Here is the log from a secure rip, although it says track 9 & 10 could not be copied they are there. C2 is still not checked. I do not have any CRC info for tracks 9 & 10 but all the others match now as opposed to Burst.
Exact Audio Copy V0.99 prebeta 3 from 28. July 2007
EAC extraction logfile from 12. January 2008, 12:26
Hed Kandi / Winter Chill 06.02 (CD1)
Used drive : HL-DT-STDVD-ROM GDR8164B Adapter: 1 ID: 0
Read mode : Secure
Utilize accurate stream : Yes
Defeat audio cache : Yes
Make use of C2 pointers : No
Read offset correction : 102
Overread into Lead-In and Lead-Out : No
Delete leading and trailing silent blocks : No
Null samples used in CRC calculations : No
Used interface : Native Win32 interface for Win NT & 2000
Gap handling : Not detected, thus appended to previous track
Used output format : User Defined Encoder
Selected bitrate : 128 kBit/s
Quality : High
Add ID3 tag : No
Command line compressor : F:\Program Files\Exact Audio Copy\Flac\flac.exe
Additional command line options : -6 -V -T "artist=%a" -T "title=%t" -T "album=%g" -T "date=%y" -T "tracknumber=%n" -T "genre=%m" -T comment="%e" -T "comment=EAC (Secure Mode)" %s
TOC of the extracted CD
Track | Start | Length | Start sector | End sector
1 | 0:00.00 | 5:18.56 | 0 | 23905
2 | 5:18.56 | 3:25.66 | 23906 | 39346
3 | 8:44.47 | 6:25.36 | 39347 | 68257
4 | 15:10.08 | 4:48.27 | 68258 | 89884
5 | 19:58.35 | 4:27.26 | 89885 | 109935
6 | 24:25.61 | 5:51.21 | 109936 | 136281
7 | 30:17.07 | 4:17.14 | 136282 | 155570
8 | 34:34.21 | 4:48.24 | 155571 | 177194
9 | 39:22.45 | 3:56.13 | 177195 | 194907
10 | 43:18.58 | 3:29.58 | 194908 | 210640
11 | 46:48.41 | 6:06.54 | 210641 | 238144
12 | 52:55.20 | 3:26.16 | 238145 | 253610
13 | 56:21.36 | 5:00.41 | 253611 | 276151
14 | 61:22.02 | 3:51.69 | 276152 | 293545
15 | 65:13.71 | 5:09.13 | 293546 | 316733
Track 1
Filename H:\My Music\Hed Kandi - Winter Chill 06.02 (CD1) - 01 - Slovo - Whisper.wav
Peak level 99.8 %
Track quality 100.0 %
Test CRC 802A5671
Copy CRC 802A5671
Accurately ripped (confidence 5) [8942C2EB]
Copy OK
Track 2
Filename H:\My Music\Hed Kandi - Winter Chill 06.02 (CD1) - 02 - Abraham - Magpie.wav
Peak level 99.7 %
Track quality 99.9 %
Test CRC 9D87C7FE
Copy CRC 9D87C7FE
Accurately ripped (confidence 5) [0AF5842F]
Copy OK
Track 3
Filename H:\My Music\Hed Kandi - Winter Chill 06.02 (CD1) - 03 - Nova June - Another Try.wav
Peak level 99.4 %
Test CRC 35390781
Copy CRC 35390781
Accurately ripped (confidence 5) [547695B5]
Copy OK
Track 4
Filename H:\My Music\Hed Kandi - Winter Chill 06.02 (CD1) - 04 - Hard Kandy - Standstill.wav
Peak level 99.8 %
Test CRC 1BD18161
Copy CRC 1BD18161
Accurately ripped (confidence 5) [4EBCD2B2]
Copy OK
Track 5
Filename H:\My Music\Hed Kandi - Winter Chill 06.02 (CD1) - 05 - Eric Kupper presents Roy Camembert & His Orchestra - Missing.wav
Peak level 99.8 %
Test CRC 944CA10B
Copy CRC 944CA10B
Accurately ripped (confidence 5) [F03F6C2F]
Copy OK
Track 6
Filename H:\My Music\Hed Kandi - Winter Chill 06.02 (CD1) - 06 - KimBlee - Naturally (Yearn mix).wav
Peak level 96.7 %
Test CRC 31DC0881
Copy CRC 31DC0881
Accurately ripped (confidence 5) [C19EB189]
Copy OK
Track 7
Filename H:\My Music\Hed Kandi - Winter Chill 06.02 (CD1) - 07 - Ive Mendes - Night Night.wav
