Topic: Columns UI appearance (Read 3306132 times) previous topic - next topic
Reply #175
I doubt I'll use it when it gets released, since I enjoy the process of creating my own configurations far too much to use anyone else's. But I've got to say, Falstaff, that's some mighty fine-looking work there.
Reply #176
My latest work-in-progress, which I'm tentatively calling Manuscript. There's a good bit more to do on it yet, but I think the basics are in place.
Reply #178
Nothing special just foobar with ColumnsUi, artworkview and trackinfo
Reply #179
I made a new fullscreen trackinfo_mod display: htpc9. Nothing new, just better coded than the predecessors, fully resolution adaptive and configurable and with a cover glow effect:
Reply #180
I'd prefer a more technical look, but this is really good work! Well done!!!
Reply #181
Thanks! I generally prefer more technical layouts too; this was an experiment in what was possible as much as anything else. But I am pleased with the results, at least until I get a wild hair and decide do to something completely different, probably a month from now
Reply #182
converting my panels ui config to panel splitter was a lot easier than I thought! I think my config in panel splitter is actually better because filter works so much better than the browser ever did, and the ability to hide/show/move panels and buttons is great too.
Reply #183
this is great!
would you share it?    and i also like the visual style,too
Reply #184
here's my build (watch at 100% zoom):
Reply #185
when do you share this perfect config?
Hmm... I want to make some minor tweaks (especially with 'LCD displays') and insert 'Now Playing' panel.
So, coming closer to the release of your config or?
Yes, 'Sapphire' (this is how I called my config) is almost finished. New preview:
Reply #187
Looks really nice!
Here's mine. Not quite sure about the buttons, I'm not that great with photoshop but at least I can say they're mine! I might try and make some new ones soon. Oh and I still haven't made cursor follows playback/playback follows cursor buttons, they're meant to go on the right, either side of the playback order button.
Reply #188
[a href="http://i34.tinypic.com/34pgwmr.png" target="_blank"]
Reply #189
This is my new config. I lately switched from Panels to Columns and tried to design a surface as similar as possible to my old panels config. It's rather nice I think, exactly what I hoped it would look and "feel" like. The most complicated work were the search algorithms for the album list and chronflow panel, which I only got to work the way I want with much of extra tag fields for all sorts of "special" albums (sampler, soundtracks, my own recordings, ...).
For searching I use the columns UI filter, it appears instead of the Chronflow panel.
I will add an additional panel for lyrics the next days, which will appear at the same position.
Reply #190
Kung-Foo running under neion Visual Style
Toolbars visible (Playback Order + Playlist Dropdown plugin)
Reply #191
Reply #192
Fiddled around to make use of a new widescreen monitor.
Reply #193
Zarkon, great config. Very well categorized.
Can you tell me how do you display directory name in "Folder"?
Reply #194
If you have a fixed number (depth) of subdirectories in your music folder, you can use $directory(%path%,n) to pick out the n-th folder from the bottom. But I have a variable number of subfolders:
X:\Music\Category\(zero, one or more subfolders)\file.mp3
So I use
$substr($replace(%path%,X:\Music\,),1,$sub($strchr($replace(%path%,X:\Music\,),\),1))
to pick out the text after "X:\Music\" and before the next "\". Obviously this isn't as versatile as the directory feature of Facets.
Reply #195
Thanks for the tip. Working fine
Reply #196
Here's mine.
Reply #197
I'm on the simple but functional boat
Reply #198
Modded Kung-Foo  added some colors to this great config
[a href="http://img.w3dizajn.net/images/1gd62.png" target="_blank"]
Reply #199
i work on the next release of my Kung-Foo config, here is the v1.2-beta preview with a dark layout :
[a href="http://xs231.xs.to/xs231/08396/preview111black348.png" target="_blank"]
