Topic: Columns UI appearance (Read 3306076 times) previous topic - next topic
Reply #1800
I was thinking of making these images display in different colours but I don't know how to make them dependent of genres. Wanted to make the same classification as on the page of the pleasurize foundation.
Reply #1801
Do you have to manually scan each album with the DR component?
Reply #1802
I guess you could do this if you had different versions of the DR images, sorted out into different folders, and then used a combination of $if functions, but it might over-complicate things. You could always use the colour scheme from the Unofficial DR Database, as you'd only need one set of DR images.
You do, and you need to ensure that it is set up to write the values as tags in the selected files.
You can set this in File > Preferences > Advanced > Tools > Dynamic Range Meter > Write DR meta data tags
Reply #1803
Yeah, I have these images grouped into three categories and it is divided on the website, but I can't implement the division into foobar. In other words, I can't make one set apply only to specified genres and, and likewise with the others. Tried $if functions but nothing comes out of this.  If I don't find a way to make it, I may stick to the unofficial scale.
Reply #1804
You may be able to get it working using something like this:
$if($and(%album dynamic range%,$or($stricmp(%genre%,classical),$stricmp(%genre%,soundtrack))),$imageabs(x,y,w,h,skins\dynamicrange\HIGH\DR%album dynamic range%.png),)
$if($and(%album dynamic range%,($or($stricmp(%genre%,alternative),$stricmp(%genre%,pop),$stricmp(%genre%,rock))),$imageabs(x,y,w,h,skins\dynamicrange\LOW\DR%album dynamic range%.png),)
You should then be able to use the $or function to specify more genres. If anyone has a more elegant solution, then please feel free to suggest.
Reply #1805
My first config ever
Reply #1806
nice and where is the download?
Reply #1807
Well, as it is my first try I have there real mess in code. Some absolute paths. I don't even know how to properly put it all together for download.
Reply #1808
DUI kind of style which focuses on usability rather than fanciness.
The very act of observing, influences what happens.
Reply #1809
You can just pack your whole folder, the experienced users will figure all the necessaries out.
I like yours.
mad messy misanthropist morbid mused
Reply #1810
I suggest you use a portable copy of foobar, then its just a case of zipping up your foobar2000 directory if you want to share it with someone, they can then run it 'straight out the box'
btw might I say its a slick config, another request for you to share it!
Reply #1811
Thank you for tips. I'll release it as soon as I finish all small tweaks. Also there will be at least 4 color themes available (green, blue, fire, glamour). I hope to finish it later today.
Reply #1812
slate 1.0 with dockable panels
Reply #1815
Fancy! Composition with your skin is impressive. I'm curious how it will work compare to other cover flows plugins. I don't use any because loads are too high for me. Or should I say: to my PC
EDIT:
Heh, just saw beta version on dA. Time to test.
Reply #1816
[quote name='Falstaff' date='Mar 17 2012, 16:25' post='789767']
trying my WSH CoverFlow script in my Slate config:
wow....looking forward for the release.... , scrollbar in addition would be a nice idea
Reply #1820
A skin I made has no borders around the filters on my computer, but whenever anyone installs it they get these white borders:
What do I need to do so that when people install it they don't have the borders?
Reply #1821
not finished yet
Reply #1823
Looking forward to downloading your config too
Reply #1824
Guys, how can I learn to solve this problem, don't know what to do, to sort this ones in correct order : ) noob here alert!!
