Topic: FLAC using EAC "There were errors". Is that normal (Read 6222 times) previous topic - next topic
Ripping my enitire collection for the first (and only?). Using EAC I'm ripping FLAC's (compression 6). At the end of every Log it states "There were errors". Also, some tracks list "Track quality 99.9%". Are these normal things?
I'm somewhat of Audiophile. Knowing I'm not ripping anything but perfect lossless files would keep me awake at night. Hell, I'm still coming to terms with the concept of Lossy compression were data is actually lost!?
Please post a log file so we don't have to guess as to what may have gone wrong (if anything).
Make sure to present it using the "codebox" command.
I have the same question in regards to the "99.8%" accurate. Except in my situation it doesn't say there are errors. What's with the missing .2 percent? I'm not to torn up about it but it is curious.
[!--sizeo:4--][span style=\"font-size:14pt;line-height:100%\"][!--/sizeo--]Here's what the log looks like:[/size]
Exact Audio Copy V0.99 prebeta 4 from 23. January 2008
EAC extraction logfile from 22. February 2008, 21:14
Beatles / Abbey Road
Used drive  : PIONEER DVD-RW  DVR-112D  Adapter: 0  ID: 0
Read mode              : Secure
Utilize accurate stream : Yes
Defeat audio cache      : Yes
Make use of C2 pointers : No
Read offset correction                      : 48
Overread into Lead-In and Lead-Out          : No
Fill up missing offset samples with silence : No
Delete leading and trailing silent blocks  : No
Null samples used in CRC calculations      : Yes
Used interface                              : Native Win32 interface for Win NT & 2000
Gap handling                                : Not detected, thus appended to previous track
Used output format              : User Defined Encoder
Selected bitrate                : 1024 kBit/s
Quality                        : High
Add ID3 tag                    : No
Command line compressor        : C:\Program Files\FLAC\flac.exe
Additional command line options : -6 -V --replay-gain -T "artist=%a" -T "title=%t" -T "album=%g" -T "date=%y" -T "tracknumber=%n" -T "genre=%m" -T "comment=EAC (Secure Mode)" %s
TOC of the extracted CD
    Track |  Start  |  Length  | Start sector | End sector
        1  |  0:00.33 |  4:20.47 |        33    |    19579
        2  |  4:21.05 |  3:03.00 |    19580    |    33304
        3  |  7:24.05 |  3:27.20 |    33305    |    48849
        4  | 10:51.25 |  3:26.53 |    48850    |    64352
        5  | 14:18.03 |  2:51.12 |    64353    |    77189
        6  | 17:09.15 |  7:47.13 |    77190    |  112227
        7  | 24:56.28 |  3:05.42 |    112228    |  126144
        8  | 28:01.70 |  2:45.40 |    126145    |  138559
        9  | 30:47.35 |  4:02.30 |    138560    |  156739
      10  | 34:49.65 |  2:26.23 |    156740    |  167712
      11  | 37:16.13 |  1:06.22 |    167713    |  172684
      12  | 38:22.35 |  1:12.55 |    172685    |  178139
      13  | 39:35.15 |  1:57.55 |    178140    |  186969
      14  | 41:32.70 |  1:31.43 |    186970    |  193837
      15  | 43:04.38 |  1:36.65 |    193838    |  201102
      16  | 44:41.28 |  2:19.62 |    201103    |  211589
      17  | 47:01.15 |  0:23.20 |    211590    |  213334
Track  1
    Filename C:\Documents and Settings\j.JOE\My Documents\My Music\Beatles - Abbey Road - 01 - Come Together.wav
    Peak level 63.3 %
    Track quality 100.0 %
    Copy CRC 51F5C73D
    Copy OK
Track  2
