Topic: My Columns UI config · FooSune (Read 190456 times) previous topic - next topic
Reply #50
very nice update
is it possible to add a 5 blip rating icon between  title | artist  in the tracklist ?  and/or how would i go about doing that myself?
Reply #51
Thank you very much for adding the album art thing. Works great. Beautiful config.
Reply #52
Having some problems installing it. The minute i import the .fcl file foobar, vista says that foobar isn't responding and the program crashes.
i don't have the slightest idea what i'm doing wrong...
Reply #53
^ umm.. no idea. I was thinking it could be the wsh panels component, but I think it would crash on startup, not when loading the fcl. or maybe I'm mistaken
you could post your crash log and someone who knows about this stuff (not my case) could help you, maybe
Reply #54
Create text file: this one is for when I find the lyrics on sonmeanings, I can just copy paste them in a new text file this button will create (so I don't have to go to the folder, create it, name it, etc)
With word pad, create a new document and write this:
start notepad "C:\Music\Lyrics\%~n2.txt"
^with the path where you store your lyrics instead of this one.Save it as "open txt.bat" in your lyrics folder
Add a new service called: "Open Lyrics File" (no quotes), and in the path:
C:\'Music'\'Lyrics'\'open txt.bat' "$replace(%title%, ,+)" "%path%" (again, the with the path of your lyrics folder)
And that's it. when you click the button, it will create a txt named as the filename of the track selected. you can paste the songmeanings lyrics there, and when you refresh the lyrics the text should display
I've done this and still doesn't work, what am I doing wrong?
Reply #55
If the button does nothing when you click, it's because the service doesn't exist, or you've entered it wrong. Another thing would be that it launches the service but it doesn't find the .bat file, or something.
when you enter the service in the "run services" dialogue, you first have to fill in the service properties (label and path), and after that, click add. Otherwise it won't store the service in the list. (might seem obvious, but maybe it's what you're doing wrong?)
Reply #56
where can i find the crashlog? already searched for it, but didn't find it
Reply #57
Amazing config - I think I'll be using it for a long time.
EDIT: I'm having sort of a weird problem.  Whenever I middle-click an item in the left panel, it doesn't go to my playlist.  As a matter of fact, it seems the only way to add anything to my playlist via that panel is to select the "*BROWSER*" playlist and then left-click an item, which automatically places it in that playlist.
Do you have any idea what setting I need to change to fix this?  I generally use "Library view" as my default playlist, FYI.
ANOTHER EDIT: It looks like I can middle-click and add to playlist by using the Album List panel instead.  Will the browser always automatically add whatever's selected to the playlist, or is there a way around it?  I really prefer it to the Album List panel.
Reply #58
thanks
about your question, I didn't really configure the behaviour of the browser or the album list components.. and if I had they wouldn't have been exported with the fcl file, I think. Everyone uses foobar in their own way, I just "provided" the interface, but you have to adapt it to the way you want it to behave.
Just go to preferences > media library > browser  and there you have a couple of settings you can change, only for double-click, not for middle-click, though. Edit/send to active playlist (or current playlist) might be what you want.
Reply #59
great stuff
two humble requests:
1. full screen mode with just album art and basic song info
2. rating support
Reply #60
I've got some room left in my EL playlist. Is there an easy way to enlarge album art (the ones when expanded) or would this become a rather disfficult part?
Reply #61
All is working now except the tabs don't have the proper formatting, they just stay gray, and yes, i inserted the code.
Reply #62
I'd like to second the request for ratings integration.  That's really the only thing this is missing.
Reply #63
I'm using, and I love it. I made a few mods to personalize it, but the base design is top notch.
Reply #64
Great work on this config! I'm overall very pleased with it. The only gripe I have is the lack of a database search demo integration. Could you put it on the same place as the Quicksearch, give it it's own icon, or tell me how to do it myself?
Thanks for an overall excellent configuration!!!
Reply #65
Could you tell me a little bit more about your customization? Would be very interesting as I'm also thinking about some mod for coverflow and albumart viewer.. What have u done and could you post your config?
By the way, just an idea for a more sophisticated Statusbar that I've picked up somewhere in this forum..
