Topic: How do you use VorbisComment to remove tags? (Read 5409 times) previous topic - next topic
I don't see anything in the documentation.  I tried -t "MYTAG=", but that just leaves the tag without changing it.
I don't use vorbiscomment.exe any more. It has no documentation and the syntax doesn't quite seem to conform to what is listed when you type the -h command.
I think you are right that it used to have some sort of remove command, but that command no longer appears when you type -h. Logically it would seem to be '-r' but I don't know.
I now use tag.exe or mp3tag instead.
I need a command-line tool to integrate into a script.  Thanks for the tip about tag.exe!  I didn't know (or had forgotten) that it handles Ogg.
On my linux box, I run this command:
vorbiscomment -w -c /dev/null 01_music_with_bad_comments.ogg
For Windows machines, I supposed substituting "/dev/null" with any empty filename would work.
