Topic: Columns UI appearance (Read 3306293 times) previous topic - next topic
Reply #1225
actually that's not what i meant at all. i mean my music files are getting modified by the various components in your config. examples being lyrics saved to tags and also playback statistics.
Ehh sorry i misunderstood you
The lyrics tagging can be turned off in lyrics panel, they are on only because that way the elplaylist lyric indicator can see them.
and i will add playback statistics save to tag optional in my next update.
Reply #1226
I need to know how to do the things marked in red in this pic, anyone can help me? Thanks anyway
PS how can i change the column font color? (for exemple, album in red and artist in white...)
Reply #1227
Updated my config a bit:
Reply #1228
my first config (:
Reply #1229
I ubtated my fooMMX to 1.1 if anybody is interested.
Canges in 1.1:
- Playback statistics and ratings by default will now be stored to database (read the readme for more info).
- Lyrics are now by default saved to the lyric folder in your foobar dir (this also eliminates that annoying foobar hanging sometimes when lyrics was updated
(I love that foo_uie_lyrics2 much more now ).
ELPlaylist lyric indicator displays those lyrics when synced Yellow and unsynced Light Yellow (Lyrics in tags are displayed Green and Unsynced Lyrics in tags are displayed White (I hope i got that write i'm a little bit colorblind you know ))).
- Quicksearch toolbar moved to top of the ELPlaylist.
- fix - when comment button was clicked in info panel the back
button was hidden.
- fix - the spectrum takes less cpu now.
deviantart
Reply #1230
Almost 3 or 4 years using my PanelUI version, stucked with a foobar aged 0.94.
Those last days i had time, no job, and look about foobar v1 and new components.
Wow! so much improvment... almost everything that i had to make with run service are now automatic.
So i've tried Panel Stack Splitter... and BINGO! i began configuring my new skin.
The start point was simple: all my friends were not able to use my old config
because : "too much possibilities, too much buttons, too much icons, and no much skill for them"
so i decided too start a sort of "music explorer" that should be as simple as a minimalistic internet explorer ala firefox, opera or chrome, without too much buttons.
It is designed too look more like a kind of internet thing than a player. It is a choice and for that, i suppose that some of you will not like it so much...
I made 30% of my will, and will not have now much time to finish it because new job...
There miss lot of things: tags panel, possibility to rate, and even play/pause/stop/playback order buttons !!! (i only use keyboard shortcut or my phone to do that).
so here the look of my lastFOOdly... a sort of combinaison of some look of my favorites internet pages (feedly, lastfm...)
as ever, excuse my poor english spoken, and my "life story"
You have to share that. It's the most Ideal thing I have seen for a large music collection for foobar.
Reply #1232
Canges in 1.1:
button was hidden.
deviantart
Nice interface! I try it yesterday and I am not familiar with it. Would you mind improve these:
i) Present a user guide, especially the setting of the dialog-box;
ii) The setting file provided as "fcl", it seems more popular, I don't wanna change the configuration files location frequently.
iii) The album-art in group header and playlist display so slowly and always frozen, there's maybe something wrong or unefficient settings.
I like this work and will try it further.
Thank you, ExtremeHunter!
Reply #1233
I'll mabe write a guide , mean while you may take a look to my LatroX guide they are quite similar in many ways.
I'm not gonna too the fcl file because that way is impossible to export all the settings etc. cowerflow backround colors and so on ...
And you don't have to change the location , just go foobar preferences\general and click open folder there (no matter what your current location there)
then open configuration folder (make backup your current files, just in case) and put my configuration files there.
"iii) The album-art in group header and playlist display so slowly"
Maybe that will help go to the elplaylist settings (right click on the playlist) and choose settings then go Behaviour and on the left bottom is the Resize Quality:
at the moment it is on the HighQualityBicubic try to change different settings there, it depends your video card or cpu what is best for you.
PS. I always make from a front cover a copy, resize it to 500x500 pix and name it to folder that way the cover panel and elplaylist load it much faster.
Reply #1234
I hope that by "foobar directory" you mean profile directory. The foobar2000 directory is not writable by mortals, in most cases.
Stay sane, exile.
Reply #1235
@extremehunter, if you want to distribute  .cfg files, just tell them to goto start, run/search,
%appdata%\foobar2000\configuration
telling people they must use the application folder is nonsense.
Reply #1236
Hello all! I spent a few hours learning how to adjust themes and I figured I would share what I ended up with.
I know it's not as fancy as the many other themes out there, but sometimes less is more right?
Reply #1237
foo_work
Reply #1238
Just showing off my custom seebar.fx
Reply #1239
Ye, please share asap!!!!! would be great.
Reply #1245
[a href="http://img213.imageshack.us/i/lastfoodly01.jpg/" target="_blank"]
Reply #1246
seekbar.fx
For future reference, when posting attachments, please actually commit a post to the Uploads or foobar2000 Uploads forum to contain the attachments. Otherwise, they won't work. I had to fix this one manually. (The attachments table includes a reference to the post number that they're contained in, which was zero for your attachment, breaking it. I reset it to the post you linked it from.)
Reply #1247
foo_work
Is this NG playlist? I've seen configs like this before and I can't figure out how to put draw those vertical lines (as the column separators)
