Topic: Columns UI appearance (Read 3306648 times) previous topic - next topic
0 Members and 5 Guests are viewing this topic.
Reply #254
my simple config
mini mode
full
wow! any chance to get it somewhere?
install it on clear foobar v0.9.5.x (replace files in foobar folder)
include: foo config, required components
now i'm working on this config, it's not release yet
i reupload it without fonts and theme link 711kb
Moderation: Download link removed. The archive contained copyrighted fonts and a visual style.
Reply #255
This is my current fabrication, which consists of
a playlist panel + art
and a album art show off panel.
It's kept pretty simple due to the fact i'll be using it on my work also.
And due to that i had problems to get some plugins to work as a result of missing dependencies.
The MFSL cover is a template.
The playlist consists of lone mp3's with and without single (45rpm) art, albums with art, and compilations with art.
They are all sorted and displayed in their own way. The mp3's with and without art, i could only sort through adding the comment 'single' to the comment tag of the ones with art.
<3 f00
Reply #256
Here is mine.
Reply #257
My Current foobar:
Work is still in progress.
Btw. is there any way to hide the scrollbar which appears in big playlists in NG Playlist?
Reply #258
Seconded. I'd like to see tgpo's config as well.
This is in no way a final version or anything, but it's what I use.
You MUST install fooSune first, since the playlist uses all the code.
I'll be the first to say that 99% of this isn't my work.  So all credit goes to sune for this.  I've only done the stylization for the mini mode.  So thank him for all this.
http://www.tgpo.org/files/sune.zip
Reply #259
Here's some screenshots for my simple column UI plugin, haven't got a name for it.
(Full album list view)
(Specific group album view - showing off my Final Fantasy collections)
(Specific group album view - currently playing)
Reply #261
Reply #262
After about ten days of playing around with panel_stack_splitter and trackinfo_mod I've finished my foobar config (at the moment  )
If i could only hide the vertical scrollbar in NG Playlist...
Reply #263
^make the width of the panel wider so that the scrollbar is out of view
Reply #264
@Harun
That doesn't help. It only ends up in not displaying the parts from the lyrics/album list panel right beneath the playlist that are hidden by the resized playlist.
Reply #265
[a href="http://img529.imageshack.us/my.php?image=myfoobar20081101xa6.png" target="_blank"]
keep up the good work & learn
Reply #266
@Harun
i think it does work when it's the right-most panel
Reply #267
I'm a freshman. I'm interesting in the skin of foobar. The version is 0.9.5.6 which I'm using now. Which plugin is fit to this? How can I do that?
Thanks a lot!
Reply #268
@Harun
Sure, but as you can see on my screenshot it isn't the right-most panel
Reply #269
how do you get the cover art to show in the play list?
Reply #270
It's the NGPlaylist, with the albumart enabled through right clicking on the column list and clicking on the option.
Reply #271
ah thanks...very nice
Reply #272
CUI with NG playlist
How did you get milkdrop 2 in fb2k????
I absolutely LOVE milkdrop2 and that's the only reason i still have winamp.
would love to know how you did that.
Reply #273
Shpeck component, see below :
http://www.hydrogenaudio.org/forums/index....showtopic=59388
