Topic: Columns UI appearance (Read 3320551 times) previous topic - next topic
Reply #2025
The configuration for the touchscreen.
Reply #2026
hello all -
  well, here's the new and improved (much) lljkturntable config.  it looks about
the same...
  thanks to tom barlow and tedgo for their help with the wsh panel, and to br3tt
for his (unwitting) help with the buttons scripting!  thanks also to everyone else
i've shamelessy but not thanklessly "borrowed" scripting ideas from....
here's the link:  stick this in yer foobar and smoke it...
rock
j
Unfortunatly the link in this post doesn't work anymore. Can anybody please repost this or tell me if I can find this skin (or another nice turntable skin) elswhere?
^ This PLEASE
Reply #2027
Mine
Reply #2028
Ill start with "to each their own".
'L' opens library.
'1','4','7' rewind 1,5,10 seconds respectively as '2','5','8' fast forward (on number pad of course).
Spacebar to pause/play and many more shortcuts.
600+ GB of music and just shy of 300 artists.
Reply #2029
I really love foobar2000
Thanks a lot to marc2003 and all other guys doing the hard job for very nice scripts and plug-ins.
Below is the result of my design while using their scripts. It's all good for my usage and taste  Thanks again.
Those are three panels (CUI) easy and fast to switch among them with double clicking on their captions... just perfect for me.
Reply #2030
it's been a long, long time since i last used columns.
marc, the playlist list looks awesome. Is something you have done or it is a mod of some of the existing ones? In any case will be nice if you share it.
Reply #2031
that playlist is pretty awful. it's just a plain text ELplaylist. sorry i don't have it anymore but it was only a couple of lines of code to display the artist/title. i increased the row height to fit 2 lines in and that was it really.
Reply #2032
  - I like the simple things. The general question was because of the two lines per PL position. Seems that this can be done with ELplaylist only.
anyway - thanks for the reply.
Reply #2033
Denim
Reply #2034
Anyone knows a plugin / splitter to detach a panel from the main window?
I want to make something like a Lyric Panel outside of the main foobar window. Thanks!
Reply #2035
Foo_popup_panels?
With Lyrics Show Panel 3 you can achieve that without any additional components: menu - view - Lyrics Show Panel v3 (on a restart it disappears though).
Reply #2036
Is there any way to change the colors of the Filter column? I was looking to get a transparent background with white text, and can't figure out how to do it for the life of me :\
Reply #2037
Preferences > Display > Columns UI > Colours and Fonts > Colours tab.
Select Filter Panel in the Element dropdown and then make other adjustments accordingly. "Foreground" is the text color. And no, you can't make the background of the filter panel transparent.
Reply #2038
Foo_popup_panels?
foo_popup_panels does the job that I need, thanks for your reply! "Lyrics Show Panel 3" Panel didn't work well because I need to hide title bar and frame.
Reply #2039
My first skin. Work in progress but I wanted something minimal and easy to read/navigate.
Reply #2040
Replica
Reply #2041
Columns UI Layout
Vertical Splitter
--Horizontal Splitter
----Buttons (link unmodified files; Playback Order Button uses these files too)
----Filter Search
--Vertical Splitter
----Waveform Seekbar (link)
--Tab Stack
----EsPlaylist (link)
----WSH Panel Mod (WSHtpc03 Version 1.0 by ojdo)
----Lyrics Show 3 (link)
----Menu
----WSH Panel Mod (Playback Order Button is included in the zip file of WSH Panel Mod)
----Volume
Misc.
--Waveform Seekbar
----background 160,0,226
----foreground 143,240,132
----selection 0,240,120
--Text 0,50,175
----To make the words in parentheses grey:
----$rgb(0,50,175,0,60,225)$replace(%title%,'(',$rgb(150,150,150)'(',')',')'$rgb(150,150,150)$rgb(0,50,175,0,50,175))
--Edit EsPlaylist Length Column
----If the track is currently playing, display time elapsed and remove the seconds digits from %length%:
----$rgb(0,50,175)$if(%isplaying%,%playback_time% | $ifgreater(%length_seconds%,600,$cut(%length%,2),$cut(%length%,1))) $if($not(%isplaying%),%length%)
Reply #2042
So, I started working on one, but I've no idea how to change the grey areas, any help would be much appreciated.
Reply #2043
I wrote a much longer post about my theme in ojdo's WSHtpc thread but thought I'd share the images here as well:
Reply #2044
I should also point out that my theme is entirely WSHPanel based, so it could work in DUI, but those are CUI screenshots because you can hide the toolbars (and also switch between themes with a hotkey).
Reply #2045
i would like to paint in red the title of all the lastfm loved songs, which script should i use?
Reply #2046
Foobar2k beginner here - could anyone tell me how the left/right layout in the main window in this screenshot can be achieved? I'm trying out foobar2000 after many years of curiosity and was hoping I could get a nice layout.
I found it here. Liked the idea of having the artists in the library listed on the side and when clicked showing the albums/tracks on the right.
Reply #2047
Update: found a solution using the Facets and EsPlaylist components
Reply #2048
Mine
Man, how did you change the font size of the grouping title? I've changed the colour of the text and horizontal bar, but need to finish it off by changing the size like in this (and maybe add line spacing on only the grouping title).
Reply #2049
Preferences/Columns UI/Colours and Fonts/Fonts tab/Element dropdown, choose NG Playlist: Group Titles
