Topic: Are APE2 tags ok? (Read 4581 times) previous topic - next topic
Are APE2 tags ok?
There seem to be lots of warnings NOT to use ID3V2 files (although they have always worked fine with me). How about APE2 tags, are they fine?
Are APE2 tags ok?
yes they are perfect.
ape tags for mac
ape tags for mpc
ape tags for mp3
ape tags for everything
Are APE2 tags ok?
is it not possible to view ape tags in foobar?
Are APE2 tags ok?
hm. i think for mpc, mac and mp3 it works perfectly
but id3v2 doesn't work.
Are APE2 tags ok?
foobar has no probs with ape2 - certainly not the latest build 28
Are APE2 tags ok?
So how come, when I start playing a track in foobar it only displays "Track01.ape"???
Do I need to activate it somehow
I used ape1 tags to tag my ape audio files
Are APE2 tags ok?
You probably need to selected the file and:
right-click -> database -> Reload info from file
Are APE2 tags ok?
Thank you Jan S
Are APE2 tags ok?
Is it possible to apply APE2 tags to *.ape audio files?
Are APE2 tags ok?
I am now trying to at the --track value to all my audio tracks using tag frontend.
The only way I know how to do this is by typing in "--Track 01" in "Other Options".  This will add "01" to the first tag.
This adds "01" to all tracks.  Will I have to add a track number individually?  As this will be very time consuming.  Is there no automated way, so the track number increments by 1 each time???
Are APE2 tags ok?
How does "--trackinc" work?
I typed in "--trackinc" and nothing happened.  I checked the value for "Track" and it was still blank!!!!
Are APE2 tags ok?
I figured out how to apply APE2 tags to ape files!
I am assuming no one knew how to do this as I got no replies to this question, or were you waiting for me to figure it out for my self?
Anyway, I still have not figured out how to apply auto incrementing numbers to selected tracks.  I think I need to use "--trackinc" but dont know how.
Please help
anyone
Are APE2 tags ok?
Anybody know how to configure APE tags on MPC's with CDex..
thanks
Are APE2 tags ok?
 I was talking about APEv2 tags on ape files, not mpc
Are APE2 tags ok?
I know.
However my question remains...
APE tags on MPC anyone?  I know how with EAC, does CDex support this somehow?
Are APE2 tags ok?
I know.
I do Apologies
I dont use CDex, so I wouldnt know how to use the tags.  I use speek's tagging frontend for case's tag.exe
Are APE2 tags ok?
The same way as with EAC, just use CDex variables.
Add something like this:
--artist "%a" --title "%t" --album "%b" --year "%y" --track "%tn"
to command line, it will automatically write ape2 tags.
BTW with mppenc 1.15, you can encode w/o temp wavs (on-the-fly).
Are APE2 tags ok?
Use both --track 1 and --trackinc. But you only need this if your filenames don't have tracknumbers, if they do you should just use correct scheme and let Tag read values from path.
Are APE2 tags ok?
I must have tried every possible combination with --track and --trackinc and 1 except that one
Oh well, thats for solving that little problem for me Case
