Topic: Columns UI appearance (Read 3306341 times) previous topic - next topic
Reply #1050
I meant in the columns UI layout setup. Sorry.
Reply #1052
I'm using Filter in ColumnsUI and it's grouping all my artists with "The" together, any way around this?
And I also want to make the song info panel hidable/unhidable. Any way i can do this?
Reply #1053
Here is another vandalism of Br3tt's great X-change configuration...
[a href="http://img197.imageshack.us/i/myfooconfig.jpg/" target="_blank"]
this is my first post, I am a newbie  , I do not know where to put the code, if I need a version of fooby (I have the 1.0) .. or ....? i 've O.S. Win Vista
I like this skin
thanks
ff10a
Reply #1055
wanna know if the official CUI team has a plan to support windows aero transparent, something like this:
Note: this picture is just an ugly window style hack for demo use, no practical use anyhow.
Reply #1056
http://img69.imageshack.us/img69/6741/aerofb2k.png
you should post here : http://www.hydrogenaudio.org/forums/index....c=28647&hl=
and wait for an answer from musicmusic
Reply #1058
thanks for your kindly remind.
i have copied the post there.
Reply #1059
Just my new 'improved' (rather simple) config /w waveform seekbar
http://img39.imageshack.us/img39/9413/foocarb.jpg
I'd love to get my hands on your ui, I like that it's not cluttered with tons of excessive information and that the only visuals are at the top/bottom :>
And if it's not too much trouble I'd like the playlist grouping script as well (or just your fb2k folder if that's ok), pretty please!
Reply #1060
My unfinished foobar. It s all about usability.
Could you please post this config? I've been looking for something like this since forever, and I'm just not good enough at this to make one myself.
Reply #1062
This is a (not very) modified Monolite Hybrid. I'll probably add other things like a dedicated Preferences button (don't like enabling that menu bar) and Biography tab at some point.
Reply #1063
I decided to start my own skin from scratch with some ideas that I took from my original Monolite mod.  It's at it's beginning stages and still a work in a progress but here is what I have so far:
I'm going for a minimal but very functional interface.  There are a lot of great designers and skins out there that I owe credit to for inspiration and ideas.
Reply #1064
Currently working on this, my main problem at the moment is trying to change the Filter component (top-left). I suspect it can't be done using the component which comes from the DUI, my objective is to get something functionally the same but which removes the "Artist" tab at the top (it's set to just the Artist tab, not Genre or Album, but it still shows) and which allows me to change the scrollbar. Not necessarily anything fancy, flattening it and making it dark would probably be enough. I think I might need a WSH Panel Mod for this?
Reply #1065
http://i31.photobucket.com/albums/c372/Jon...ta_foobar_1.png
http://i31.photobucket.com/albums/c372/Jon...ta_foobar_2.png
http://i31.photobucket.com/albums/c372/Jon...ta_foobar_3.png
http://i31.photobucket.com/albums/c372/Jon...ta_foobar_4.png
I'm inspired by your work. Very nice!
Reply #1067
that's very nice work. just one thing, how come we have to import the .fcl? aren't these redundant now that v1 has it's own .cfg files for components?
Reply #1068
@marc2003
Isn't it more comfortable to import the .fcl instead of copying the .cfg's to a (hidden) folder?
On portable installations copying the .cfg's only is a good idea, though...
Reply #1069
fair point. i'm so used to having my config folder inside my foobar directory (not in program files obviously) that i kind of forgot...
Reply #1070
nothing new, but my common layout functionality updated with few dsp buttons and forum color scheme
[a href="http://img6.imageshack.us/img6/6654/sshot6r.png" target="_blank"]
Reply #1071
LatroX 1.0 Released http://extremehunter1972.deviantart.com/ar...X-1-0-151924059
Hi and thanks for sharing.
This is the first "skin" I approach (always used CUI with a minimal plugin set so far) and this is a whole new world to me.
I'm trying to customize it (or, to be more precise, "dumb it down") to better suit my needs and I need assistance if possible.
1) Buttons on the left panel (Playlist, Lyrics, etc.) appear with the wrong font (I suppose, as long words end outside the grey area) even though I installed your fonts: is it because I'm on XP?
2) I replaced %tracknumber% with %list_index% in the track list, but the "Now playing" effect only applies to the first two digits and I was unable to spot which part of the code I should modify
3) I also added a Typefind panel (which I used to activate through a keystroke) but it doesn't seem to work
I'm sure more questions will come...
TIA for your assistance.
Alessandro
Reply #1072
@2E7AH: Looks nice. How did you make some text italic in the biog panel? e.g. 'Vidna Obmana' Is it a wsh panel?
Reply #1073
Restarting the PC fixed it.
Alessandro
Reply #1074
@TomBarlow: it's basic CUI layout, and info is in item details panel:
[font= "Lucida Console"]$replace(%some tag%,
%artist%
$set_font(Segoe UI,9,italic;)
%artist%
$reset_font()
)[/font]
though using this sometimes replaced word(s) aren't correctly wrapped, but rarely noticeable
