Topic: Registry Settings for making Enqueue Default (Read 5016 times) previous topic - next topic
Attached are registry settings to make "Enqueue in foobar2000" the default shell operation, without having to enable "Enqueue incoming files by default when adding from command line".
The problem I found with the latter was that with that enabled you cannot right click>play in foobar2000, as that would enqueue as well.
Disclaimer: you should always backup your registry before editing it. the attached registry file has been tested and works on my two machines.
edit: bah, didn't know there was a character limit to the topic description.