    Filename C:\Documents and Settings\j.JOE\My Documents\My Music\Beatles - Abbey Road - 02 - Something.wav
    Peak level 63.8 %
    Copy CRC 5190A4DF
    Copy OK
Track  3
    Filename C:\Documents and Settings\j.JOE\My Documents\My Music\Beatles - Abbey Road - 03 - Maxwell's Silver Hammer.wav
    Peak level 61.0 %
    Copy CRC A91CCEA1
    Copy OK
Track  4
    Filename C:\Documents and Settings\j.JOE\My Documents\My Music\Beatles - Abbey Road - 04 - Oh! Darling.wav
    Peak level 64.5 %
    Copy CRC 857FF398
    Copy OK
Track  5
    Filename C:\Documents and Settings\j.JOE\My Documents\My Music\Beatles - Abbey Road - 05 - Octopus's Garden.wav
    Peak level 63.8 %
    Copy CRC 5F9C55EA
    Copy OK
Track  6
    Filename C:\Documents and Settings\j.JOE\My Documents\My Music\Beatles - Abbey Road - 06 - I Want You (She's So Heavy).wav
    Peak level 66.8 %
    Copy CRC B40B1A37
    Copy OK
Track  7
    Filename C:\Documents and Settings\j.JOE\My Documents\My Music\Beatles - Abbey Road - 07 - Here Comes The Sun.wav
    Peak level 72.4 %
    Copy CRC B4DA4772
    Copy OK
Track  8
    Filename C:\Documents and Settings\j.JOE\My Documents\My Music\Beatles - Abbey Road - 08 - Because.wav
    Peak level 65.2 %
    Copy CRC 01A022D1
    Copy OK
Track  9
    Filename C:\Documents and Settings\j.JOE\My Documents\My Music\Beatles - Abbey Road - 09 - You Never Give Me Your Money.wav
    Peak level 77.2 %
    Track quality 99.9 %
    Copy CRC FD4EA7C9
    Copy OK
Track 10
    Filename C:\Documents and Settings\j.JOE\My Documents\My Music\Beatles - Abbey Road - 10 - Sun King.wav
    Peak level 61.1 %
    Copy CRC C214C8BA
    Copy OK
Track 11
    Filename C:\Documents and Settings\j.JOE\My Documents\My Music\Beatles - Abbey Road - 11 - Mean Mr Mustard.wav
    Peak level 89.4 %
    Copy CRC 8BD598B9
    Copy OK
Track 12
    Filename C:\Documents and Settings\j.JOE\My Documents\My Music\Beatles - Abbey Road - 12 - Polythene Pam.wav
    Peak level 79.9 %
    Track quality 99.8 %
    Copy CRC D7F94B3C
    Copy OK
Track 13
    Filename C:\Documents and Settings\j.JOE\My Documents\My Music\Beatles - Abbey Road - 13 - She Came In Through The Bathroom Window.wav
    Peak level 75.8 %
    Copy CRC 6E052BA6
    Copy OK
Track 14
    Filename C:\Documents and Settings\j.JOE\My Documents\My Music\Beatles - Abbey Road - 14 - Golden Slumbers.wav
    Peak level 77.2 %
    Copy CRC 60674D4D
    Copy OK
Track 15
    Filename C:\Documents and Settings\j.JOE\My Documents\My Music\Beatles - Abbey Road - 15 - Carry That Weight.wav
    Peak level 77.0 %
    Copy CRC A53DB9A2
    Copy OK
Track 16
    Filename C:\Documents and Settings\j.JOE\My Documents\My Music\Beatles - Abbey Road - 16 - The End.wav
    Peak level 88.3 %
    Copy CRC 607266CF
    Copy OK
Track 17
    Filename C:\Documents and Settings\j.JOE\My Documents\My Music\Beatles - Abbey Road - 17 - Her Majesty.wav
    Missing samples
    Peak level 54.2 %
    Track quality 99.5 %
    Copy CRC 3F29A440
    Copy finished
There were errors
End of status report
[!--sizeo:1--][span style=\"font-size:8pt;line-height:100%\"][!--/sizeo--]Moderation: Codebox!!![/size]
[!--sizeo:1--][span style=\"font-size:8pt;line-height:100%\"][!--/sizeo--]http://www.hydrogenaudio.org/forums/index.php?s=&act=legends&CODE=bbcode[/size]
This happens with some discs.
Try test and copy (Shift+F6) in burst mode or try a different drive.  The error will result in no worse than the substitution of low-level noise with digital silence after the last track has pretty much finished.
