Topic: CUETools versions 1.9.5 through 2.1.6 (Read 1942381 times) previous topic - next topic
0 Members and 7 Guests are viewing this topic.
CUETools versions 1.9.5 through 2.1.5 (current)
Reply #175
Use the "Own format" textbox.
audiophile // flac & wavpack, mostly // using too many audio players
Reply #176
Is there a tutoral or any kind explanation of how to use Cuetools ?
Not really. Just a readme file and a small wiki page here, which i hope somebody will expand a bit - i'm not really good at this.
I would like to write my files to a different directory using "artist - album" as the folder name and "artist - album" as the name of my single file .wav .
Choose "Use custom format" for output path, and set it to something like "C:\Music\%D - %C\%D - %C.cue".
Make sure that in advanced settings "Single format" is set to %F and "Keep original filenames" is turned off. I think it's this way by default.
Your program is great !!!!
Actually, it's Moitah's program. I just added some new features.
CUETools 2.1.6
Reply #177
Does anyone know how to change CueTools language? It's a good idea to place this info to readme :-)
Reply #178
AFAICS it is taken from the system?
Reply #179
Yep...
If your system's language is russian or german, CUETools will use the appropriate language files, unless you remove the deDE and ruRU folders.
No other language packs available currently. If you are willing to help creating one of them, let me know.
CUETools 2.1.6
Reply #180
If it hasn't been reported, yet: ALAC input does not work without cuesheets for 1.9.3. It displays the following message "Padded some input files to a frame boundary.", fails to detect the correct disc ID, and returns before verification. If I convert the same set of ALAC files to FLAC in Foobar and feed them into CUETools again everything works fine.
I tried the same in 1.9.4a. Here verification starts (I guess the disc ID has been detected then) but breaks when going from track 01 to track 02 with the following error: "Samples read != Samples expected".
Edit: ALAC files were created using XLD (Apple's Core Audio converter), so they should be conforming to specs.
Reply #181
In November last year I did a request for a drag & drop for the cue-sheet creator. A few days later I said I didn't need it any more.
But now I think it would be a nice feature.
Since the request of Fandango on Jan, 9 an update also calculates the crc's with and without zero's while only verifying.
Could this be made into a selectable feature?
I check many downloads without log, and now I have to wait until cuetools has calculated all crc's instead of telling me right away the disc is not in accurate rip database.
To finish a question about a log:
[Disc ID: 00376db3-03ea51a9-5f0f8019]
Track [ CRC    ] Status
 01 [41810bc1] (00/00) No matches
 02 [b38f9541] (00/02) No matches
 03 [f534d0a5] (00/02) No matches
 04 [70e38582] (00/02) No matches
 05 [b9ffa57c] (00/02) No matches
 06 [a4c21713] (00/02) No matches
 07 [a9e42b24] (00/02) No matches
 08 [2ce3ec1f] (00/02) No matches
 09 [691da940] (00/02) No matches
 10 [653ff6e2] (00/02) No matches
 11 [8a6e4f7c] (00/02) No matches
 12 [28bb673f] (00/00) No matches
 13 [67633e1d] (00/02) No matches
 14 [543b0503] (00/02) No matches
 15 [e08a56d5] (00/02) No matches
 16 [ab61a706] (00/00) No matches
 17 [27fd191b] (00/02) No matches
 18 [47a1b9a8] (00/02) No matches
 19 [875f8b51] (00/02) No matches
 20 [984f5c0a] (00/02) No matches
 21 [c1d8633a] (00/02) No matches
 22 [ca8cc11e] (00/02) No matches
 23 [3bb02914] (00/02) No matches
 24 [d7980cae] (00/02) No matches
 25 [04d0fc4c] (00/02) No matches
Offsetted by 450:
 01 [eae7aa77] (00/00) No matches
 02 [190770ed] (02/02) Accurately ripped as in pressing(s) #1
 03 [3de8c8b7] (02/02) Accurately ripped as in pressing(s) #1
 04 [8db62dac] (02/02) Accurately ripped as in pressing(s) #1
 05 [8215c9da] (02/02) Accurately ripped as in pressing(s) #1
 06 [331c07eb] (02/02) Accurately ripped as in pressing(s) #1
 07 [9a6d6c68] (02/02) Accurately ripped as in pressing(s) #1
 08 [97a0f8eb] (02/02) Accurately ripped as in pressing(s) #1
 09 [a1f2a00c] (02/02) Accurately ripped as in pressing(s) #1
 10 [50af46dc] (02/02) Accurately ripped as in pressing(s) #1
 11 [6499de26] (02/02) Accurately ripped as in pressing(s) #1
 12 [8aca015d] (00/00) No matches
 13 [02e24079] (02/02) Accurately ripped as in pressing(s) #1
 14 [f10f0f87] (02/02) Accurately ripped as in pressing(s) #1
 15 [3fceacb1] (02/02) Accurately ripped as in pressing(s) #1
 16 [29c0ff10] (00/00) No matches
 17 [b9bf2dd9] (02/02) Accurately ripped as in pressing(s) #1
 18 [3d7cde7c] (02/02) Accurately ripped as in pressing(s) #1
 19 [019b2343] (02/02) Accurately ripped as in pressing(s) #1
 20 [57d3d30c] (02/02) Accurately ripped as in pressing(s) #1
 21 [fee1fed6] (02/02) Accurately ripped as in pressing(s) #1
 22 [1731c90a] (02/02) Accurately ripped as in pressing(s) #1
 23 [dcd59316] (02/02) Accurately ripped as in pressing(s) #1
 24 [f286eafc] (02/02) Accurately ripped as in pressing(s) #1
 25 [a764d748] (02/02) Accurately ripped as in pressing(s) #1
Am I correct when I conclude that tracks 1, 12 & 16 haven't been ripped by both contributors?
