Topic: MONOGRAM AMR Filter Pack (Read 15664 times) previous topic - next topic
Hello people,
there is a new opensource (GNU GPL) AMR filter pack available for public use. I’ve upgraded the AMR demux and encoder filter with some better timestamp handling and completed the collection by adding a mux and a decoder filter. So now the package contains a set of Encoder+Decoder and Mux+Demux filters. This makes all kinds of encoding/transcoding into and from AMR format possible.
The filter collection is also available at the public MONOGRAM SVN repository and you can checkout the source code using this command:
svn co svn://dev.monogram.sk/public/amr_pack/trunk
Download binary here : mm_amr_pack_1.0.1.0_bin.zip (288 KB)
Enjoy,
Igor
have the force, read the source
Thank you for your good work Igor!
The filterpack works with 4 of my 5 test AMR samples. Does it support WB-AMR or just the NB?
Currently only NB. I may add WB support and multichannel AMR file support soon.
Thanks for these filters
Do you plan to add support for WB+?
Hopefully yes. Can't promise any exact release dates but I'd like to add as many AMR formats as possible.
How to get the source code? Please give more detail.
