You can change the playlist font from File> Preferences> Display> Columns UI> Playlist View> "Colours and Fonts" Tab. You cannot change the fonts from code for that you might want to try SingleColumnPlaylist (Which will allow album art in the playlist also).
You can manage the global style script from File> Preferences> Display> Columns UI> Playlist View> "Globals" Tab. Basically all columns will use any style script specified there, then if "- Use custom style script" is checked under the "Columns" Tab, "Scripts" subtab for the column.. it will use the script defined in the "Style" sub-subtab for that column.
this is clear, thanks
so i suppose i can't use different fonts in different columns..
i had to replace the banned foo_rating since it's unstable, and edited a code i found in this forum to make my own colored rating marks
$if(%_selected%,$textcolor(0,0,0),
$ifequal(%rating%,9,$rgb(74,0,0)?,
$ifgreater(%rating%,5,
$repeat($transition(?,$rgb(255,255,0),$rgb(255,220,3)),$add(%rating%,0)),
$ifgreater(%rating%,4,
$repeat($transition(?,$rgb(255,255,0),$rgb(253,203,2)),$add(%rating%,0))?,
$ifgreater(%rating%,3,
$repeat($transition(?,$rgb(255,255,0),$rgb(251,176,4)),$add(%rating%,0))??,
$ifgreater(%rating%,2,
$repeat($transition(?,$rgb(255,255,0),$rgb(250,146,5)),$add(%rating%,0))???,
$ifgreater(%rating%,1,
$repeat($transition(?,$rgb(255,255,0),$rgb(250,103,5)),$add(%rating%,0))????,
$ifgreater(%rating%,0,
$repeat($transition(?,$rgb(255,255,0),$rgb(252,28,3)),$add(%rating%,0))?????,??????
i used $transition thinking to draw a 3d effect, but didn't get that result... at least it's simple to choose beetwen small gradients of the same color
i use quicktagger and keyboard shortcuts to rate a selected track. i assign rating from 0 to 6 and a 9 mark means a useless track (like a clone)
![](http://img219.imageshack.us/img219/8610/44461812po7.th.jpg)
now i would like to change selected text color in rating column, making those hearts characters black o white instead of yellow-reverse (..blue)
