Topic: FLACCL: CUDA-enabled FLAC encoder by Gregory S. Chudov (prev. FlaCuda) (Read 366816 times) previous topic - next topic
Reply #326
Intel® Core™ i7-3770, 8Gb DDRIII-1333, MSI R7770-PMD1GD5, Win7 HP x64
CUETools.FLACCL.cmd.exe -X -o nul --opencl-type GPU --opencl-platform "AMD Accelerated Parallel Processing" --fast-gpu test.wav
-0 = 750.56
-1 = 640.93
-2 = 608.70
-3 = 1164.92
-4 = 1108.60
-5 = 1006.79
-6 = 1067.87
-7 = 960.46
-8 = 761.45
-9 = 515.59
-10 = 395.81
-11 = 347.45
Reply #327
Hi, ..
recently installed Win7x64
and purchased 2x HD7970
but... Flaccl v0.4
does not work...
AMD drivers 12.6
Flaccl v0.3 works... but... no GCN, no Crossfire.
very small performance increase...?
cuetools.flaccl.cmd.exe --11 --task-size 64 --group-size 64 cd1.wav
C:\Users\jpc\Desktop\FLACCL\flaccl03>flaccl03.exe -8 --task-size 64 --cpu-thread
s 3 --group-size 64 cd1.wav
FLACCL#0.3, Copyright (C) 2010 Gregory S. Chudov.
This is free software under the GNU GPLv3+ license; There is NO WARRANTY, to
the extent permitted by law. <http://www.gnu.org/licenses/> for details.
Filename  : cd1.wav
File Info : 44100kHz; 2 channel; 16 bit; 01:05:14.1880000
Results   : 350.02x; 448997159 bytes in 00:00:11.1826396 seconds;
C:\Users\jpc\Desktop\FLACCL\flaccl03>flaccl03.exe -11 --task-size 64 --cpu-threa
ds 3 --group-size 64 cd1.wav
Filename  : cd1.wav
Results   : 379.22x; 433963131 bytes in 00:00:10.3215904 seconds;
crark v3.41 also does not work...
http://www.crark.net/
any ideas?
http://www.golubev.com/blog/
Reply #328
FLACCL is very hardware-dependant, because architectures were rapidly changing at the time it was written. First thing it does is tries to determine which hardware it runs on, and selects parts of code appropriate for that hardware.
I need to debug the general case for unknown hardware to increase the chances of it working on any new GPUs.
CUETools 2.1.6
Reply #329
i thought it was a Windows problem...
because cRARk for Linux has incredible performance increase HD7970 vs. HD6970
but cRARk for Windows does not even work. strange.
Reply #330
It seems that the --ignore-chunk-sizes option is missing which makes it impossible to use with foobar's default flac profile.
Is this just some missing functionality or is not needed with this version?
By the way, I read that the Nvidia 600 series aren't the fastest with flac-cuda I'm still very happy to see encoding speeds of 200-350 with my GTX670. Thanks!
Reply #331
Only 300x? Depends on the source format of course, but a GTX670 should reach 800x speeds even at -8. Try this:
-q -8 --verify --slow-gpu --task-size 32 --cpu-threads 2 - -o %d
Reply #332
Thanks! I'll certainly try them later this week.
Reply #333
Somehow after updating nvidia drivers to 306.23, flaccl 0.4 stopped working on GTX 570... this is just me?
EDIT: it says
Error: GetDeviceIDs failed: INVALID_VALUE
Reply #334
EDIT: it says
Works nicely with a GTX560Ti on Win7/32
Reply #335
So, can I hope that this will be worked around somehow, or should I stick to old drivers forever?
Reply #336
OK I see this project is dead. Then does anyone know what libraries and/or other files that are part of nvidia windows7 driver FLACCL make use of? So I'll be able to copy them, install new driver and then put old files in sandbox environment or overwrite new files. Or what files in driver package are opencl-related? Maybe someone have some info about GetDeviceIDs failed issue? From its name it looks like some general issue that can happen not only in flaccl.
