.1 (Intel SSE)
foo_input_std.dll (2008-11-19 13:07:26)
    Standard Input Array 1.0
foo_input_tak.dll (2007-04-11 21:58:22)
    TAK Decoder 0.2
foo_input_wma.dll (2007-10-22 13:43:56)
    Acro WMA decoder 0.1.7.1 (Intel SSE)
foo_lyricsgrabber.dll (2008-04-24 06:05:15)
    Lyrics Grabber 0.1.6 Preview
foo_masstag.dll (2006-09-23 15:16:28)
    Masstagger 1.6
foo_np_simple.dll (2007-10-21 04:02:06)
    Now Playing Simple 1.7
foo_playback_custom.dll (2007-12-21 16:12:08)
    Playback Statistics Custom 1.4.3
foo_playlist_manager.dll (2007-01-22 12:05:12)
    Playlist Manager 1.0.2
foo_pqview.dll (2007-01-22 13:02:24)
foo_removefromqueue.dll (2007-07-14 14:30:00)
    Remove from Queue 1
foo_rgscan.dll (2008-11-19 13:06:26)
    ReplayGain Scanner 2.0.8
foo_scheduler.dll (2006-12-04 17:23:20)
    Scheduler 3.52
foo_scrobblecharts.dll (2007-03-31 16:36:48)
    Last.fm Chart Player 0.2.3
foo_sendtodevice.dll (2007-11-28 10:13:46)
    Send to Device 1.1.2 [Nov 28 2007 - 10:13:31]
foo_texttools.dll (2008-05-18 16:40:42)
    Text Tools 1.0
foo_tutorial1.dll (2008-10-14 16:36:19)
    Component Tutorial 0.4
foo_ui_columns.dll (2007-12-08 00:25:15)
    Columns UI 0.2.1 alpha 9 v3
foo_ui_egoh.dll (2007-01-13 05:20:02)
    Egoh User Interface 1.1.0
foo_ui_std.dll (2008-11-19 13:06:36)
    Default User Interface 0.9.5
foo_uie_albumart.dll (2007-10-23 22:39:18)
    Album Art Panel 0.2.7
foo_uie_albumlist.dll (2007-06-11 14:13:53)
    Album list panel 0.2.3 beta
foo_uie_lyrics_panel.dll (2006-12-10 03:05:30)
    Lyrics panel 0.35
foo_uie_quicksearch.dll (2007-05-18 13:31:10)
    Quick Search Toolbar 2.8l
foo_uie_trackinfo_mod.dll (2006-12-06 14:21:34)
    Track info panel mod 0.8.0 beta [Dec  6 2006 - 14:21:24]
foo_uie_vis_channel_spectrum.dll (2008-01-12 16:52:12)
    Channel Spectrum panel 0.14
foo_uie_vis_egoh.dll (2007-01-13 05:20:06)
    Egoh Spectrum analyser (uie) 1.1.0
foo_uie_vis_peakmeter_spectrum.dll (2008-04-19 19:18:50)
    Peakmeter Spectrum Visualisation 0.2.0.0 beta
foo_uie_wmpvis.dll (2007-09-30 00:03:36)
    WMP Visualizations 0.1.3 (Intel SSE)
foo_unpack.dll (2008-11-19 13:05:34)
    RAR reader 1.1
    ZIP/GZIP reader 1.0
foo_utils.dll (2008-02-08 22:26:58)
    Playlist Tools 0.6.2 beta 6
Another thing I come to think about is that I got a crash when rescanning the library before switching to newest beta, is it possible my config.cfg is broken?
Anyways, hope there is a solution without having to redo all work with my current config. It would really suck. Edit: Meh, I did it.
Have you tried reloading tags from files? I had similar problem and that's what helped me.
Sharing delusions since 1991.
When I started using foobar (almost 2 years ago) I missed a lot of songs too. When I started using facets also, I noticed I had songs that missed important tags. Filling the tags solved it.
Try this search to see if my solution will work for you too.
%album% MISSING OR %artist% MISSING OR %title% MISSING
(maybe also genre or date if that is an operator you view your library in.)
Hi all!
Is there a simple method to find all %album artist% fields that are present but empty?
I've searched around the wiki without results...
If empty, why would it be present?
terry
terry
All my tracks have the "album artist" tag  (I don't know why) but a lot of them have the field empty, so I need to find them and fill the fields. Possibly without manually scan all my library (2600 cd).
Fabio
You are having troubles understanding foobar, I think. Or maybe just tagging in general.
If %album artist% field is empty, then that track does NOT have an album artist tag.
Unless you are having trouble with compilations showing correctly, there is seldom a need for any value in %album artist%.
Show us a specific example of how one of your tracks that has an empty %album artist% that is troubling you and we can go from there.
Also, where is it in the program where you see Foobar showing that a track an %album artist% tag present, but it is an empty tag.
terry
Try a query like
[font= "Courier New"]album artist PRESENT AND album artist IS ""[/font]
or
[font= "Courier New"]"$if($meta_test(album artist),$meta(album artist),-)" IS ""[/font]
Yirkha
Could you tell me what the above strings test for ?
thank you
terry
terry
This is an album with the problem:
[a href="http://img195.imageshack.us/my.php?image=albumartisth.jpg" target="_blank"]
Yirkha, your strings seems to do nothing in my library.
However many thanks to all
Fabio
The only issue here is bad tags.
In this case, you just need to edit. Select all the tracks and return to the properties dialog.
Edit the two fields and save. Done.
You are simply seeing a Field / Tag pair that is Field = %Album Artist% Tag = Empty.
It is no different than all the other empty fields whose %Field Name% is not automatically included in the properties dialog OTHER than for a setting in preferences > Advanced >Display > Properties Dialog
PLEASE do not make changes here until you are more familiar with Foobar.
terry
EDIT: I meant for you not to fool with the advanced setting preferences. Editing your tags, of course, is the point here.
tpijag: Sure.
\__________________/     \________________/
  Checks if "album artist"        |
  field is present. Usual title   |
  formatting remapping for        |
  %album artist% doesn't doesn't  |
  apply here.                     |
               This one is simple, tests whether
               the "album artist" field is empty.
But actually it could be even simpler just like this: [font= "Courier New"]album artist IS ""[/font]
The second is the same, but in title formatting only:
     +--- Using $meta_...() to avoid
          the %album artist% remapping.
If "album artist" field is present, return it's value.
If it's not present, return a dash.
Then show the tracks for which this evaluates to an empty string.
Also would be enough like this, I think: [font= "Courier New"]"$if2($meta(album artist),-)" IS "" [/font]
Fabio258: Seems you don't have tracks like you described after all. Maybe you're just confused about the %album artist% remapping? See Help > Title formatting help:
%album artist% -- Name of the artist of the album specified track belongs to. Checks following metadata fields, in this order: “album artist”, “artist”, “composer”, “performer”. The difference between this and %artist% is that %album artist% is intended for use where consistent value across entire album is needed even when per-track artists values vary.
thanks
I always forget that you can bypass the built in remapping.
terry
terry
Yes, it's just that i want to do, maybe I cannot explain well (sorry for my bad english). But how can i do to find the tracks without the tag? Only with a manual search album by album?
Just find it! I must search album artist MISSING and not %album artist% MISSING sorry for the mismatch and again thanks to all, you are great!
Fabio
