Topic: RQ: Track info string (Read 3276 times) previous topic - next topic
Can I ask you for the default or some simple looking string for the Track Info panel.
I have one, but it does not always refresh itself, when I change playlists etc.
Thanks in advance
To reset a component to its default settings:
- Exit foobar
- Remove the component's dll from the component directory
- Restart foobar
- When prompted to save the settings for the missing component answer No.
- Exit foobar
- Replace the component's dll into the component directory
- Restart foobar.
As for your refresh issue.. if you are using the old Track Info panel you may need to enable update every second option. If you are using the newer Mod/PanelsUI version you may need to add // PerTrack, // PerSecond, etc. You may also need to adjust a setting to follow the currently selected or the currently playing track.
