Topic: Panels UI: playlist problems (Read 2952 times) previous topic - next topic
Hey, I've using foobar for ages, and I'v had my current config for a while.
But for some reason the playlist no longer changes when changing it via the playlist switcher - which is odd as I have the same configuration on my other system, and it works fine.
Anyway, some help would be ace.  I've already tried re-installing, but it makes no difference.
darkblackcorner - in the dark since 1986
I'm using Panels UI 0.13.8 beta, but I've never experienced problems with it in the past, and it does still work fine on my other system.
ah HA.  When you asked me that, I thought it could be a UI problem, and sure enough when I restored my Panels UI backup, everything worked again.
Silly me
Thanks man
