Topic: Columns UI appearance (Read 3306119 times) previous topic - next topic
0 Members and 5 Guests are viewing this topic.
Re: Columns UI appearance
Reply #2350
Current dark theme that I'm running the most.
Based on the very well done Catrox theme...
... and thanks to the foobar community that keep on developing awesome tools/panels.
Reply #2353
Share? No, I've never done that before. I always keep everything to myself. :P
Have you tested JSPlaylist and Smooth Browser from the latest JSP3 beta already? They might be a sluggish on larger collections. ( I remember your posts about CPU usage /maybe crashes??)
Disclaimer for Smooth Browser here: https://marc2k3.github.io/jscript-panel/gallery/smooth-browser/
I'll post something later on. I need to remove my personal tweaks.
edit: with the exception of the middle panel with over-layed text, you can recreate it with the samples already provided
Menu button
Smooth browser
Thumbs
JS Playlist
Track Info + Spectrogram Seekbar + Buttons (requires ffmpeg: https://marc2k3.github.io/jscript-panel/gallery/spectrogram-seekbar/ )
Status Bar
Reply #2355
64bit test layout with JScript3 and code samples from marc2k3. It would be nice to somehow replace panel tabs with one jscript panel and buttons but can't figure out how to do it. And with 32bit version I was using Peakmeter Spectrum Visualisation plugin which looks much better than default F2k spectrum analyser.
Reply #2356
If each tab contained a single JScript Panel it would be easy enough. You could replace the tabs with a single panel and add this code...
// ==PREPROCESSOR==
// @author "marc2003"
// @name "Panel Receiver"
// ==/PREPROCESSOR==
var script = window.GetProperty('2K3.SCRIPT', 'user-components-x64\\foo_jscript_panel3\\samples\\JS Playlist.txt');
var pre = '';
var text = utils.ReadUTF8(fb.ProfilePath + script);
var lines = text.split('\r\n');
if (lines[0].indexOf('// ==PREPROCESSOR==') == 0) {
for (var i = 0; i < lines.length; i++) {
if (lines[i].indexOf('// @import') == 0) {
var fq = lines[i].indexOf('"') + 1;
var lq = lines[i].lastIndexOf('"') - fq;
var file = lines[i].substr(fq, lq).replace('%fb2k_profile_path%', fb.ProfilePath).replace('%fb2k_component_path%', fb.ComponentPath);
pre += utils.ReadUTF8(file) + '\n';
} else if (lines[i].indexOf('// ==/PREPROCESSOR==') == 0) {
break;
eval(pre + text);
(function (global) {
var original_callback = global.on_notify_data;
global.on_notify_data = function (name, info) {
if (name == 'load_script') {
window.SetProperty('2K3.SCRIPT', info);
window.Reload();
} else if (original_callback) {
original_callback(name, info);
})(this);
Now you need a secondary panel which contains a button/menu that would send notifications to this panel whenever it was clicked. You should just need to supply the full script path something like this...
// must be relative to fb.ProfilePath - do not make it absolute
window.NotifyOthers('load_script', 'user-components-x64\\foo_jscript_panel3\\samples\\smooth browser.txt');
edit: of course any current "state" would be lost each time new content is loaded.
Reply #2358
foobar2000 v2 64-bit, Columns UI, Windows 11.
"Flag"
This is cool and something I've thought about doing before. Can you explain any more about it? Does it use a separate component or is it a script/custom field? I'm interested. I think it would be fun to track country of origin.
EDIT: btw, here is a screenshot of my Columns UI interface as of this morning.
