Topic: Peakmeter Spectrum component (Read 176618 times) previous topic - next topic
Reply #50
This is the best spectrum visualization plugin. But transparancy is missing to be perfect.
Reply #51
I'll second the request for functionality into the sub-bass. If your sub can make sound down there, why not be able to see it?
Reply #52
Love this plugin.
@Mastermind - I wish I could see how you got that to look like that.  I have tried to get Peakmeter on with AlbumArt and the Columns_UI.  I cannot get them to arrange no matter what I try.  All I get is a wide separator - either vertical or horizontal.  I really want to put the Peakmeter above or below the AlbumArt panel both to the left of the playlist.
RC
Reply #53
Damn ! I was really hoping for that one.  More precisely, what I was hoping for was not an orientation setting, but this :
(1) A symmetric layout for L spectrum / R spectrum :
=> Example :[L spectrum 20.000 --- 20 Hz] [20 Hz --- 20.000 Spectrum R] in the same row, not one over the other of course
(2) The possibility to add the peakmeter wherever we want (or at least between the two L and R spectrums) :
=> Example : [L Spectrum 20.000 --- 20 Hz] [L / R PEAKMETER HERE] [20 Hz --- 20.000 Spectrum R]
Can you imagine this totally symmetrical layout ? It would be REALLY beautiful !
(yeah, I like symmetrical things  )
Pleeeeeeeeeeeaaaaaaaaaaaaaaaaase !!!!!!!!!!!!!
Thank you!  I will take this into consideration. But I think i need to concentrate on other suggestions like adjustable sensitivity and refresh time first before something like this could be implemented.
Don't know what this "window function" accuracy setting does and have no time to find this out, but thanks!
kudos, very well done! looks great!
Thank you!
I'd also like the ability to auto-fill panel, including the potential to automatically adjust number of bands/fft size/spacing to achieve the auto-fill.
The fft size will be no part of the autosize algorithm. Maybe the number of bands.
edit: Did you write the DSP math (fft, window function, etc) yourself?
any chance at releasing source code? pretty please? Might get some people to implement features and submit back to you (hopefully you've got some version control going, even if local)
The most part of fft based on popular algorithms. The window functions are only mathematical formulas. So only performance aspects have to be considered. It’s not something special. If i don't got the time or losing interest to perform maintenance, i will release the source.
Very nice plugin. But what I'm missing, is the possibility of transparent background.
Thank you!  It's already on the todo list.
My 2nd problem is, that the plugin doesn't rezise, when I change the width of my foobar window...
It's also on the list.
Thank you foo_pm! Your plugins rock.
This is my simple yet useful layout on white background
[a href="http://i203.photobucket.com/albums/aa228/Mastermnd_/Foobar.png" target="_blank"]
Thank you!
Moderation: Propagated image to thumbnail conversion. Also removed two excess emoticons because the board software would not let me save the post with the previous number of them.
Reply #54
You can see the sub bass. All frequencies below 28 Hz are consolidated into the 28 Hz Band. I'll think about new bands down to 16.35 Hz, but only to display the C0 octave (see this post).
Love this plugin.
Reply #55
@heatstroke and yeye: Check your pms
Reply #56
Thank YOU !  I'll wait then, no problem, I'll be patient.
Reply #57
Very nice!
Any way you could expand the frequency range to 48KHz? I ask because I play 24-bit/96KHz on a daily basis and it would be nice to see the full range.
Reply #58
Yes, could be nice too...
Reply #59
"see" is the right word, because I'm pretty sure there's no way you can hear 48KHz... provided your tweeter is able to reproduce it, and provided your speaker's filtering system does not cut every frequency well before 48KHz...
(just kidding, don't take it personally  )
Reply #60
Heh, obviously not. I can go almost to 20 though.
But I do needledrops, and some of these old records go well past 40KHz. I just think it's neat to see how high they go.
Reply #61
Thank you for great plug-in
Just one plea
Is there any possibility you would consider adding scrolling spectrum analyzer like the one included in default UI? After lots of waiting and tweaking I finally dropped default UI and returned back to the lovely columns/panels, and the only thing that I miss is the spectrum. Don't know how hard it is to code, but it makes detecting transcodes and poor rips much easier. Please consider it
Reply #62
Just to let you see my spectrum configuration for full 5.1 output
The image is 1600x1200. Yes, I've a quite big screen ...
This preset gives a full control over all channel level and spectrum.
What a great plugin!!
Reply #63
I'm sorry such an enhancement is currently not planned.
Reply #64
Just one plea
Thank you!  The DUI Spectrum is too different from the Peakmeter Spectrum component. So something like that is not planned. Why is the detection of "poor rips" with DUI Spectrum easier?
[a href="http://rvd.it/Temp/Foobar%20Spectrum%2001.png" target="_blank"] Thank you!
Reply #65
Version 0.2.0.0 beta is released.
Download Changelog
Reply #66
Reply #67
Great Spectrum analyzer! I have just one question. Is there a way to get it in its own window instead of having it within Foobar? Thanks!
Reply #68
Thank you for your work, foo_pm! The new options (like peaks fall speed, etc) are amazing!
The past  was yesterday...
Reply #69
Would it be possible to make so we can import from the old one?
Ok, found a way so that I could have both pref windows open, just copied all the entries.
It looks very neat with the peaks falling down.
Thank you.
Reply #70
Question for foo_pm:
Any plans for independent vertical/horizontal orientation of peakmeter and spectrum. You see, I'm running both your components at the same time (specifically -- horizonal peakmeter and vertical spectrum). :\
Thanks for all your hard work
Reply #71
Thanks!  You can use foo_dockable_panels to show the plugin in its own window.
Thank you!
Reply #72
Hi!
I've already asked foo_pm to implement this feature, but he said that "it's unfortunately too time-consuming".
Reply #73
Thank you.
Thanks!    foo_uie_vis_peakmeter_spectrum Version 0.1.x can import pmf files from foo_uie_peakmeter version 0.0.4.x. The new version 0.2.x will only support peakmeter_spectrum files. I will improve the backward compatibility in the next releases.
Hi!
Yes, i'm sorry  , but alternatively you can use two panels. One for the spectrum an one for the peakmeter.
Reply #74
Wow, thanks for that. I had no idea thats what it was for! I feel so silly now
Thanks again for your plugin, its the best one out there I think. Also thanks for all your help in this topic, your one of the few people who really support their work and take time to help others.
