Topic: KUNG-FOO by Br3tt (Read 186518 times) previous topic - next topic
KUNG-FOO by Br3tt
Reply #75
core, go into file prefrences and go to columns ui, then go to the filter tab, and make sure edge style is set on "none" (near the bottom right)
Wow... so long searching for a easy thing
Thx a lot
KUNG-FOO by Br3tt
Reply #76
nice config, thx Br3tt
but what's wrong with rating? :/
Firstly, thank you so very much for this config!!!
It`s very strange, but I have the same problem and I`ve tried to reinstall windinds 2 font (I use Win.Vista)
Also, every time, then I restart foobar, it`s returns to the first position (elplaylist and track info).... so, but I like more third position (there can see three panels), how can I fix that?
Many thanks Falstaff !!!!
Hello :-)
I have the same problem (i use windows vista x86 (default this font is installed)). Falstaff can you help fix this problem.
KUNG-FOO by Br3tt
Reply #77
Ok i'm near the goal with my customization of your foo config!
I wanna know what you people are thinking about it? All blue... cause I love blue
Many things need some adjustement like the group header but I'll make it in time
Here it's!
KUNG-FOO by Br3tt
Reply #78
Here it's!
[a href="http://img337.imageshack.us/my.php?image=sanstitre2rv3.jpg" target="_blank"]
KUNG-FOO by Br3tt
Reply #79
good mod, but this blue is a little too much flashy, i prefer a smooth blue ligther, but tastes and colors ...
Yep but the color depend on screen adjustement too! For me it's dark and smooth
I wil maybe do a another one with different color for each filter tab (artist; genre) & for the play mod =)
Here's the finished blue version ->
KUNG-FOO by Br3tt
Reply #80
First of all, great script! I like it very much, but...
I have problems with the rating symbols like some of the people that posted above. I decided to debug the situation because I have all the fonts properly installed (Wingdings, Wingdings 2, Wingdings 3, etc.), but all I get are box-like characters. I tried messing with the 'Playlist Settings' under 'Track list' where the Wingdings characters are used to show the ratings of each song. I found out that if I changed the font (to Tahoma for example) the symbols were still not showing properly and I still got the darned boxes. So I returned to 'Wingdings 2' and decided to mess with the $char function... and it turns out that whenever I enter a number above 126 (for example: $char(127) or $char(166)) I still get the boxes. I don't know if it is a problem with the $char function or a component that I'm using, so I'm posting a list of all the components I have installed:
Core (2008-08-04 01:16:48)
    foobar2000 core 0.9.5.5
foo_abx.dll (2008-05-24 18:23:50)
    ABX Comparator 1.3.3
foo_albumlist.dll (2008-08-04 01:04:30)
    Album List 4.3
foo_cdda.dll (2008-06-25 20:18:24)
    CD Audio Decoder 2.1.3
foo_chronflow.dll (2008-04-14 00:16:00)
    Chronial's Coverflow 0.3.0
foo_converter.dll (2008-08-04 01:04:34)
    Converter 1.1.2
foo_convolve.dll (2006-06-26 22:52:14)
    Convolver 0.3
foo_dsp_crossfader.dll (2008-07-25 04:59:28)
    Gapless Crossfader 0.3.4.1 (Intel SSE)
foo_dsp_delta.dll (2006-03-21 17:16:22)
    LPCM <--> delta-PCM converter 0.1.1
foo_dsp_ssrc.dll (2006-08-15 17:00:00)
    Resampler DSP (SSRC) 0.57 SSE2
foo_dsp_std.dll (2008-08-04 01:10:54)
    Standard DSP Array 1.0
foo_dsp_vlevel.dll (2006-07-19 23:37:29)
    VLevel 20060324.0
foo_facets.dll (2008-09-01 10:58:16)
    Facets 2008-02-25
foo_fileops.dll (2008-06-07 22:14:56)
    File Operations 2.1
foo_freedb2.dll (2008-06-07 22:15:10)
    freedb Tagger 0.6
foo_input_monkey.dll (2008-05-31 22:39:34)
    Monkey's Audio Decoder 2.1.3
foo_input_std.dll (2008-08-04 01:04:56)
    Standard Input Array 1.0
foo_playcount.dll (2008-07-09 22:00:12)
    Playback Statistics 2.1.5
foo_quicktag.dll (2008-05-01 19:39:02)
    Quick Tagger 1.0.1
foo_rgscan.dll (2008-06-11 21:30:18)
    ReplayGain Scanner 2.0.8
foo_ui_columns.dll (2008-07-22 23:20:48)
    Columns UI 0.3.4.1
foo_ui_std.dll (2008-08-04 15:09:14)
    Default User Interface 0.9.5
foo_uie_albumlist.dll (2008-08-08 12:30:44)
    Album list panel 0.3.1
foo_uie_elplaylist.dll (2008-09-06 21:25:10)
    ELPlaylist 0.6.2.0(beta)
foo_uie_graphical_browser.dll (2008-04-19 22:37:53)
    Graphical Browser rev015
foo_uie_lyrics.dll (2007-03-12 16:32:45)
    Lyric Show Panels 0.3.1.1
foo_uie_panel_splitter.dll (2008-05-31 12:19:42)
    Panel Stack Splitter 0.3.4(alpha)
foo_uie_playlists_dropdown.dll (2007-09-29 03:03:32)
    Playlists Dropdown 0.6 alpha 4
foo_uie_quicksearch.dll (2007-05-18 13:31:10)
    Quick Search Toolbar 2.8l
foo_uie_trackinfo.dll (2008-09-01 11:12:07)
    Track info panel 0.8
foo_uie_trackinfo_mod.dll (2007-01-05 13:36:20)
    Track info panel mod 0.8.0 beta [Jan  5 2007 - 13:36:12]
foo_uie_vis_channel_spectrum.dll (2008-05-18 03:02:12)
    Channel Spectrum panel 0.17.2
foo_uie_vis_peakmeter_spectrum.dll (2008-04-19 20:18:50)
    Peakmeter Spectrum Visualisation 0.2.0.0 beta
foo_uie_wsh_panel.dll (2007-07-21 20:16:08)
    WSH Panel (uie) 0.7.2
foo_unpack.dll (2008-08-04 01:04:20)
    RAR reader 1.1
    ZIP/GZIP reader 1.0
foo_utils.dll (2008-02-08 23:26:58)
    Playlist Tools 0.6.2 beta 6
foo_whatsnew.dll (2008-08-30 15:45:00)
    Feature Watcher 1.0.6
I hope someone out there could help me get my neat rating characters showing.
