Topic: Burrrn Troubleshooting (Read 9045 times) previous topic - next topic
I've been trying to burn FLAC files (I've tried other formats with the same result) with Burrrn and get the following result:
Finished processing file #1.
Initializing ASPI ... OK!
ASPILOCK:1,0,0: MATSHITA DVD-RAM UJ-820S        Rev: 1.00
Starting write
Starting write at speed 16...
Turning BURN-Proof on
ERROR: Cannot set write parameters mode page.
Executing power calibration...
?: Input/Output error.  : scsi sendcmd: retryable error
CDB:  54 01 00 00 00 00 00 00 00 00
status: 0x2 (CHECK CONDITION)
Sense Bytes: 70 00 03 00 00 00 00 0A 00 00 00 00 73 03
Sense Key: 0x3 Medium Error, Segment 0
Sense Code: 0x73 Qual 0x03 (power calibration area error) Fru 0x0
Sense flags: Blk 0 (not valid)
cmd finished after 0.003s timeout 180s
ERROR: Power calibration failed.
ERROR: Use option --force to ignore this error.
ERROR: Writing failed.
I cannot burn any audio from Mediamonkey, Mediaplayer, etc. DVD burning has been no problem in the past but I haven't tried recently
Any ideas as to how to fix this problem? I thought it might be a driver issue or a scsi/aspi issue, but I am not sure. I've used other programs to burn cue/flac/ape and get similar results. Thanks in advance.
I got a similar error, I just unistalled and reinstalled again. Then it worked fine
Try uninstalling the drive via device manager and rebooting and let Windows redetect the drive.
maybe give imgburn a shot?
Maybe try the Raw Driver in the drive settings of Burrrn.