Edit: I also did some googling and it looks like this problem indicates bug in opencl application
Reply #337
c:\Program Files (x86)\Utilities\CUETools_2.1.4>CUETools.FLACCL.cmd.exe Mustapha
.wav -o Mustapha.flac
FLACCL#0.4, Copyright © 2010 Grigory Chudov.
Filename  : Mustapha.wav
File Info : 44100kHz; 2 channel; 16 bit; 00:03:26.3470000
Error    : GetDeviceIDs failed: INVALID_VALUE
Windows 7 SP1 64 bit, Sapphire Radeon 5770 1 GB, Catalyst 12.8.
What can I do to make it work?
Reply #338
hlloyge
Hi. try this:
CUETools.FLACCL.cmd.exe --opencl-type CPU somefile.wav -o somefile.flac
Edit: of course this doesn't solves the issue but at least it works.
Reply #339
Yeah, it works, confirmed. Thank you.
Reply #340
My netbook has Nvidia ION graphic. The whole time I had to use 267.54 driver as flaccl refused to work with later versions always showing "Out of resource" error after encoding several files.
Today I tried the latest 306.97 version - with the same result.
Then I tried flaccl 0.3 from the command line - it worked!
I tried flaccl 0.4 from the command line - it worked, too! Though a little bit slower than 0.3.
I replaced 0.4 in Cuetools folder with 0.3 files - the same out-of-resource error but after 12 encoded files (before it were 4).
So I decided to say farewell to flaccl as dll and tried to use it as command-line encoder in Cuetools.
With these settings it works now!
BTW, my home computer has an ATI Radeon 5870 graphic card. After upgrading the processor to i5 3570K I don't use ATI opencl anymore - Intel 4000 graphic is faster :-)
Reply #341
I don't know why but FLACCL works again with the latest ATI Catalyst driver (12.10).
Reply #342
Because 12.9 fixed an issue from 12.4 that OpenCL runtime was broken, resulting in crash or incorrect results on some programs.
Reply #343
I've been using and testing FLACCL for some days now, and I ran into some questions:
- will there be tagging support in a future update?
- I've tested up to 24 bits / 96khz / 7.1 channels successfully. will the samples rates 88.2/174.4/192khz be supported at some point (not that I'm a fan of those...)?
- when using flaccl as a command line encoder in foobar, is there a way to force fb2k to use the source wav and not create a temp wav thus slowing the operation down?
- at the moment I'm using batchenc as a gui/frontend and while it skips the foobar delay it lacks tagging. is there a better alternative or a way to include metaflac for the task?
thanks!
btw, here are some benchmarks on a low-end system (with cuetools):
Celeron E1200 @ 1.6 Ghz, FLAC 1.2.1b -8 -V: 22x, +0%
Celeron E1200 @ 3.0 Ghz, FLAC 1.2.1b -8 -V: 42x, +91%
Celeron E1200 @ 1.6 Ghz, Geforce 210 @ default, FLACCL 0.4 -8 --verify --slow-gpu: 53x, +141%
Celeron E1200 @ 3.0 Ghz, Geforce 210 @ default, FLACCL 0.4 -8 --verify --slow-gpu: 73x, +232%
Reply #344
[quote author=sefr-g link=msg=817435 date=1355773442]I've been using and testing FLACCL for some days now, and I ran into some questions:
- at the moment I'm using batchenc as a gui/frontend and while it skips the foobar delay it lacks tagging. is there a better alternative or a way to include metaflac for the task?[/quote]
If it uses temp wav in foobar, I believe you set up it that way. It should do encoding from any source without temp file. Not sure what you say about tags, but if they was in source file, they'll be in final encoded file too.
Btw be careful with anything that is more than 16bits 5.1. It often produces broken files. Verify them after encoding. They may be not completely broken, but some part of it.
Reply #345
if I skip the %s in foobar's commandline I get an error: The encoder has terminated prematurely with code 1 (0x00000001)
as for tags, if the source wav has tags (shown in foobar) the resulting flac will have none, at least with the "regular" CUETools.FLACCL.exe [options] <input.wav> commandline.
with verifying you mean listening or just using --verify?
