Topic: My Columns UI config · FooSune (Read 190457 times) previous topic - next topic
Reply #150
Could someone upload foo_cwbowron, the main page for the components has closed down.
Reply #151
yes PLEASE could somebody do this. I've been scouring the internet looking for foo_browser.dll and foo_cwbowron.dll as they have been taken down by the author. I managed to find foo_browser.dll hidden away in another person's config .zip but have been unable to find foo_cwbowron.dll as any mention of it only links back to the original source which has been taken down!
For anyone else in my situation I've uploadad a copy of foo_browser.dll here.
Could someone please do the same for foo_cwbowron.dll? Thanks in advance.
Reply #153
thanks!
Reply #154
First off; thanks a million to Sune and supporters of his work!. Great stuff!
I'm pretty new to footweaking so mayb i'm overlooking something but i'm gonna have to ask you guys anyway.
I seem to be missing some options that, seeing the installation instructions or messages on the board, should be present.
For my albumcover adjustments: When I go to Columns UI -> Layout -> 2nd Pannel Stack Splitter -> Configure -> Covers. I can't further configure Covers and there's no textbox below where I can change the image path.
For my album list color adjustments: When I go to Media Library -> Album List Panel -> Advanced Tab. I see no options for altering color schemes. I'm using the Directory structure view.
I Hope someone can help me with this cuz when it's fixed all will be well!
Here are the components i've got installed:
Core (2008-09-22 14:31:58)
    foobar2000 core 0.9.5.6
foo_albumlist.dll (2008-09-22 13:45:20)
    Album List 4.3
foo_audioscrobbler.dll (2008-05-13 15:36:16)
    Audioscrobbler 2.3.1
foo_browser.dll (2009-06-15 13:47:26)
    Music Browser 1.2.3b [Mar 23 2007 - 16:52:56]
foo_cdda.dll (2008-09-22 19:41:36)
    CD Audio Decoder 2.1.3
foo_converter.dll (2008-09-22 13:45:16)
    Converter 1.1.2
foo_cwbowron.dll (2009-06-15 16:55:32)
    Album Art Browser 0.0.5 [Jul 23 2007 - 08:27:55]
    Startup Actions 0.0.2 [Jul 23 2007 - 08:27:55]
foo_dirwatch.dll (2007-12-09 00:29:50)
    Directory watcher 0.2 beta 3
foo_dsp_std.dll (2008-09-22 13:45:24)
    Standard DSP Array 1.0
foo_input_std.dll (2008-09-22 19:42:04)
    Standard Input Array 1.0
foo_rgscan.dll (2008-06-11 20:30:18)
    ReplayGain Scanner 2.0.8
foo_ui_columns.dll (2009-05-21 23:15:16)
    Columns UI 0.3.7.3
foo_ui_std.dll (2008-09-22 13:45:40)
    Default User Interface 0.9.5
foo_uie_albumlist.dll (2009-03-28 17:14:17)
    Album list panel 0.3.4
foo_uie_elplaylist.dll (2009-06-05 22:01:32)
    ELPlaylist 0.6.5.3.3(beta)
foo_uie_explorer.dll (2008-09-27 10:58:30)
    Explorer Tree 1.04.6c
foo_uie_lyrics.dll (2008-12-12 11:39:20)
    Lyric Show Panel 0.3.3.9 [Dec 12 2008 - 17:39:01]
foo_uie_lyrics_panel.dll (2007-08-17 23:56:36)
    Lyrics panel 0.35
foo_uie_panel_splitter.dll (2009-06-07 22:36:54)
    Panel Stack Splitter 0.3.8(alpha)
foo_uie_playlists_dropdown.dll (2009-05-16 19:10:32)
    Playlists Dropdown 0.7.2
foo_uie_quicksearch.dll (2007-05-18 13:31:10)
    Quick Search Toolbar 2.8l
foo_uie_trackinfo.dll (2009-06-15 13:14:40)
    Track info panel 0.8
foo_uie_trackinfo_mod.dll (2007-01-05 14:36:20)
    Track info panel mod 0.8.0 beta [Jan  5 2007 - 13:36:12]
foo_uie_vis_peakmeter_spectrum.dll (2008-04-19 20:18:50)
    Peakmeter Spectrum Visualisation 0.2.0.0 beta
foo_uie_wsh_panel.dll (2007-07-21 20:16:08)
    WSH Panel (uie) 0.7.2
Reply #155
Does anyone have a link for foo_browser 1.2.2c?
Reply #156
mous00, use Filter instead. It works better/faster/more options, plus it is built-in to Columns UI now.
Reply #157
Thanks Harun, where would I get Filter and would it work with this FooSune config? Or is there some editing required?