// set colors
$puts(col_paused,¬00c8ff¬)
$puts(col_streaming,¬008800¬)
$puts(col_cue_file,¬880000¬)
$puts(col_progbar_symb1,¬ee8888¬)
$puts(col_progbar_symb2,¬550000¬)
$puts(col_time_remaining,¬000000¬)
$puts(col_bitrate,¬00a3cc¬)
$puts(col_bitrate2,¬00a8ee¬)
$puts(col_stereo,¬808080¬)
// set variables
$puts(text_streaming,'Streaming')
$puts(text_listened_for,'Listened for:')
$puts(text_cue_file,'Cue File')
$puts(text_paused,'PAUSED')
$puts(text_time_remaining,[%_time_remaining%])
$puts(spacer_symb,' ')
$puts(spacer_width,2)
$puts(progbar_symb1,'ι')
$puts(progbar_symb2,'ι')
$puts(progbar_length,90)
$puts(text_bitrate,$get(col_bitrate)$if2($pad(%__bitrate_dynamic%,3)¬808080¬' kbps',$if2(%__bitrate%' kbps'¬¬,)))
$puts(text_extrainfo,[%__extrainfo%])
// add colors and formatting
$puts(spacer,$repeat($get(spacer_symb),$get(spacer_width)))
$puts(text_streaming,$get(col_streaming)$get(text_streaming)¬¬)
$puts(text_listened_for,$get(col_streaming)$get(text_listened_for)¬¬)
$puts(text_cue_file,$get(col_cue_file)$get(text_cue_file)¬¬)
$puts(text_paused,$get(col_paused)$get(text_paused)¬¬)
$puts(text_time_remaining,$get(col_time_remaining)$get(text_time_remaining)¬¬)
$puts(progbar_symb1,$get(col_progbar_symb1)$get(progbar_symb1)¬¬)
$puts(progbar_symb2,$get(col_progbar_symb2)$get(progbar_symb2)¬¬)
// streaming
$puts(streaming,
$if(%_time_total%,,
$get(text_streaming)$get(spacer)
// cuefile
$puts(cue_file,
$if(%__cue_audiotype%,
$get(text_cue_file)$get(spacer)
// codec
$if(%__codec%,
$if($stricmp(%__codec%,musepack),$puts(codec,'MPC'),
$if($stricmp(%__codec%,vorbis),$puts(codec,'Ogg'),
$get(spacer) $puts(codec,%__codec%)
//If no codec tag and not streaming, read file extention
$if($and(%_time_total%,$not(%__codec%)),
$puts(codec,$upper($ext(%_path%)))
// bitrate
$puts(bitrate,$get(spacer)$get(text_bitrate))
$if(%__mpc_profile%,
$puts(bitrate,$get(spacer)%__mpc_profile%$get(spacer)$get(text_bitrate))
// extrainfo
$puts(extrainfo,$get(spacer)$get(text_extrainfo))
$if($stricmp(%__codec%,MP3),
$if(%__extrainfo%,,
$puts(extrainfo,$get(spacer)'CBR')
$if(%__mpc_streamversion%,$puts(extrainfo,$get(spacer)'sv'%__mpc_streamversion%))
// samplerate
$puts(samplerate,
$if(%__samplerate%,
$get(spacer)$cut(%__samplerate%,2)'kHz'
// channels
$puts(channels,
$if(%__channels%,
$get(spacer)$ifgreater(%__channels%,2,%__channels%ch,$ifgreater(%__channels%,1,Stereo,Mono))
// mp3 stereo mode
$puts(stereo_mode,
$if2( $get(col_stereo)'['$caps(%__mp3_stereo_mode%)']',)
// Replay Gain
//track gain
$puts(rpg,
$if(%__replaygain_track_gain%,
$get(spacer)
' TGain:'$cut(%__replaygain_track_gain%,5)'dB'
$if(%__replaygain_album_gain%,
$get(spacer)' AGain:'$cut(%__replaygain_album_gain%,5)'dB'
// progress bar
// (checking total because of streaming)
$puts(progress_bar,
$if(%_time_total_seconds%,
$get(spacer)$get(spacer)
$progress2(%_time_elapsed_seconds%,%_time_total_seconds%,$get(progbar_length),$get(progbar_symb1),$get(progbar_symb2))
// progress %
$puts(progress_%,
' '¬808080¬$pad_right($muldiv(%_time_elapsed_seconds%,100,%_time_total_seconds%),3)¬808080¬'%'¬¬' '
// 'Listened for:'
// (used for streaming)
$puts(listened_for,
$if(%_time_total%,,
$get(spacer)$get(spacer)$get(text_listened_for)
// time
$puts(time,
$get(spacer)
' '[%_time_elapsed%]
$if(%_time_total%,
'/'%_time_total%' ' $get(spacer)$get(spacer)$get(spacer)
'Remaining Time: '$get(text_time_remaining)
// paused
$puts(paused,
$if(%_ispaused%,
$get(text_paused)
// create string
$get(streaming)
$get(cue_file)
$get(codec)
$get(bitrate)
$get(extrainfo)
$get(samplerate)
$get(channels)
$get(stereo_mode)
$get(progress_bar)
$get(progress_%)
$get(spacer)$get(listened_for)
$get(time)
$get(spacer)$get(rpg)
//Right adjust from now on
$char(9)
$get(paused)
Reply #66
  • I got rid of the panels I don't use (Which is basically everything in the left panel, I only use the playlist view).