Reply #346
[quote author=sefr-g link=msg=817440 date=1355774861]if I skip the %s in foobar's commandline I get an error: The encoder has terminated prematurely with code 1 (0x00000001)
with verifying you mean listening or just using --verify?[/quote]
Simply skipping it is not a proper way. check fb2k documentation for correct way, I don't really remember without checking myself.
Thing with tags is a feature of the front end. it will work with foobar, not with FLACCL.exe alone
By verify I mean verify md5 using anything that works for you. personally I use fb2k plugin. maybe FLACCL.exe can do that, I never tried. Original flac package should have ways to do it. If you'll try to mux it in mkv using mkvmerge for example, it will give an errors too. Listening may or may not work as it not always completely broken. It's hard to spot anything that way. BTW while it happens only with more than 16bits audio, it looks like it depends on the _content_ of the audio. For some 24bit audio it never happens, for some other it always happens with any compression level and whatever.
Reply #347
alright thanks.
I've noticed the missing - in foobar's commandline although I could swear I've used it initially. now it works, though a bit slower than with plain cmd.exe.
I'll look into md5, thanks again.
Reply #348
Hi, Happy New Year....
i installed drivers 12.10 and was a BIG improvement over 12.6.
but i read somewhere that 12.11 are even better...
uninstalled the 12.10, reboot & installed the 12.11beta11 NET4
it does improove a bit... over 12.10,
but something strange happens...
with Hitachi 2TB HDD goes faster, than using RamDrive...? crazy right?
sadly HDTach 3.0.4 software was discontinued, to test Ramdrive speed.
very strange....
also the latest 12.11beta11 NET4 does not support --group-size 64
gives a Error    : internal error: invalid stereo mode.
but with --group-size 32 works ok.
also does not auto-detect the OpenCL name, i guess because i have installled the "Intel SDK OpenCL 2012"
anyway... here are some results:
--opencl-type cpu
164.32x
i7 970 3.2GHz
AMD Drivers 12.10...
C:\Users\jpc\Desktop\FLACCL\flaccl03>flaccl03 -11 --opencl-type gpu --opencl-platform "AMD Accelerated Parallel Processing" --task-size 64 --group-size 64 cd1.wav
FLACCL#0.3, Copyright © 2010 Gregory S. Chudov.
Filename  : cd1.wav
Results  : 670.88x; 433963131 bytes in 00:00:05.8344102 seconds;
C:\Users\jpc\Desktop\FLACCL\flaccl03>flaccl03 -11 --opencl-type gpu --opencl-platform "AMD Accelerated Parallel Processing" --task-size 128 --group-size 32 cd1.wav
Filename  : cd1.wav
Results  : 804.20x; 662069752 bytes in 00:00:04.8672085 seconds;
a few more tests with same setting:
791.51x
789.02x
801.63x
806.78x
804.20x
781.65x
806.78x
806.78x
with DataRAM RAMDisk now called AMD RamDrive...
R:\>flaccl03 -11 --opencl-type gpu --opencl-platform "AMD Accelerated Parallel Processing" --task-size 128 --group-size 32 cd1.wav
Filename  : cd1.wav
Results  : 789.02x; 662069752 bytes in 00:00:04.9608088 seconds;
784.09x
784.55x
786.55x
786.55x
789.02x
789.02x
791.51x
789.02x
AMD Drivers 12.11beta11 NET4
Filename  : cd1.wav
C:\Users\jpc\Desktop\FLACCL\flaccl03>flaccl03 -11 --opencl-type gpu --opencl-platform "AMD Accelerated Parallel Processing" --task-size 64 --group-size 32 cd1.wav
Filename  : cd1.wav
Results  : 332.33x; 672222043 bytes in 00:00:11.7780207 seconds;
791.51x
806.78x
799.07x
806.78x
806.78x
806.78x
Reply #349
[quote author=sefr-g link=msg=817435 date=1355773442]will the samples rates 88.2/174.4/192khz be supported at some point (not that I'm a fan of those...)?[/quote]
WTF...not a fan? you really need to change your loudspeakers.
http://www.youtube.com/watch?v=3lXnAGIwicE
http://www.youtube.com/watch?v=Ys7lABBrpYw
