Topic: Converting album flac files with cue back to the original flac image (Read 4349 times) previous topic - next topic
I have downloaded an album image in FLAC format with CUE sheet (album.flac + album.cue).
To play this album in players that do not support cue sheets I have split the album into separate files using Medieval Cue Splitter (track01.flac, track02.flac, etc).
Is there a way to merge/join these flac files back into the original FLAC image without reencoding? I want to get a 100% identical copy of the original FLAC image.
I'm not sure you can re-create the original image because there might be additional info in the original .cue which won't be in your re-created .cue
Other than that, i'm usually using foobar to do this, just load all files in a playlist then convert them to .flac as image with cuesheets. On the new converter interface it's the "generate multi-track file" option
What you could also do is keep the original .cue and then just merge all the tracks to one with foobar and then use the backed up .cue to play the image file.