Peak level 99.8 %
Test CRC B41EAE6E
Copy CRC B41EAE6E
Accurately ripped (confidence 5) [D8C545AA]
Copy OK
Track 8
Filename H:\My Music\Hed Kandi - Winter Chill 06.02 (CD1) - 08 - Almadrava - I'm Sorry.wav
Peak level 100.0 %
Test CRC 2C4E5DA6
Copy CRC 2C4E5DA6
Accurately ripped (confidence 5) [C442F3EE]
Copy OK
Track 9
Filename H:\My Music\Hed Kandi - Winter Chill 06.02 (CD1) - 09 - Space Raiders - Beautiful Crazy.wav
Copy aborted
Track 10
Filename H:\My Music\Hed Kandi - Winter Chill 06.02 (CD1) - 10 - Poloroid - Count On You.wav
Suspicious position 0:00:00
Copy aborted
Track 11
Filename H:\My Music\Hed Kandi - Winter Chill 06.02 (CD1) - 11 - Aim ft. Kate Rogers - The Girl Who Fell Through The Ice.wav
Peak level 100.0 %
Test CRC 329399F3
Copy CRC 329399F3
Accurately ripped (confidence 5) [6AF507D0]
Copy OK
Track 12
Filename H:\My Music\Hed Kandi - Winter Chill 06.02 (CD1) - 12 - Fingathing - Haze.wav
Peak level 95.2 %
Test CRC 97AECABE
Copy CRC 97AECABE
Accurately ripped (confidence 5) [D6D19046]
Copy OK
Track 13
Filename H:\My Music\Hed Kandi - Winter Chill 06.02 (CD1) - 13 - Gare Du Nord - Pablos Blues.wav
Peak level 99.9 %
Test CRC 62894607
Copy CRC 62894607
Accurately ripped (confidence 5) [E302D9CF]
Copy OK
Track 14
Filename H:\My Music\Hed Kandi - Winter Chill 06.02 (CD1) - 14 - 39 Vybes ft. John Lee Hooker , Groove Armada , Rachel Brown - Sometimes Lonely.wav
Peak level 99.6 %
Test CRC 3DD1E959
Copy CRC 3DD1E959
Accurately ripped (confidence 5) [6D712DFB]
Copy OK
Track 15
Filename H:\My Music\Hed Kandi - Winter Chill 06.02 (CD1) - 15 - Moby - Sunday (The Day Before My Birthday).wav
Peak level 100.0 %
Track quality 99.8 %
Test CRC 0C96554A
Copy CRC 0C96554A
Accurately ripped (confidence 5) [8D4D1FA8]
Copy OK
13 track(s) accurately ripped
2 track(s) canceled
Some tracks could not be verified as accurate
There were errors
End of status report
So basically, If C2 is checked and it reports the same errors I can trust it? At that point should I just do a test and copy anyway or is it pointless with C2 checked?
Here is something interesting, the 2 secure rips I did of this CD, one with C2 one without both did not make playable copies of track 9 & 10 however burst mode plays fine. The 2 secure rips left those 2 tracks as .wav files. The only problem is the Burst mode CRC's didnt match.
I did have error checking on high, should I lower that?
[!--sizeo:1--][span style=\"font-size:8pt;line-height:100%\"][!--/sizeo--]Moderation: Quote changed to codebox. Please get into the habit of using codebox.[/size]
EDIT:
I also did check using the -usefua command on my drive ( I did it from a dos window and EAC popped up so I assume it ran the switch)
Here is the log, it did come up with errors:
EAC extraction logfile from 12. January 2008, 15:00
Read mode : Secure
Defeat audio cache : No
Quality : High
Add ID3 tag : No
Track 9
Copy aborted
Track 10
Copy aborted
No tracks could be verified as accurate
There were errors
As much as I am starting to understand this, I dont get why burst mode was the only one able to make those files from a bum disk.
[!--sizeo:1--][span style=\"font-size:8pt;line-height:100%\"][!--/sizeo--]Moderation: Code changed to codebox.[/size]