Reply #182
I have the same problem with log files. I don't see any value in wasting time calculating CRC values only to eventually be told that the CD does not exist in the AccurateRip database.
Tigerman, are those three tracks really short tracks? I've seen 00/00 with tracks that are just a few seconds long.
Reply #183
All 3 tracks are more than 2:30 minutes long.  I also think it's a bit strange that 2 persons rip all tracks but 3 and on top pf that, the same 3.
But I don't know another explanation for this log.
Reply #184
+1, please add a checkbox to disable this feature of 1.9.4a.
Reply #185
What's ru-RU\CUETools.resources.dll for? If it is a localization, how can I enable it?
Reply #186
If your system language is ru-RU, it is enabled automatically.
Reply #187
How can I save the log with summary results including information how many tracks are accuratly ripped???
I have flac files + cue and cue tools shows me this:
[Verification date: 17.02.2009 18:48:00]
[Disc ID: 00236e9b-0148dca1-be129a0c]
 01 [900ed963] (04/08) Accurately ripped as in pressing(s) #1
 02 [fe14ff5a] (04/08) Accurately ripped as in pressing(s) #1
 03 [3251d1ea] (04/08) Accurately ripped as in pressing(s) #1
 04 [1ed5ba05] (04/08) Accurately ripped as in pressing(s) #1
 05 [6988026b] (04/08) Accurately ripped as in pressing(s) #1
 06 [63c0c74c] (04/06) Accurately ripped as in pressing(s) #1
 07 [502fbf53] (04/06) Accurately ripped as in pressing(s) #1
 08 [a1134504] (04/08) Accurately ripped as in pressing(s) #1
 09 [2a2a7ca5] (04/08) Accurately ripped as in pressing(s) #1
 10 [af9ffc79] (04/08) Accurately ripped as in pressing(s) #1
 11 [6e81ef45] (04/08) Accurately ripped as in pressing(s) #1
 12 [a096748a] (04/08) Accurately ripped as in pressing(s) #1
Offsetted by 658:
 01 [16bda481] (04/08) Accurately ripped as in pressing(s) #2
 02 [b4e5f384] (04/08) Accurately ripped as in pressing(s) #2
 03 [e91b7a6a] (04/08) Accurately ripped as in pressing(s) #2
 04 [e06ef381] (04/08) Accurately ripped as in pressing(s) #2
 05 [b948c587] (04/08) Accurately ripped as in pressing(s) #2
 06 [f3b8c9bc] (02/06) Accurately ripped as in pressing(s) #2
 07 [4b9e0fa3] (02/06) Accurately ripped as in pressing(s) #2
 08 [f4d7469e] (04/08) Accurately ripped as in pressing(s) #2
 09 [0eff3567] (04/08) Accurately ripped as in pressing(s) #2
 10 [a62f7475] (04/08) Accurately ripped as in pressing(s) #2
 11 [8df9bdff] (04/08) Accurately ripped as in pressing(s) #2
 12 [396b5720] (04/08) Accurately ripped as in pressing(s) #2
Track [ CRC32  ] [W/O NULL] [  LOG  ]
 -- [5BA4C51E] [69837F15]
 01 [ED14D67F] [0524FE8D] W/O NULL
 02 [9FFC6177] [A4439958] W/O NULL
 03 [84459ABA] [165623DE] W/O NULL
 04 [65AF8CCC] [6D42D10C] W/O NULL
 05 [2FE0C888] [E04A22A1] W/O NULL
 06 [9DA30EA6] [A38AB19E] W/O NULL
 07 [D651B2BB] [8F25F247] W/O NULL
 08 [5E96E749] [4AA61D43] W/O NULL
 09 [DC12FE56] [F67A5A90] W/O NULL
 10 [9C620694] [ACCAF361] W/O NULL
 11 [099A2D28] [69AB621E] W/O NULL
 12 [361F538B] [573BDEDA] W/O NULL
W/O NULL - what does it mean????
