Topic: Cost of -x option? (Read 6798 times) previous topic - next topic
Cost of -x option?
Hi
My CD ripper has for compression options for wavpack: -f, nothing, -h, and -hh. I am considering adding -x6 to all of those options, transparently to the user.
But before I do that I'd like to ask if anyone knows of reasons why the -x6 option would be undesirable. I can live with the encoding speed penalty, that's only done once. For example are there any players that would have trouble with such files?
Thanks in advance
Cost of -x option?
Very bad idea for -x6.. The only option I'd slip in transparently is -x1 or simply -x. This will optimise compression a bit (a lot for hi-rez) and give smart mid-side coding. Most people will want x1~3. -x4 gives some nice compression gain on very weird artificial material but is slower.. -x6 is very rarely better but much much slower.
The info on wavpack.com is good.
wavpack 4.8 -b256hx6c
Cost of -x option?
Hi
Thanks in advance
No one, even David, recommends x6.  If your ripper doesn't have an advanced option, and you really want to default an x value, I'd recommend x1.  The highest recommended value is x3, although there are some here that use x4 and x5.
But I'm sure that others have a different take on the issue.
I hope this helps.
Edit:  Shadowking beat me to it.
FLAC -8 | MP3 V2
Cost of -x option?
Ok then, say I default to x3. Is there any downside to that besides encoding speed?
Cost of -x option?
Then that's what I'll do. Thanks!
Cost of -x option?
I agree that -x6 is overkill and way to slow too be useful. I use -x4 a lot, but I agree that -x3 is about the most that you would want to force on someone. Since the user is ripping at the same time anyway they should not notice a big slowdown.
And, as was said, there is no cost associated with the -x modes. They are fully compatible with all decoders, and they actually seem to decode a little faster than the regular modes, although I've never really understood why.
BTW, I downloaded Asunder and tried it out and it works great on my system. Very nice!
I did run into something a little strange though. It seems like the compression levels don't quite match correctly. 0 and 2 seemed to give normal mode (no quality specifier) and 1 gave fast mode (instead of normal) and 3 gave high (instead of very high). You might want to check those again...
David
Cost of -x option?
Grr that was stupid. A lousy -1 and the whoe slider is broken  Thanks for noticing.
