Topic: foobar2000 0.9.5.2 and SDK (Read 10629 times) previous topic - next topic
Looks like 0.9.5.2 final is released along with the SDK? Or is that not the long awaited SDK?
Now, what do the developers say?
A new version of Visual studio is needed ... and there is no indication on how to build a toolbar.
no, it isn't. everything you need is just to to download additionally created dependency, WTL. I've recompiled my component with new SDK in a no-time.
If by "long awaited" you mean support for UI Elements, then no, their specification is not included in 0.9.5.2 SDK yet.
Then I probably have missed something. I get this message when trying to open the SDK-test.sln file in VS 2005.
And this SDK-test.sln starts with:
Microsoft Visual Studio Solution File, Format Version 10.00
# Visual Studio 2008
Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "foobar2000_SDK", "foobar2000\SDK\foobar2000_SDK.vcproj", "{E8091321-D79D-4575-86EF-064EA1A4A20D}"
    ProjectSection(ProjectDependencies) = postProject
        {EBFFFB4E-261D-44D3-B89C-957B31A0BF9C} = {EBFFFB4E-261D-44D3-B89C-957B31A0BF9C}
    EndProjectSection
EndProject
you have two ways: either manually recreate sdk solution hierarchy, or decrease format version numbers in SDK-test.sln and each *.vcproj you encounter. yes, the 2nd one is somewhat dumb, but it works. solution and project formats didn't change that much in vs08 versus vs05.
Hello. Where can I get ATL for free? VS 2008 Express edition don’t include it.
Or is there a possibility to compile without it?
@casperrr:
You can read this article for using  WTL if you are using Visual C++ Express, however, one problem is Windows SDK of VC++ 2008 Express doesn't contain atl headers anymore.
ATL/WTL is used in the implementation of some of the official components. You can compile the SDK just fine in Visual C++ 20008 Express without ATL (obviously, only as long as you don't try to use the ATLHelpers project).
Thanks, now I ready to read your guide).
Just a quick question, will the tutorial be updated to reflect the new SDK? It currently does not compile, presumably because of the titleformatting changes.
I uploaded a new version of foo_tutorial1. It is available from my components page.