[!--sizeo:1--][span style=\"font-size:8pt;line-height:100%\"][!--/sizeo--]Moderation: Codebox.[/size]
🇺🇦 Glory to Ukraine!
Reply #188
Without nullsamples, I guess?
Reply #189
it means that file not contain null samples??? or there must by CRC for this tracks without nullsamples??? I don't undderstand
Reply #190
There are two ways in which EAC can calculate CRCs.  This has no effect on the data that is ripped.
I take it the first pair listed is for the data as a single-file image?
Reply #191
Exactly.
Also, in the first column are CRCs from the audio with the null samples. In the second column are CRCs of the audio without the null samples.
Reply #192
The null samples for CRC calculations applies to null samples (as a stereo pair) anywhere within the track, not just at the beginning or end.
Personally, I don't see the need to show the fourth column which I assume is a comparison against the log.  However, I'm curious to see what gets displayed if the checksums don't match at all or if they match a test CRC which may be different from a copy CRC.  I can pretty much figure this out for myself, but if you or anyone else can save me the trouble, I'd love to know.
Reply #193
Really? I wouldn't have thought so. It's a bit weird, does it have any practical advantage?
It doesn't compare the against the CRC in EAC's log, but maybe it is planned? Would be a nice feature to make an event from it that triggers something useful.
Reply #194
Oh, I guess it just checks for that setting in the log?  That's even less useful.
Re: practical advantage
I can't think of any.  I despise the idea of leaving out null samples in CRC calculations.
Reply #195
Why CUETools don't shows the summary information like "9 tracks is accuratley riped. 1 track is not in database" ???
Reply #196
AFAIK it doesn't analyze the EAC log at all.
But I think this would be a great way of improving CUE Tools' performance... for example: only check rips where the log says the read offset correction was "0", in case you want to quickly "correct" all your older rips, only those without offset correction would be analyzed and if possible they'd be corrected. Utilizing the AR drive offset database for cross-reference would be nice, too, by using the drive model's string.
Then a EAC-log-rewrite feature... after correcting a rip's offset the EAC log gets rewritten to match the CRC/AR-CRCs, change the "no use of null samples" line if desired and of course change the offset correction line...
Rips where the CRC in the log doesn't match both CRCs calculated by CUE Tools, could be marked as suspicious, and so on. This could be useful for example after you've had an incident of data corruption due to hardware failure.
See, there's so much more that could be implemented in this tool just by integrating EAC log analyzing... so much work.
Reply #197
Yes, the EAC log file is analyzed now in 1.9.4 update 1. There is a pop-up window making you choose a log file -- even if there is only one EAC log file in the directory.
CUE Tools now always computes CRC values for all tracks and compares them to the EAC log file. It also computes CRC values for the entire CD. Here's an example:
[Verification date: 02/06/2009 8:09:59 PM]
[Disc ID: 001426c9-00bb266b-910a740c]
Disk not present in database.
--      [D4B3D468]   [0941D83E]
01      [90C6CBFC]   [E10369D8]     CRC32
02      [03D82245]   [1B9DDD67]     CRC32
03      [BCEF4981]   [264486A1]     CRC32
04      [220D5D1A]   [C8631D4C]     CRC32
05      [23971A5D]   [D20A87F2]     CRC32
06      [FBEE9E98]   [26A4AF23]     CRC32
07      [4DCD9046]   [B909E371]     CRC32
08      [9FEB083A]   [3883A06F]     CRC32
09      [BAE5C697]   [70AE19C0]     CRC32
10      [2625C539]   [7F40B7A7]     CRC32
11      [3F9E6356]   [B3F07038]     CRC32
12      [AC331DC0]   [DEAD6636]     CRC32
Reply #198
What a satanic track
CUETools 2.1.6
Reply #199
Your files are ok. Each track is accurately ripped, as the log shows.
CRCs in the end of the log are only there to compare with EAC log file.
CUETools 2.1.6
