Topic: Foobar Data on Logitech Dinovo MediaPAD LCD (Read 19095 times) previous topic - next topic
Hi there,
I made an application which has the ability to show Song Data from Foobar2000 on your Logitech Dinovo LCD Display.
Installation:
Download the foo_winamp_spam plugin which is linked below and put the dll in your foobar2000 components folder.
Then download the MediaPAD Control Application from my Homepage.
Information on how to configure your settings can be found on the Wiki Pages.
Required Plugins:
foo_winamp_spam
Data which can be shown:
  • trackname (artist - title)
  • status (playing - paused - stopped)
  • samplerate
  • bitrate
  • channels (2.0, 5.1, ...)
  • repeat (on | off)
  • shuffle (on | off)
  • position (graphical progress bar)
  • duration
  • elapsed time
  • time left
  • playlistpos
  • playlistlength
Links:
Homepage
Wiki
Forums
Pictures:
If the screenshots should be offline you can also see them here:
[attachment=4463:attachment] [attachment=4464:attachment]
I LOVE YOU!  THANKS!
Unfortunately it doesn't work.... at least not on my XP x64
As you can see on the Wiki Pages of my Application it is only for 32bit Operating Systems currently.
I dont know what I have to change to make it work and i also have no 64bit to test it on.
If you can tell me what I have to change (Programming Language is C#), I could implement it)
It doesn't make any sense. Any x64 OS is fully compatible with 32-bit applications. I have never had problems before running 32-bit applications.
I can tell you the behavior: When I run the program an icon is showed for the fraction of a second in the systray. So apparently it's crashing after initialization.
Yeah thats right.
I searched google and found this: http://www.computerbase.de/forum/showthread.php?t=376342
(Page is in german)
They said I had to specifiy the Build Options to x86 to let it work under x64. Confusing but never mind.
I made these changes and uploaded it to the server. So could you please try the new file?
http://stryder.bplaced.net/download/index.php?subcat=2
This Error has something to do with our main problem... x64 Support. I will try to find a solution.
By the way: The problem is already solved now
Is there any way to make it works with mx 5500 keyboard? Thanks in advance
I dont have an mx 5500 keyboard and I also dont know about a C# Driver.
Are there any 3rd Party "Addons" for the mx5500 keyboard?
Best regards
Stryder
the link is not working anymore
Does anyone have another solution for it?I really need to display the information on foobar2000 to my keyboard
Which link does not work? Everything is up and running...
Is it possible to display foobar infos on numpad lcd that is with diNovo Cordless for Notebooks?
Best regards
Stryder
I have foobar working with my mx5500 lcd screen.
I have foo_vis_shpeck running to emulate the winamp api, and by renaming foobar.exe to winamp.exe, the keyboard works perfectly.
Thanks pal, workin perfect
But foobar2000 1.0 beta not working as "winamp.exe"
Works with foo_winamp_spam.dll too.
That's strange...
all 3 links I got
bplaced.net  Zugriff verweigert, Fehler 403.  Sorry, access forbidden, error 403.  - Impressum
Hi there,
Installation:
Unfortunately that homepage is long gone.
I could easily find the foo_spam plugin elsewhere, but I cannot find the MediaPAD Control Application. Can someone reup that application?
thanks in advance!
