new in aac what should i do to get cd quality
Reply #51 – 2008-10-06 23:08:25
' date='Oct 6 2008, 19:55' post='591995']Nero q 0.75 (~300 kbps). I wonder if you guys hear the cymbals and drums smearing issues you talk about with this Nero setting, taking into account that LAME -V0 is not enough in some cases... The AAC standard has some extra tools compared to MP3, and different sizes of the long/short blocks which reduce the pre-echo effect, which translates in the smearing that you talk about. In other words, it is not the bitrate the one that makes this possible. That "eig" sample, is a good example that even higher bitrates struggles. Speaking of high bitrates, i brought Trivium's new album today and for some reason i could ABX one of the tracks at V2 and V0 LAME 3.97 -V0 --vbr-new foo_abx 1.3.3 report foobar2000 v0.9.5.5 2008/10/06 22:27:58 File A: C:\Rips\Trivium - Shogun\10. Like Callisto To A In Heaven.flac File B: C:\Temp\q 55\Trivium - Shogun\10. Like Callisto To A In Heaven.mp3 22:27:58 : Test started. 22:28:13 : 01/01 50.0% 22:28:23 : 02/02 25.0% 22:28:31 : 03/03 12.5% 22:28:37 : 04/04 6.3% 22:28:44 : 05/05 3.1% 22:28:52 : 06/06 1.6% 22:28:57 : 07/07 0.8% 22:29:05 : 08/08 0.4% 22:29:09 : 09/09 0.2% 22:29:25 : 10/10 0.1% 22:29:32 : 11/11 0.0% 22:29:42 : 12/12 0.0% 22:29:57 : 13/13 0.0% 22:30:02 : 14/14 0.0% 22:30:06 : 15/15 0.0% 22:30:50 : Test finished. ---------- Total: 15/15 (0.0%) For some reason the first few secends with the drum sounds abit odd. Also at V2, there is warbling on the guitar at around 0:13. I also did the test again to make sure that am not going insane . Also please ignore the subfolder name, i forgot to select my V0 encode folder when i was transcoding from flac to v0.foo_abx 1.3.3 report foobar2000 v0.9.5.5 2008/10/06 22:45:08 File A: C:\Rips\Trivium - Shogun\10. Like Callisto To A In Heaven.flac File B: C:\Temp\q 55\Trivium - Shogun\10. Like Callisto To A In Heaven.mp3 22:45:08 : Test started. 22:45:27 : 01/01 50.0% 22:45:39 : 02/02 25.0% 22:45:50 : 03/03 12.5% 22:45:57 : 04/04 6.3% 22:46:05 : 05/05 3.1% 22:46:16 : 06/06 1.6% 22:46:35 : 07/07 0.8% 22:46:46 : 08/08 0.4% 22:46:57 : 09/09 0.2% 22:47:02 : 10/10 0.1% 22:47:10 : 11/11 0.0% 22:47:16 : 12/12 0.0% 22:47:29 : Test finished. ---------- Total: 12/12 (0.0%) The first few secends do still sound odd on the drums. Also this file weighs at 295kbps and still not transparent. I really don't get it, i got mediocre audio hardware. I only got a Soundblaster Audigy SE and pair of Sennheiser HD 215 headphones.
