Topic: FLAC-Playback using Cuesheet Index Points ... (Read 2182 times) previous topic - next topic
hi,
anybody thinking about a flac-playback plugin for winamp/implementation for foobar2k which allows usage of index points as defined in a (previously imported cue-sheet), now that flac has that fabulous "CUESHEET"-block? mp3cue sucks and has some serious flaws in it ...
bye
in what way do you want to use these indexes?
I think about implementing access to individual tracks.
that's exactly what i'm talking about. if you have one big wave-file (-> flac) representing the cd-image and one cuesheet, it should be possible to select each track individually and directly. there is a tool from guerillasoft called mp3cue which does exactly that, but it needs an external cuesheet to process, and this is an unnecessarily extensive approach, since flac stores the cuesheet data inside...
would you realize this seeking ability in a separate plugin (winamp) or just for the decoding process on command-line?
I'll add it to the winamp2 flac plugin
