Topic: From: foobar2000 v0.9.6 beta 1 (Read 1968 times) previous topic - next topic
thanks for the update, and the new features.
only startup times are little longer, but the rest flows.
at posters #9,13,17,25,27, or others interested in component dependencies:
(xp sp2, so if someone have problems maybe is vista os or components version)
Core (2008-10-19 22:39:26)
    foobar2000 core 0.9.6 beta 1
foo_abx.dll (2008-05-24 17:23:50)
    ABX Comparator 1.3.3
foo_ac3.dll (2008-06-02 12:24:26)
    AC3 decoder 0.9.1
foo_adpcm.dll (2008-03-20 15:27:44)
    ADX decoder 1.7
    BRR decoder and converter 0.7
    GCN DSP decoder 1.3
    Interplay ACM decoder 1.0
    kode's ADPCM decoders 1.2
    OKI-ADPCM decoder 0.14
    RAC decoder 1.0
    XA ADPCM decoder 1.2
foo_alarm.dll (2006-09-17 12:31:18)
    Alarm 1.61
foo_albumlist.dll (2008-10-15 19:37:56)
    Album List 4.3
foo_autoplaylist.dll (2006-08-04 21:56:56)
    Autoplaylist Manager 1.0
foo_benchmark.dll (2006-08-04 21:56:56)
    Decoding Speed Test 1.0
foo_binpack.dll (2006-05-15 11:09:58)
    BinPack Playlist Generator 1.0.0
foo_biometric.dll (2008-08-15 00:16:08)
    Fingerprint tools 0.2
foo_bitcompare.dll (2006-08-04 21:56:50)
    Binary Comparator 1.1
foo_burninate.dll (2006-08-04 21:56:44)
    Audio CD Writer 2.0.1
foo_cdda.dll (2008-10-15 19:37:46)
    CD Audio Decoder 2.1.3
foo_cdtext.dll (2007-12-29 01:38:42)
    CD-TEXT Reader 0.2
foo_chacon.dll (2008-10-05 16:28:50)
    Chacon 0.0.1
foo_channel_mixer.dll (2008-03-12 10:37:48)
    Channel Mixer 0.9.6.5
foo_converter.dll (2008-10-15 19:37:42)
    Converter 1.2
foo_convolve.dll (2006-08-04 21:57:26)
    Convolver 0.3
foo_cuefilter.dll (2008-08-29 02:14:58)
    Cue sheet filter 0.0.1
foo_cuesheet_creator.dll (2007-03-10 11:58:28)
    Cuesheet Creator 0.4.6
foo_dbsearch.dll (2007-01-25 21:58:48)
    Database Search 1.4
foo_dbsearch_api_demo.dll (2007-01-22 13:01:38)
    Database Search Toolbar Demo 1.0
foo_dirwatch.dll (2007-12-09 00:29:50)
    Directory watcher 0.2 beta 3
foo_discogs.dll (2008-10-21 05:44:21)
    Discogs Tagger 1.14
foo_dockable_panels.dll (2007-03-28 09:19:02)
    Dockable Panels 1.0.7b [Mar 28 2007 - 09:18:48]
foo_dsp_bs2b.dll (2006-11-14 14:42:36)
    bs2b 2.1.0
foo_dsp_centercut.dll (2006-07-18 16:30:22)
    Center Cut 1.0.1
foo_dsp_continuator.dll (2008-03-04 20:41:40)
    Continuator 0.6.1
foo_dsp_crossfeed.dll (2006-03-21 13:32:54)
    Crossfeed 0.92
foo_dsp_delta.dll (2006-03-21 18:16:22)
    LPCM <--> delta-PCM converter 0.1.1
foo_dsp_downmix.dll (2008-03-27 03:18:58)
    Downmix AC3/DTS to PL2 0.2
foo_dsp_fsurround.dll (2008-03-27 03:18:20)
    FreeSurround 0.3.5
foo_dsp_pl2.dll (2008-03-27 03:19:46)
    Dolby ProLogic II Wrapper 0.1
foo_dsp_span.dll (2007-03-14 04:16:22)
    Surround Pan 1.2
foo_dsp_std.dll (2008-10-15 19:38:08)
    Standard DSP Array 1.0
foo_dsp_stereoconv.dll (2007-05-18 00:19:46)