KUNG-FOO by Br3tt
Reply #81
hello! good, perfect almost setup Br3tt. good work. but 3 things bothers me: i can't get play count to work  -in ibiza all was ok (i am using my ibiza foobar folder for kung-foo). another thing is how to show vbr bitrate not average
 // Tech. Infos
$font(LCDMono,8,normal)
$drawtextex($caps2(%__codec%)' - '$get(bit.rate)' - '%__samplerate%' Hz - '$get(channel.type),296,$sub(%_height%,35),$sub(%_width%,380),20,$get(botscr.green.color),hleft vtop)
%bitrate% isn't working  . and last thing rating not showing propertly.    thanks in advance!
KUNG-FOO by Br3tt
Reply #82
someone mind uploading the WSH plugin? the sites with it are all under maintanence =(
KUNG-FOO by Br3tt
Reply #84
thanks mate! but i cant use rapidshare my ISP uses dynamic ip so rapidshare detects my ip having downloaded a file already ><
managed to download it somewhat. but sighh wsh crashes on my athlonxp =(
KUNG-FOO by Br3tt
Reply #87
I've got the same problem, and I have that font installed. I've investigated it further and found out that this config displays Windings characted up to $char(127), but no further. Any character with bigger number gets rendered as that kind of square. Is it a ELPlaylist bug?
Also, can someone point to me the portion of the code where the flip switches (repeat track, shuffle) are described? I'd like to change "shuffle tracks" to "shuffle albums".
KUNG-FOO by Br3tt
Reply #89
Hey Br3tt any chance you can/or will support embed images? for cover art. That would be nice.
Any chance this can be done?, and would you implement this? Or if anyone else knows?
embedded images display is only possible in ELplaylist for Kung-Foo config, and this is not the only way where covers are displayed in the config, so i'll not support it in my config.
KUNG-FOO by Br3tt
Reply #90
Would it be possible to make further versions come with two (or more) colour schemes (like FofR's PUI config did)? Because I see you're planning to make v1.2 completely black, while I'd love to at least keep that white border and panel (like in v1.1) or even have a completely white version.
KUNG-FOO by Br3tt
Reply #91
white border color scheme will be released cause it's the default theme, the black one is just an add
KUNG-FOO by Br3tt
Reply #92
v1.2a released, check the 1st post to grab it on DA
screenshot:
[a href="http://xs232.xs.to/xs232/08403/kung-foo-1.2a848.png" target="_blank"]
KUNG-FOO by Br3tt
Reply #93
screenshot:
it's very cool,THX!
KUNG-FOO by Br3tt
Reply #94
cool update, testing now
KUNG-FOO by Br3tt
Reply #95
Really nice update.  I'd generally shy away from the darker scheme and stick with the lighter one, but in this case it's the exact opposite.  The dark scheme is great.
KUNG-FOO by Br3tt
Reply #96
Really nice update.  I'd genuinely shy away from the darker scheme and stick with the lighter one, but in this case it's the exact opposite.  The dark scheme is great.
thank you, and what about some TRANSPARENCY background , just like that
[a href="http://xs232.xs.to/xs232/08404/kf-transp385.png" target="_blank"]
KUNG-FOO by Br3tt
Reply #97
TRANSPARENCY background looks very good.
Are there any plans to create more color schemes? I like the Kung-Foo very much, its the best designed scheme I would say (like Ibiza was before).
In terms of readability I dont like the black font on brown background because its somethime difficult to read. Therefore I would like to have a more whiter scheme :-)
KUNG-FOO by Br3tt
Reply #99
Hey Guys
Great config but i have a problem. Whenever i try to play a mp3 the foobar crushesh  any idea why ?? and i dont know how to make a dump file or something like that
