Topic: Playlist statistics. (Read 3881 times) previous topic - next topic
Is there a component that will display the currently selected play list's total play time, total tracks, etc, in the red area in the pic?
EDIT: I stuffed up the pic, the red bit is supposed to be under the playlist tabs.
see pic below
you can display all that you discribed in this playlsit dropdown toolbar panel, but i'ts for ColumnsUI or PanelsUI layouts only
Ok, I'll re-use this thread.
%title% ~$rgb(64,156,64,255,255,255)$if(%isactive%,' (Active'$if(%isplaying%,', Playing')')',$if(%isplaying%,' (playing)'))
$tab(3)[ '('%lock%')']$tab(2)
$rgb(0,0,255,160,240,120)%size% Songs / $div(%filesize%,1048576)
MB
'('$div(%filesize%,1048576000) GB')'
$rgb(127,127,127,255,255,255)' (Total Playtime: '%length%')'
That's what I currently have.
What I would like to do is merge the MB and GB, so that it displays it in GB only if it actually adds up to atleast a gigabyte, else it displays it in megabytes.
I have no idea where to start with this...
I was thinking it would be much the same as:
$info(codec)$if($strcmp($info(encoding),lossy), @ $info(bitrate)kbps,: Lossless)
...with a few things changed, but it says $info is an unknown function.
...$ifgreater(%filesize%,1048575999,$div(%filesize%,1048576000) GB,$div(%filesize%,1048576) MB)...
Thank you very much Yirkha
EDIT: How would I add decimal places to the gigabytes?
...$puts(x,$muldiv(%filesize%,100,1048576000))$insert($get(x),.,$sub($len($get(x)),2))...
Thanks again Yirkha, but I have no idea where that goes.
Could you possibly paste it in the appropriate place in the following code, so that I can copy/paste it?
$rgb(0,0,255,160,240,120)%size% Songs / $ifgreater(%filesize%,1048575999,$div(%filesize%,1048576000) GB,$div(%filesize%,1048576) MB)
EDIT: Kinda have it.
Except the decimals are appearing after the MB...
MB
Meh, $ifgreater() and $muldiv() does not work with large numbers...
$ifgreater($put(m,$div($add(%filesize%,524288),1048576)),999,$puts(g,$muldiv($get(m),100,1000))$insert($get(g),.,$sub($len($get(g)),2)) GB,$get(m) MB)
Sorr for bumping this thread
With recent version of foo_uie_playlists_dropdown (0.6.9.9), you can use
%filesize_natural%
formatting field, which displays formatted total playlist file size, e.g. 62.1GB or 322KB.
Note, that it works in playlist views too, so there is no more need to calculate file sizes using formatting scripts.
Yeah, %filesize_natural% is another new 0.9.6 feature, thanks for reminding.
