Topic: oggenc with FLAC COMMENT COPY support (Read 4465 times) previous topic - next topic
I've just uploaded a version of oggenc, created by Stan Seibert (Volsung), that has integrated FLAC decoding and comment copying. Although Stan has a copy available elsewhere compiled against the FLAC 1.0.4 libs, the version I've uploaded is an ICL6 compile, compiled against the FLAC 1.1.0 libs.
I'd be grateful for any feedback, particularly as to whether the comment copying works correctly because this could provide a quick means of adding this function to oggdropXPd.
John
My compiles and utilities are at http://www.rarewares.org/
I just tested this using Speek's Multi frontend (so I could manually change the location of the program, rather than renaming/overwriting my current oggenc), with two different sets of options:
    -q 6.25 --advanced-encode-option lowpass_frequency=19.5
    -q 6
  I chose the first since it was non-standard, and the second to double-check the results. Each time, I got the following results:
ERROR while decoding data
state = 3:FLAC__STREAM_DECODER_READ_FRAME
  Using either the standard oggenc (through Speek's Multi frontend for piping) or oggenc2.2, the same parameters begin properly encoding the file. So something isn't quite right yet.
    - M.
   -q 6
   - M.
The problem is not in oggencFLAC, it is that Speeks Multifrontend sees a flac input file and then uses flac.exe to pipe the decoded flac file into oggencFLAC. From the command line the options you specified work fine!!
Even using Multifrontend, they work fine here, but the input is thru stdin, so the FLAC decoding is not being invoked. The error message you are seeing is, I would suggest, coming from the standard flac.exe and not oggencFLAC.exe.
John
All right, I tried it again using oggencFLAC -q 6 "G:\01 Blackbird.flac" as a command line and got the following "Unable To Locate Component" message:
This application has failed to start because libmmd.dll was not found. Re-installing the application may fix this problem.
  Next (even though I knew it wouldn't encode) I tried oggenc -q 6 "G:\01 Blackbird.flac" to see if I would get the same error. I didn't, of course; instead it just told me the following:
ERROR: Input file "G:\01 Blackbird.flac" is not a supported format
  So then I went straight to oggenc -q 6 "G:\01 Blackbird.wav", and it immediately began encoding. OggencFLAC works for you; therefore, there is some difference between your system and mine. Should a copy of "libmmd.dll" be included with the ZIP archive? Because it doesn't have one, and the file isn't anywhere on my system.
    - M.
libmmd.dll is a maths library needed by programs compiled by the Intel C++ compiler. There are versions for ICL 6 and ICL 7 at rarewares.
OK, but then why would the ICL6 compile of oggenc2.2 work fine on my system (without that DLL!)? Does simply adding the FLAC decode and "comment copy" support require referencing libmmd.dll, or would it be possible to compile the program such that the extra DLL was not necessary?
    - M.
   - M.
It's a good question!  Would you do me a favour, just to test a theory? I just uploaded another version that doesn't need the 2 flac dlls. Would you delete the dlls and try that one, please? The theory, BTW, is that libmmd.dll may not be needed if it is compiled against the static libs.
Thanks in advance.
John
Encoding works again, but there seems to be an intermittent error in the tag-copying routines. Here are the ASCII interpretations for a couple of tag segments, as shown in HexEdit:
Original FLAC tag for "Blackbird," as recorded by Crosby, Stills, Nash & Young
TITLE=BlackbirdTRACKNUMBER=01ALBUM='Ohio' single#ARTIST=Crosby, Stills, Nash & Young    DATE=1970GENRE=Volatile FolkComment=So Far Away
BAD Transcoded Vorbis tag, using the command line oggencFLAC -q 6 "G:\01 Blackbird.flac"
TITLE=BlackbirdTRACKNUMBER=01!ALBUM='Ohio' single.1.0 20030126    #ARTIST=Crosby, Stills, Nash & Young    DATE=1970GENRE=Volatile FolkComment=So Far Away
  For reference, I encoded "01 Blackbird.flac" using FLAC 1.0.4 with no padding, and a tag was manually added using Case's Tag/Speek's Tag frontend.
Original FLAC tag for "I Had Too Much to Dream (Last Night)," as recorded by the Electric Prunes
TITLE=I Had Too Much to Dream (Last Night)ARTIST=The Electric PrunesALBUM=Reprise single #0532TRACKNUMBER=001    DATE=1966GENRE=Garage PsychLComment=Nuggets: Original Artyfacts from the First Psychedelic Era 1965-1968
GOOD Transcoded Vorbis tag, using the command line oggencFLAC -q 6 "G:\Nuggets_1-01.flac"
  I encoded "Nuggets_1-01.flac" using FLAC 1.1.0 (padding is now enabled by default), and a tag was again manually added using Case's Tag/Speek's Tag frontend. For some reason, when transcoding tags from non-1.1.0 encoded files, the encoder is inserting a portion of the current libFLAC identifier. (!)
  Thanks for checking on this, john33.  It looks like your theory is sound... now it's just a problem of tracking down some elusive glitch in the tag parser.
    - M.
Thanks a lot, M.
I'll research this some. I'll produce a compile against flac 1.0.4 to see whether it is a compatibility problem.
John
New compile uploaded and available from Mirror 1. I located and fixed the comment copying problem.
John
Verified here as well... thank you! Is there any chance Garf might implement this in the final version of GT3?
    - M.
