Oh, thanks! Will update the template ajquery-xxx asap on github then.
Uses responsive design now, so it should be fully compatible with any device. Dark theme available. Full integration with my Playlist Manager and Playlist Tools scripts, full documentation within browser, ported most of the mouse gestures from Foobar2000 (like double clicking on playlist name to rename, or on status bar to show focused item) and fixed a lot of bugs/quirks present on the original template.
*** Release history 2022
14 Sept 0.92
fix: All Playlist Tools and Manager lists get now refreshed when entries are deleted;
fix: All CMD actions are now disabled (UI and functionality) when missing dependencies;
fix: Wrapped all JSON reads on try/catch;
fix: Minor code fixes and code cleanup;
28 Aug 0.91
add: Double clicking on status bar (below playlist) sets focus on playing item;
cha: Playlist Tools integration using dynamic menus;
cha: Updated all help texts about Playlist Tools integration;
fix: Minor code fixes;
25 Jun 0.90
add: File browser now has header columns;
add: Double clicking on active playlist opens rename popup;
add: Double clicking on Console log panel alternates between 2 modes;
add: Double clicking on Artwork alternates between 2 sizes;
add: Double clicking on volume slider mutes the sound (mute button);
add: Help button;
add: Full documentation within browser;
add: Playlist Manager button;
add: Playlist Manager integration: available file list, load / save, actions, etc.;
cha: Full responsive design, should adapt and fully work on any device;
cha: Cursor changes while controller is being reloaded;
cha: Cursor for playlist items;
cha: Cursor for playlist page slider;
cha: Cursor for volume slider;
cha: All popup windows are now closed when pressing their button a second time;
cha: Minor adjustments to UI colors: album name, playing item, backgrounds...;
cha: Minor adjustments to themes;
cha: Minor adjustments to browser UI;
cha: Minor adjustments to progress bar;
cha: Added and edited multiple tooltips;
cha: A lot of code cleanup;
cha: Text on tabs is now non-selectable;
cha: Text on most panels is now non-selectable;
cha: Library list can now be filtered with the search input (usually by artist);
cha: Removed play button. Replaced with smart play/pause button;
cha: Up/down keys allow to select items (+ shift allowed);
cha: Icon for selected items;
fix: Search panel now has a max height and a scroll bar (instead of infinite size)
fix: Text on playlist is now non-selectable (fixes shift + selection not working properly);
fix: Text on progress bar is now non-selectable (fixes seeking not working properly);
fix: Broken seeking (since original ajquery);
fix: Double clicking on playlist page slider to focus on now playing limited to button;
fix: Double clicking on a playlist row now works the same on the title or album;
fix: Focusing on now playing item jumps to page only when needed;
fix: Focusing on now playing item will also mark the item as selected;
fix: Selection is not lost when clicking on buttons, opening panels or running most actions;
fix: Active playlist tab cursor was not consistent with the rest of tabs;
fix: Console log panel position is now limited to window width and height;
fix: Loading indicator showing white background on dark theme;
*** Release history 2021
25 Jun 0.80
add: Development continued to be compatible with Spider Monkey Panel scripts;
add: Playlist Tools integration:
- Call pre-configured menu entries with buttons
- Call arbitrary menu entries by name (retrieves list from foobar first)
- Set DSP (retrieves list from foobar first)
- Set Device (retrieves list from foobar first);
add: SMP main menu integration;
add: Contextual menu Buttons;
add: Themes (and associated art);
add: Console log panel;
add: Rating on playlist list (stars);
cha: General UI changes and font size;
cha: Artwork images (no playing / no artwork);
cha: Row tags are now cut to not overextend over multiple lines;