Reply #158
I like this config, it seems to be fairly clean, yet functional and looks nice.
Anyone help with the "filter" replacement for foo_browser?
Reply #159
When I try to load the config it says "layout import was aborted" because the following required panels are not installed:
Browser Panel
I take it that's foo_browser.
Does anyone have foo_browser they can share?
Reply #160
nevermind, found foo_browser, config is loaded.
now to configure it.
Reply #161
    Album List 4.3
    Converter 1.1.2
    Columns UI 0.3.7.3
    Lyrics panel 0.35
Anyone? Some ideas? Have not managed to find it out for myself yet.
Reply #162
Would some one be so kind and UP the entire component pack, since ive tried to find all of them with no luck
Reply #164
Yes !
Does someone knows where we can fond "Browser Panel" , the link is broken !
Thanks for help to try this theme !
Reply #165
Pretty good work and my FooSune is working!
Here are my components
Core (2009-04-25 16:47:24)
    foobar2000 core 0.9.6.5
foo_albumlist.dll (2009-04-25 16:45:44)
    Album List 4.3.1
foo_browser.dll (2009-08-16 11:42:33)
foo_cdda.dll (2009-04-25 16:45:30)
    CD Audio Decoder 2.1.4
foo_converter.dll (2009-04-25 16:45:38)
    Converter 1.2.1
foo_cwbowron.dll (2009-08-15 23:28:03)
foo_dsp_std.dll (2009-04-25 16:45:44)
foo_input_std.dll (2009-04-25 16:45:20)
foo_rgscan.dll (2009-04-25 16:45:16)
foo_run.dll (2009-06-07 15:15:18)
    Run services 0.3.7
    Columns UI 0.3.7.3
foo_ui_minilyrics.dll (2009-07-21 17:23:06)
foo_ui_std.dll (2009-04-25 16:45:54)
foo_uie_albumlist.dll (2009-08-15 23:11:28)
    Album list panel 0.2.3 beta
foo_uie_elplaylist.dll (2009-08-13 22:27:36)
    ELPlaylist 0.6.5.4(beta)
foo_uie_trackinfo.dll (2008-11-01 13:24:02)
foo_uie_trackinfo_mod.dll (2009-08-15 23:11:50)
running with foobar 0.9.6.5 (Final) with last.fm software under Win7 64bit
components download
Did anybody know how can i can fix the "the spectrum analyzer at the top does not resize " to my personal width? My Screen Resolution is 1440 * 900 (Fullscreen).
And my second problem http://www.hydrogenaudio.org/forums/index....mp;#entry627924
can someone upload the fixed images? these are also not correct http://www.hydrogenaudio.org/forums/index....st&p=629190
Reply #166
I just loaded everything and foobar crashed when I tried to import the .fcl file. Any ideas? The crash report was huge but maybe this part is important:
Crash location:
Module: foo_uie_wsh_panel
Offset: 738Eh
Reply #167
This config very good, but...
Where I go wrong?
Reply #168
Hello all and Thanks to Sune for this amazing upload. I installed it followeing all steps you mentioned. But there's some problems I can't fix yet. Yes, I've read the whole topic and tried lot of things but those problems still there. I have this screenshot for show those problems:
As I see this post is old but I hope some one to help me fixing those problems. Thank you all and Sune for making me find a definitive skin for my f2k.
Reply #169
Can someone tell me how to make the album thumbnails larger in the playlist view?
Reply #170
Would you be able to upload the missing components again?
Reply #171
I have the same problem with the display as in post 118 (Screen). I tried to update some *. dll files but still I can not solve the problem. Could someone give me advice on how to achieve comprehensive skin.
Reply #172
Hi, I'd love this skin; exactly what i'm looking for, but it seems outdated?
I've d/led all components except for music browser, which was deleted apparently. However, yet i get errors "not installed" when importing the FCL.
Browser panel
ALbum List
WSH Panel
Track Info
Playlists Dropdown
Help, please!
Re: My Columns UI config · FooSune
Reply #173
I just heard about FooSune at http://www.head-fi.org/a/foobar2000-appearance-customization-skins-themes-configs (I only started using foobar2000 less than a week ago).  It looks great, but there doesn't seem to be a way to download it.  The first link in the article brought me here and the second link takes me to deviantart.  While deviantart allows people to download FooSune, all the functionally important parts are stripped out, as per deviantart policies, and all that remains are .txt and image files.
Is there someplace else where FooSune cane be downloaded?
If not, is there some other way of making the borders around each component either disappear or become customizable insofar as color?  I've customized the foobar2k layout and color schemes as much as I can by tweaking and exporting  themes, but I'd still like to make the overall shell look nicer.  I'm a miracle worker with CSS, but CSS is no DLL.