    Stereo Convolution 1.0.1
foo_dsp_tube.dll (2007-02-07 01:17:56)
    Tube Sound 0.8
foo_dsp_vlevel.dll (2008-03-03 00:42:06)
    VLevel 20080302.0
foo_dsp_vst.dll (2007-05-17 18:39:34)
    VST bridge 0.60 Beta
foo_dsp_xover.dll (2006-05-07 12:30:26)
    Crossover 0.38
foo_dumb.dll (2008-06-26 19:38:38)
    DUMB module decoder 0.9.8.4
foo_extm3u.dll (2007-02-02 01:10:28)
    EXTM3U playlist format plugin 1.3
foo_exvar.dll (2008-06-14 00:42:56)
    Extended Variables 0.3.1
foo_facets.dll (2008-06-01 04:40:42)
    Facets 2008-02-25
foo_filedate.dll (2007-09-19 13:07:16)
    File date 1.0.4
foo_fileops.dll (2008-10-15 19:37:24)
    File Operations 2.1
foo_freedb2.dll (2008-06-07 21:15:10)
    freedb Tagger 0.6
foo_gep.dll (2008-03-18 16:19:54)
    Game Emu Player 1.5
foo_guidlookup.dll (2006-03-13 00:25:18)
foo_infobox.dll (2006-10-09 15:17:14)
    Special file info box 2.0.4
foo_infospect.dll (2008-02-01 21:02:58)
    Infospect 1.0.3
foo_input_adplug.dll (2008-10-08 15:13:36)
    AdPlug 1.0
foo_input_alac.dll (2008-06-04 20:29:06)
    ALAC Decoder 1.0.1
foo_input_avs.dll (2006-03-21 14:15:50)
    AVS input 0.1
foo_input_ds.dll (2008-06-01 04:31:38)
    DirectShow input 0.1
foo_input_dts.dll (2007-05-04 10:29:44)
    DTS decoder 0.1.7
foo_input_mkx.dll (2008-06-01 04:30:58)
    Matroska input 0.1
foo_input_monkey.dll (2008-05-31 22:39:34)
    Monkey's Audio Decoder 2.1.3
foo_input_ofr.dll (2006-06-26 19:13:24)
    OptimFROG Lossless/DualStream Decoder 1.21b
foo_input_shorten.dll (2006-03-11 19:25:12)
    Shorten decoder 0.4.2a
foo_input_std.dll (2008-10-19 19:42:36)
    Standard Input Array 1.0
foo_input_tta.dll (2006-05-01 11:53:16)
    TTA Audio Decoder (unofficial) 2.4.2
foo_lyricsdb.dll (2007-02-26 18:42:02)
    foo_lyricsdb 0.0.7 beta 5
foo_lyricsgrabber.dll (2008-04-28 19:09:20)
    Lyrics Grabber 0.2.0 Beta
foo_masstag.dll (2007-10-13 15:17:26)
    Masstagger 1.6
foo_navigator.dll (2007-08-04 13:36:46)
    Navigator 0.63
foo_osd.dll (2006-08-21 10:06:02)
    On-Screen Display GDI+ 1.52
foo_out_asio.dll (2008-02-09 14:52:42)
    ASIO support 1.2.6
foo_out_ks.dll (2006-08-04 21:54:58)
    Kernel Streaming Output 1.2.2
foo_packet_decoder_ac3.dll (2006-04-30 22:01:56)
    ATSC A/52 (AC3) Packet Decoder 0.9
foo_playcount.dll (2008-07-09 22:00:12)
    Playback Statistics 2.1.5
foo_playlist_bind.dll (2007-06-27 03:57:38)
    Playlist Bind 3.2
foo_playlist_tree_mod.dll (2008-07-31 00:01:50)
    Playlist Tree Mod Panel 3.0.6.1 [Jul 31 2008 - 00:00:57]
foo_plbench.dll (2006-04-29 17:53:06)
    Playlist Loader Benchmark 0.3
foo_popupplus.dll (2008-04-24 22:24:18)
    PopUp Plus 20080424
foo_pqview.dll (2008-03-11 19:02:54)
    Playback Queue Viewer 0.2
foo_quicktag.dll (2007-10-16 17:46:18)
    Quick Tagger 1.0
foo_removeplayed.dll (2006-11-20 19:33:16)
    Remove played Files 1.3.0
foo_rg_trn.dll (2007-10-27 22:13:20)
