Topic: Feature request: Easy to use fullscreens for HTPC (Read 2626 times) previous topic - next topic
since a few days fb2k brings me nearer to my personal music heaven. It supports as the only application I know volume control by using RC (or mobile phone via BT) if ASIO is activated, supports active crossover networks and provides more usefull features. But there is nothing like "easy-to-use" clearly designed fullscreens (activated from menu, via keyboard shortcuts or via RC), when "watching" on a TV screen.
Is there any planning (roadmap)?
Thanks for your help.
Martin
If you use columns_ui and have panels_ui installed, this thread could be helpful for you. When you use columns_ui and create a seperate layout for such a view, you can set up keyboard shortcuts to switch between different views.
HTH
ojdo
Hi ojdo,
I tried both columns_ui and panels_ui because the result of your well done work seems to cover all of my needs! But I have not enaugh background to install and set all options correctly
Martin
I'm sorry, the "background" is up to you. I just can point you to the Foobar2000 wiki which provides a lot of information and further links for both columns_ui and panels_ui. It takes some time to understand the principles in order to use my scripts - probably you will have to adapt them to your needs.
Good luck,
ojdo
