Topic: FLAC 1.10 --delete-input-file bug (Read 2299 times) previous topic - next topic
Using multi frontend, if I encode from WAV to FLAC, the input file is deleted properly.
But if I transcode from APE to FLAC, the input file remains.
This is line 5 of go.bat generated by Multi frontend when transcoding:
"mac.exe" "d:\song.ape" - -d | "flac.exe" --best --verify --delete-input-file -o "d:\song.flac" -
This is line 5 of go.bat generated by Multi frontend when converting from WAV:
"flac.exe" --best --verify --delete-input-file "d:\song.wav"
it's not a bug in FLAC (in multi frontend, may be?) - flac gets data from stdin, so it simply can't delete the input file ("standard input" is undeletable). to delete input file you should add a separate line "del d:\song.ape".
a good thing would be a warning in flac when --delete-input-file (and any other operation on files) is specified with specified with stdin/stdout.
True except you only want to delete the source file if the transcoding threw no errors. Since Multi Front End is essentially a DOS batch file creator, how would one try/catch transcoding errors in DOS before del song.ape or otherwise throw an error message to stop the batch file?
"mac.exe" "d:\song.ape" - -d | "flac.exe" --best --verify -o "d:\song.flac" -
if errorlevel 1 goto BAD
del d:\song.ape
echo everything went ok.
goto DONE
:BAD
echo error encoding file!
:DONE