    ReplayGain override 0.1.2
foo_rgscan.dll (2008-10-15 19:37:48)
    ReplayGain Scanner 2.0.8
foo_run.dll (2008-01-17 20:32:42)
    Run services 0.3.4
foo_runcmd.dll (2007-08-16 20:08:42)
    Run Command 1.0 beta 3
foo_scheduler.dll (2007-01-09 22:33:46)
    Scheduler 3.53
foo_shutdown.dll (2006-12-06 08:59:24)
    Foo Shutdown 0.9.3
foo_skip.dll (2006-07-06 10:14:14)
    foo_skip 0.2
foo_spdif.dll (2007-08-24 08:33:28)
    SPDIF support 1.3
foo_textdisplay.dll (2008-07-08 19:45:26)
    Text Display UI Element 1.0 RC 3
foo_texttools.dll (2008-06-19 20:53:52)
    Text Tools 1.0.1
foo_trackpos.dll (2006-12-13 20:04:58)
    Track Positioner 1.0
foo_ui_columns.dll (2008-09-12 00:44:30)
    Columns UI 0.3.4.2
foo_ui_std.dll (2008-10-15 19:37:58)
    Default User Interface 0.9.5
foo_uie_albumart.dll (2007-12-16 00:22:24)
    Album Art Panel 0.2.7.1
foo_uie_albumlist.dll (2008-09-24 21:29:02)
    Album list panel 0.3.2
foo_uie_bookmarks.dll (2008-06-03 02:03:22)
    Bookmarks 0.2.5.3a
foo_uie_console.dll (2008-08-06 12:43:32)
    Console panel 0.3
foo_uie_elplaylist.dll (2008-05-31 03:11:14)
    ELPlaylist 0.2.9.3(alpha)
foo_uie_explorer.dll (2008-09-27 10:58:30)
    Explorer Tree 1.04.6c
foo_uie_lyricist.dll (2008-07-15 14:39:46)
    Lyrist foobar2000 Component    1.41 1.41
foo_uie_lyrics.dll (2008-08-17 09:31:18)
    Lyric Show Panel 0.3.3.2 [Aug 17 2008 - 15:30:33]
foo_uie_lyrics_panel.dll (2007-08-17 23:56:36)
    Lyrics panel 0.35
foo_uie_panel_splitter.dll (2008-05-31 12:19:42)
    Panel Stack Splitter 0.3.4(alpha)
foo_uie_playlists_dropdown.dll (2006-06-06 12:30:00)
    Playlists Dropdown 0.5.7.5
foo_uie_quicksearch.dll (2007-05-18 13:31:10)
    Quick Search Toolbar 2.8l
foo_uie_single_column_playlist.dll (2007-01-09 15:43:08)
    Single Column Playlist Display 0.5.4 beta [Jan  9 2007 - 15:42:59]
foo_uie_tabs.dll (2007-09-08 22:08:54)
    Tabbed panel modified 0.2.6
foo_uie_tagger_mod.dll (2008-09-17 22:27:46)
    Tagger Mod Panel Window 1.0.7.0 [Sep 17 2008 - 22:15:59]
foo_uie_trackinfo.dll (2006-06-06 19:08:44)
    Track info panel 0.8
foo_uie_typefind.dll (2007-10-22 23:30:46)
    Typefind 0.2 beta 2
foo_uie_vis_peakmeter_spectrum.dll (2008-04-19 20:18:50)
    Peakmeter Spectrum Visualisation 0.2.0.0 beta
foo_utils.dll (2008-02-08 23:26:58)
    Playlist Tools 0.6.2 beta 6
foo_utils_matroska.dll (2006-09-26 03:37:34)
    Matroska Utility Plugin 1.0.2
foo_verifier.dll (2006-08-29 22:09:16)
    File Integrity Verifier 1.0.1
foo_version.dll (2006-07-18 19:20:56)
    Components versions viewer 0.3
foo_vis_channelusage.dll (2006-03-13 00:24:20)
    Channel Usage Visualisation 1.0
foo_vis_screensaver.dll (2008-03-10 20:57:38)
    Screen Saver Visualisation 1.1
foo_vis_shpeck.dll (2008-05-30 01:07:54)
    Shpeck - Winamp vis plugins wrapper 0.2.4
foo_winamp_ipc.dll (2008-04-21 03:58:08)
    Winamp IPC emulator 0.1.3
