Topic: lamedropXPd3 (Read 27942 times) previous topic - next topic
lamedropXPd3
Reply #50
Any chance on getting recursive directory parsing and recreating the structure in the output directory?
lamedropXPd3
Reply #51
Not right now, but it falls within the remit of what I shall be looking at for the next version. Don't push me for a date, though, it depends how the mood takes me!!
lamedropXPd3
Reply #52
Ok.  Big thanks in advance though!
Moderation: Quoting previous message in its entirety is a waste of space.
lamedropXPd3
Reply #53
This is a great tool with the utmost utility and simplicity.  In the future, please consider the ability to drop wavpack files.
lamedropXPd3
Reply #54
I'll bear it in mind.  So you've been talking to Roberto, have you???
lamedropXPd3
Reply #55
Like I said in another thread, this program is just awesome! The more lossless formats to drop, the better
Also, would it be possible to make a similar drop-thingy for the free Nero AAC encoder? I'd love to see that! But maybe it's more tricky since that encoder has different modes (LC, HE v. 1 and 2 etc.)?
//From the barren lands of the Northsmen
lamedropXPd3
Reply #56
If you're interested, I created this...
http://www.hydrogenaudio.org/forums/index....st&p=580029
EDIT: In response to DigitalDictator's post, yes it was intended for you.  I sent you a PM about copying the code from the post.  I would like to avoid creating an off-topic discussion in john33's thread.
lamedropXPd3
Reply #57
I already wrote that as a comment to the lamedropXPd v3 release, but as it's more like a feature request, it might be more appropriate in that thread. I hope that re-posting it here is allowed given that I try to put it in the more fitting thread:
Two small things I want to add:
- On my machine (XP SP3) it has -V 8.31 (approx 78 kbps) set as (default) -V value on first startup, is this intentional? For more novice users a setting of V2.5 or V3 would possibly a better default setting in order to not make someone insecure.
- Would it be possible to see the file path in the progress bar from the end and not from the beginning? Usually the path is so long that the visible part is of no real use. The end part of the file path however would make the file name visible. And while I'm at it: When encoding long files where the progress bar is moving slowly forward one can't see the path at all, which is not so helpful. I think this is intentional but I'd favour to see the path fully from beginning to the end :-)
lamedropXPd3
Reply #58
Greynol, was that link intended for me? If so, I don't know what to download, or where!
lamedropXPd3
Reply #59
john33,
Thanks for your work with lamedropXPd3.
I have been using the latest lamedropXPd3 from rarewares for testing all LAME 3.98.2 average VBR bitrates (in 0.5 step increments). It is an excellent tool for the task.
I have noticed a small bug. I have 42 precreated destination directories (21 for rock/pop/jazz/etc and 21 for classical). I would like to copy the the destination path from Windows Explorer and paste it to the "output directory options" window before starting each batch, but apparently that does not work. Right-click paste or keyboard shortcuts do not work. In addition, it is not possible to edit the path directly by typing.
I also have a feature request: since LAME now allows the -V10 -- V9.xx settings could you expand the VBR quality settings range to start from -V10 ?
EDIT
After I have published the test results you may want to check the bitrate estimation values and revise if necessary. Expect to see the results at HA in a couple of days.
lamedropXPd3
Reply #60
john33,
EDIT
Hi Alex,
I'll take look at this as soon as I'm able and post back here. Thanks for your interest.
lamedropXPd3
Reply #61
John,
I was just going to download LameDropXPd and I was surprised to see version 3.01 had been released on the 23rd of October (based on LAME 3.98.2). Thanks for updating this program.
Re: lamedropXPd3
Reply #62
Dear john33, lamedropXPd 3.1 x64 does not work on my end when resampler is switched on. What could be the cause?
Re: lamedropXPd3
Reply #63
I'll check here and get back to you but it will probably not be until tomorrow.
Re: lamedropXPd3
Reply #64
I can confirm the problem and I know where to look for the solution. I may not be able to get to it today, but I'll try to get it sorted ASAP. Thanks for 'heads up'.
Re: lamedropXPd3
Reply #65
Dear john33, 2 weeks passed, is it turned out to be more complicated than expected?
Re: lamedropXPd3
Reply #66
I do have working versions which I'll upload later today, but I'm not entirely happy with the solution. I'll take a deeper look at it when I have the time.
Re: lamedropXPd3
Reply #67
I tried the latest version of LameDropXP 64-but you uploaded on 2021-04-29, but it does not work with Resampler either.
Re: lamedropXPd3
Reply #68
Well they worked when I checked them before uploading, but I'll take another look when I return home. I'm away until the end of the week.