  • I removed the Lyrics buttons from the bottom.
  • Instead of the forum button, I made the button run Coverdownload service
  • I made a compact view that will hide the playlist and only show the top playing part.
The left arrow button toggles between compact view.
Reply #67
[quote name='tgpo' date='Aug 20 2008, 07:58' post='583665']
[quote name='Onkel Andy' post='583605' date='Aug 19 2008, 19:21']
    [/quote]
    which one do you use?
    this is how the search bar is now:
    toggle it on/off | the settings | type ur search here
    now I want it to be like this:
    the settings (with the image from the toggle onoff | type ur search here
    ho to do that?
    great config btw.
Reply #70
hm, how do you add the picture to the album? I don't seen any way  i suck
Install Album Art Downloader.  Install the Run Services plugin.  Add the following as a Run Service named Coverdownload:
"C:\Program Files\foobar2000\AlbumArtDownloader\AlbumArt.exe" "%artist%" "%album%" "$replace(%path%,\%filename_ext%,)/folder.jpg"
Add this as a button:
$button(72,16,0,0,27,20,images\FooSune/BUTTONS\foobarforum.png,images\FooSune/BUTTONS\foobarforum_over.png,Coverdownload,)
You will need to play with the placement to make the button appear where you want it.
In a nutshell this button will launch the Album Art Downloader program, feed it the artist info it needs, and allow you to download the cover art you need.  It will automatically place the file in the correct folder, and the playlist will autoupdate with the new artwork.
Reply #71
[!--sizeo:1--][span style=\"font-size:8pt;line-height:100%\"][!--/sizeo--]Moderation: Removed redundant fullquote of the previous post.[/size]
thx but it doesn't seem to work, when i press the button nothing happens, same for rigthmouse/runservice/coverdownload
it works now, albumart downloader was in another path! thanks man
Reply #72
thx for this. its working fine here too.
Unfortunately since i'm using this skin, I get a run time error r625(?) when I close foobar. one of the components might cause this. any ideas about this error? it also does not happen always...
ps: i'm using vista 64
Reply #73
In Vista at import fcl an error occured:
Сигнатура проблемы:
  Имя события проблемы:    APPCRASH
  Имя приложения:    foobar2000.exe
  Версия приложения:    0.9.5.5
  Штамп времени приложения:    48962e34
  Имя модуля с ошибкой:    StackHash_6af1
  Версия модуля с ошибкой:    6.0.6000.16386
  Штамп времени модуля с ошибкой:    4549bdc9
  Код исключения:    c0000374
  Смещение исключения:    000af1c9
  Версия ОС:    6.0.6000.2.0.0.768.3
  Код языка:    1049
  Дополнительные сведения 1:    6af1
  Дополнительные сведения 2:    bc9a2cb8e4e33a980729722f77b82616
  Дополнительные сведения 3:    df0c
  Дополнительные сведения 4:    db614412a2e78e34aa7fca3a353a39d3
Прочтите заявление о конфиденциальности:
  http://go.microsoft.com/fwlink/?linkid=50163&clcid=0x0419
P.L.U.R.
Reply #74
I use FooSune, but FB2k now Requires 250MB of Memory, and its extremly inresponsive.
I think there is some Spaghetti code in a Component.
