Topic: Resampler plugin (Read 349515 times) previous topic - next topic
Re: Resampler plugin
Reply #450
Why are there 3 versions of the plugin? I understand that 'mod' with the list of frequencies blank is equivalent to 'non-mod' version.
Reply #451
Do new versions compiled with 1.4 SDK use dynamic library linking when used with fbk 1.4?
Reply #452
Yes, new versions (0.8.4 and newer) are dynamically linked to MSVC runtime files.
Reply #453
Any chance you can re-code  S0x binary to sound better for Classical Music with extended highs?
Reply #455
Now, that we have option "Automatic resampler preference" in advanced settings (in fb2k 1.4 and higher), isn't option "Service Priority" redundant?
Reply #456
Bugfix version (0.8.7) was released.
Reply #457
Thank you Ivqcl!  Have the two "mod" versions been permanently discontinued, and, are the 0.8.4 versions of those still available (only 0.8.3 is now present in the "old versions" post)?
Reply #458
thank you!
Reply #459
Should we update from the old 0.8.3 versions to a newer version for reasons of audio quality? Do newer versions quality wise do "better" up- or downsampling or is it just necessary to update if you experience problems?
Reply #460
Audio quality is the same, so you can keep 0.8.3.
But if you convert files using this resampler, and you hear some (very quiet) clicks during track changes, then you should try 0.8.7.
Reply #461
Thanks for the quick answer!
Another question that someone asked before but I think there wasn't an answer:
Are the mod versions discontinued? I always found them very useful.
If there is just one version updated in the future, wouldn't it make sense if that would be mod(1)? It's really useful to be able to exclude (or include) sample frequencies.
