Topic: CUETools versions 1.9.5 through 2.1.6 (Read 1942254 times) previous topic - next topic
0 Members and 9 Guests are viewing this topic.
CUETools versions 1.9.5 through 2.1.5 (current)
Reply #250
I didn't test anything but I didn't found the "filename corrector". I guess it's not here yet as it seems ok.
Thanks. I was mostly worried about the icons in the file brower, looks like they're ok.
Filename corrector is now a 'correct filenames' choice in the action list.
You can select a cue sheet and press 'go', or you can select a folder, enable 'recursive' and press go.
CUETools 2.1.6
Reply #251
When 2.0x64 will be available?
Reply #253
Oh, thank you.
Reply #254
What's ru-RU\CUETools.resources.dll for? If it is a localization, how can I enable it?
If your system language is ru-RU, it is enabled automatically.
I have english windows vista ultimate sp1 x64 version with russian formats, location, keyboard languages and system locale turned on but still i can't make CUETools run with russian interface. What else should I do?
Reply #255
Hmm, i will look into it.
CUETools 2.1.6
Reply #256
Thank you for this piece of software it allready has proven quite usefull for me!
I have one issue thouh. Maybe it is intended but I'll ask anyway.
I have a lot of one file flac images with embedded cuesheet and embeded coverart. When transcoding these images to 'new' flac images the replaygain info gets lost.
This replaygain info is added to the embedded cuesheet by foobar2000 but it seems it is not copied over via cuetools.
I'm using CUETools 1.9.5 (X64) on Vista btw.
Reply #258
Loading cue sheet file grays out go button?  Loading folder works OK, however.
If you selected 'Recursive', yes. Not very convinient, i guess. Hmm.
CUETools 2.1.6
Reply #260
Can you make an option to show the results of the operation, not just restrained "done" when the process is complete?
Reply #261
You mean, brief accuraterip summary for each item in batch mode? I was going to do that.
CUETools 2.1.6
Reply #263
Thanks for the new version, Gregory. This new user interface is really great! And now I can easily test my old rips burned to dvds, even the ones without cue files.
Reply #264
Gregory; Is the above intended behaviour?
Reply #265
Yes and no. This has been there from the start. As i understand, the reason for that was that replaygain info might become wrong if offset is applied.
I didn't get my hands on it yet. Are there any objections on just keeping replaygain info? Does anybody even need an option to remove it?
CUETools 2.1.6
Reply #266
In my quick ~10 files test the replaygain info seemed to be the same before and after. Also after offset correction.
Reply #267
The worst case scenario would be a gapless DJ mix in which a track begins or ends with a very brief and loud "crash" and the rest of the track happens to be quieter. In theory it would be possible that this peak would be moved to another track when the offset correction is applied. I doubt that would be a practical problem though. In any case you can always re-analyze the files if you think that's necessary.
So, yes, I think it would be good to preserve RG info when possible. It would be a green choice. Energy would not be used for unnecessary analysis processes.
Reply #268
OK, just a simple question here. My library is composed of WavPack images w/ embedded cue sheets. When trying to accurip verify them, if I load them individually it works fine, but when trying to do a batch job it says something like "no supported format found". Does batch only look for external cue sheets, and is there any way around this?
Reply #269
Which version are you using? This should work in 2.0
CUETools 2.1.6
Reply #270
Using 1.95a, I'll download 2.0 and try it. Thanks for the fast reply!
Reply #271
Thanks for the new version. Maybe it's my computer but the new interface isn't working as I thought it would.
If I click on my computer icon to browse to another hard disk, I get a fault "onjuiste functie" (incorrect function) behind My computer.
Also I like to drag & drop from my total commander. This still works, but after every go, the input is changed to whatever directory is selected in the input tree.
This is a bit annoying because sometimes I want to check the same directory with different pregaps.
Is it possible to keep the last used directory in the input window?
P.S. I'm using 2.0 under Window XP pro, Dutch
Reply #272
Thanks for report. That's why this version was called 'preview'  That input tree works differently depending on OS and IE versions. Hopefully, this will be fixed in the final 2.0 release.
CUETools 2.1.6
Reply #273
Something's (obviously) wrong...
"Batch" and "Multiple" checkboxes are ticked on startup, but when I load a CUE sheet and click "Go", a message pops up ("Nothing selected."), and I'll have to untick the "Multiple" checkbox and tick it again.
audiophile // flac & wavpack, mostly // using too many audio players
Reply #274
If you select 'multiple' or 'recursive', batch mode is activated.
When 'multiple' is checked, you have to select at least one album to process using checkboxes in the tree.
When you uncheck it and check it again, the current selected album becomes checked.
So far everything seems to function as designed. Or it doesn't?
Maybe the design is just too complicated.
I'm currently testing how would it work without the 'recursive' checkbox.
Batch mode would be activated when you select a folder.
Maybe the 'multiple' mode should go too?
It seems to cause a lot of confusion, but doesn't seem to be very useful.
CUETools 2.1.6
