Topic: multi-genre tagging (Read 11338 times) previous topic - next topic
Re: multi-genre tagging
The desired behaviour in the album list is called "branching expressions". See here for an explanation:
http://wiki.hydrogenaud.io/index.php?title=Foobar2000:Titleformat_Album_List#Branching_expressions
Check the album list preferences (under media library). For branching expressions, you'll have to use %<genre>% instead of %genre%.
If this doesn't work, it could be a character encoding quirk. I've experienced this on rare occasions. Try the following:
Select files -> go to Properties dialog -> right click on the genre-column -> click "Split values..." -> Add ; as a seperator -> OK
-> multiple genres should then be branched in the album list.
Take a look at the screenshots. Is that correct?
If so, it’s not something else.
Yes, that looks correct. Does it work?
Does it work?
Yes for MPEG 1 Layer III (.mp3), not for ALAC / MPEG-4 AAC LC (.m4a), FLAC (.flac), Monkey3.97 / Monkey3.99 (.ape), OGG Vorbis (.ogg), PCM / PCM (float) (.wav), WavPack4 (.wv), and WMAV8 / WMA 9.1 (.wma).
If it works for mp3s but not for other files, I suspect that there's a problem with the tags. Try the following with some files that do not work:
select files -> hold shift key -> right click selected files -> in the context menu, look under "Tagging" -> click "Rewrite file tags"
ptk - done. At least FLAC didn't work. I didn't notice any changes either immediately or after restarting the player. The list of music genres still displays entries that include multiple genres, separated by a semicolon. And they contain including those tracks that I processed in the way you recommended. Try it yourself - Google Drive.
Tried these files. Indeed, they showed up with a long list of genres seperated by ;
But using the "Split values..." operation fixed it. See for yourself: google drive
You will have to do this for every file (select everything, go to properties, right-click on "Genre" and split values).
Reply #32
Yes, this method helped to split the music genre tag string into separate tags. Thanks! Is TagScanner 6.1.6 so bad at editing tags in APEv2 / APEv2~rg, metadata (for PCM), mp4 (for ALAC and MPEG-4 AAC LC) and vorbis (for FLAC) formats? I would not want to give it up.
I don't know about TagScanner, but foobar2000 itself is the most capable tool for tagging I know of (at least if you're willing to use its scripting facilities according to the Title Formatting Reference)
