Topic: How do I change the theme? (Read 9876 times) previous topic - next topic
I'd like to use this theme but don't know how to implement it.
I have downloaded all the components listed and put them all in the "Components" folder.
I have downloaded the ".exe" file and ran it.
Now what?
Run foobar (duh..) choose "Panel UI" Hit OK
If you run foobar and there's no choosing dialog popup, Menu bar > file > Preference > Display > at dropdown box choose panel ui and restart foobar.
Now what?
go to Preferences of foobar (CTRL+P), then Display-> Panels UI , and in the combobox Layout, select the theme 'AVA ......'  -> OK
OK... I see how that works but I cannot get the theme to change.
When I select "default.pui" or my current theme "foonion.pui", I see see an immediate change in the player that corresponds to that selection, but when selecting, "DAWXXX666_AVA_1.03+.pui" (new theme), the theme does not make the change.  Instead, it appears as the default theme.
Also, when selecting "Save All" after selecting "DAWXXX666_AVA_1.03+.pui", the selection in the jumpbox reverts back to "default.pui".
Any ideas?
Bump.
EDIT:  Sorted.  Fresh reinstall.
"Theming" - There is no such 'easy' thing. There's geekish hacks, millions of dependencies (plugins, fonts, images) and tons of code. No fun if you're not an übergeek. period.