Reply #2359
It is a JScript Panel 3 Script:
//flag by grimes
//fb2k v2+, JScript Panel 3+
//DUI/CUI ready
// ==PREPROCESSOR==
// @name "flag"
// @version "4"
// @author "grimes"
var cfg_foobarpath = window.GetProperty("foobar path:", fb.Profilepath);
var cfg_flag = window.GetProperty("flag folder:", "flags");
var svg_file = cfg_foobarpath + cfg_flag + "\\noflag.svg";
var svg_content = utils.ReadUTF8(svg_file);
var dui = window.IsDefaultUI;
var original = utils.LoadSVG(svg_file);
function on_paint(gr) {
    gr.FillRectangle(0, 0, window.Width, window.Height, dui == 1 ? window.GetColourDUI(1) : window.GetColourCUI(3));
    if (original) {
        var scale = 0;
        var x = 0,
            y = 0;
        var scale_w = window.Width / original.Width;
        var scale_h = window.Height / original.Height;
        if (scale_w <= scale_h) {
            scale = scale_w;
            y = (window.Height - original.Height * scale) / 2;
        } else {
            scale = scale_h;
            x = (window.Width - original.Width * scale) / 2;
gr.DrawImage(original, x, y, original.Width * scale, original.Height * scale, 0, 0, original.Width, original.Height);
function get_flag() {
country = fb.TitleFormat("%composer_nation%").Eval();
original = utils.LoadSVG(cfg_foobarpath + cfg_flag + "\\" + country + ".svg");
window.Repaint();
if(fb.IsPlaying || fb.IsPaused) {
get_flag();
else {
    window.Repaint();
function on_playback_new_track() {
    get_flag();
function on_playback_stop(reason) {
    window.Repaint();
function on_colours_changed() {
window.Repaint();
function on_item_focus_change() {
if(!fb.IsPlaying) {
window.Repaint();
%composer_nation% has to be replaced by your country tag. Flags in svg-Format in attachment.
Reply #2361
axw, how do you do that. THANK YOU ;)
Reply #2362
My take on ColumnsUI 2
Reply #2364
...and mine  :D
Reply #2365
Foobar 2.0 64-bit. ColumnsUI 2.0*. JScript Panel 3.
All custom script, fonts and components are available on attachments.
Compact layout with JSP3 scripts
- Thumbs, Text Display, Album Art script,
- JS Playlist and
- Dynamic track compact.
Main layout with custom track and material round and segoe fluent icons.
Smooth Playlist Manager (modified), Smooth browser and JS Playlist (modified).
*custom build just to make the tab stack background darker.
Tabs stack icons are just using segoe fluent icons
Spoiler (click to show/hide)
Credits to original script by brett and components and script by marc2k3
Reply #2366
great men . very impressive. thanks for the share files.
my column UI 64 bits
share files down below :  the seekbar , the spinning vinyl , and the lastFM + biography
Reply #2367
i cannot figure out : Tabs stack icons are just using segoe fluent icons . i made this also . nothing .
how to do this ? can i see your layout ? explain to me . thanks
Reply #2368
@eurekagliese
Hi :) Thanks for good "Track Info + Seekbar + Buttons (track_custom_v2.js)" panel.
Isn't "Repeat Track" and "Repeat Playlist" reversed?
I edited. maybe i'm wrong.
Default UI foobar2000 v2.0 64bit (Image edited by me)
SHURE SRH1840, SENNHEISER HD660S2, SENNHEISER HD 490 PRO, DT 1990 PRO, HiFiMAN Edition XS, Bowers & Wilkins P7, FiiO FT5, 水月雨 (MOONDROP) 空鳴 - VOID, Nakamichi Elite FIVE ANC, SONY WH-ULT900N (ULT WEAR) (made a Upgrade/Balanced Cable by myself)
Reply #2369
Here's the layout
Make sure to change to fonts
@Air KEN
Regarding the repeat track, I've merged it into a single button. Shuffle order cycle with left click and repeat cycle with right click and middle click for random (See tooltips).
EDIT: Ah, thanks for the hint, I rarely use that repeat button.  Wait, the order is already correct on mine.
Reply #2370
You are fast like the light ..... thanks a lot for your help . appreciate . continue . We love Foobar2k .  :D  :D  :D  :D  :D  :D  :D
MOD: edited
Reply #2372
The track_custom script updated.
Reply #2373
@eurekagliese
Reply #2374
// ==PREPROCESSOR==
var pre = '';
break;
eval(pre + text);
window.Reload();
})(this);
Thanks Marc2k3 for this script . Work great... 👍👍👍
I suppose it's impossible to have 2 jscript panel loaded with one button .
MOD: Edited
